04-10-2013, 11:42 AM | #3213 |
Rep 1,622
Thanks guys. So best approach is to find out what version of ESYS and PSDzData was used by BMW and use that same version?
Makes sense..
2013 BMW INDIVIDUAL ///M5 {Frozen Black/Amaro Brown/Amaro Brown Alcantara/White Contrast Stitching/Piano Black Trim}
04-10-2013, 12:34 PM | #3214 |
Rep 40,789
No. I just told you ideally (i.e. best) you would use the latest E-Sys and PSdZData you can. While you may be able to get away with using older E-Sys and or PSdZData today, it is just a matter of time before you car gets updated ISTA/P from dealer anyway, and then you will have no choice but to update your E-Sys and PSdZData. Might as well just do it now rather than prolong the inevitable.
04-10-2013, 12:40 PM | #3215 | |
Rep 40,789
Combox Installation Instruction for Exx Series BMW.pdf With the introduction of the F30, and new BT Option 6NH, I am not sure if there exists a separate MULF module anymore, or if BT functions are built into the Head Unit, so the Combox connections in a car with 6NH are not clear to me, although I am sure wiring is involved still.
04-10-2013, 01:16 PM | #3216 |
Rep 1,130
Drives: '16 340i AW MSport
Shawn,
My Car is coming to me from Germany now, Delivery around May, is there any chance at all I'm able to code it with the other esys/PSdZData that did not require the $65 token purchase, or are all cars built now already updated to the latest version? |
04-10-2013, 01:20 PM | #3217 |
Rep 40,789
Your car will have the latest ISTA/P, which means you need the latest PSdZData, which means you will need updated E-Sys.
04-10-2013, 01:23 PM | #3218 | |
Rep 1,130
**Edit: Thanks so much for the info, not enough people say it, you are the MAN! |
04-10-2013, 01:52 PM | #3219 | |
Rep 1,622
04-10-2013, 01:53 PM | #3220 | |
Rep 40,789
If it was for 3.22.5 and 49.1, then that's it.
04-10-2013, 02:12 PM | #3221 | |
Rep 286
04-10-2013, 02:19 PM | #3222 |
Rep 40,789
No, sorry. I would contact Bimmer Retrofit, which is based out of Quebec, and see if they have a shop in Toronto that could do the retrofit.
04-10-2013, 05:56 PM | #3223 | |
Rep 226
04-10-2013, 06:07 PM | #3224 | |
Rep 40,789
The choice is yours, but recoding all of CAS and FRM isn't more than 5 minutes of work. |
04-10-2013, 06:10 PM | #3225 |
Rep 226
I believe it was something in the cas fdl that I changed I'm not good with German. I think it's the other _FB thing I changed lol. I'll take a look at it and see what I did. Doing your steps will reset it back to factory right?
04-10-2013, 06:12 PM | #3226 |
Rep 40,789
Yes, it will be back to its as delivered condition.
04-10-2013, 11:50 PM | #3227 | |
Rep 1,544
04-11-2013, 10:48 AM | #3229 | |
Rep 286
I spoke to a bimmer retrofit dealer in Toronto. He can get that (Combox) installed for me with BMW Live. I confirmed and he said no MULF as it's a L7 HU. He wants additional $150 for BMW Live activation, should i do it with him or should i code it later with the instruction you provided in the earlier post? It's about $800 (including installation with additional wiring) without BMW Live activation. Thanks http://bimmerretrofit.com/store/inde...&product_id=94 |
04-11-2013, 12:09 PM | #3231 |
Rep 40,789
For starters, S5ADA Lane departure warning (or maybe Lane Departure Warning w/Collision Mitigation) and a 7E FSC Code Imported and Activated in KAFAS module.
04-11-2013, 12:10 PM | #3232 | |
Rep 40,789
04-11-2013, 01:08 PM | #3233 |
Rep 1,976
Drives: 2020 G20 320i M Sport
04-11-2013, 01:10 PM | #3234 |
Rep 40,789
