03-22-2014, 07:43 AM | #375 |
Rep 15,858
03-22-2014, 10:10 AM | #376 |
Rep 19,982
Similar to ours and ours is probably the same proportion motorway, albeit M25 and M4 rush hours, so quite slow.
03-22-2014, 10:58 AM | #377 |
Rep 633
After 2.5 weeks of ownership and 700 miles, I know my 335d can average as high as 54mpg (160 mile drive back from dealer), 36mpg (commute trips where the engine doesn't get to temperature) and less than 30mpg when I'm using most of the 300+hp. No surprises for me.
As I think that is perfectly acceptable (given the available performance I actually think it is great), should I stop worrying about 'brim to brim' figures and just enjoy my car?
335d collected from TRL on 4/3/14
03-22-2014, 11:26 AM | #378 | |
Rep 19,982
03-22-2014, 03:50 PM | #379 |
Rep 633
I should pass the 1200 miles run-in distance in about 2 weeks.
03-22-2014, 04:31 PM | #380 |
Rep 2,651
Drives: M4 Comp Pack
03-23-2014, 04:36 AM | #381 |
Rep 633
Fantastic! Can't wait.
03-23-2014, 05:47 AM | #382 | |
Rep 385
The difference I get running at 81 on the speedo (77 on gps) and running at 76 on the speedo (70 on the gps) is around 4mpg. Oddly though the difference between running at 81 and running at 100 is only 0.3mpg. Obvious gearing and mapping advantages to driving at German speeds. |
03-23-2014, 05:48 AM | #383 |
Rep 385
03-23-2014, 05:50 AM | #384 |
Rep 633
Really? That surprises me, A LOT!
03-23-2014, 05:55 AM | #385 |
Rep 385
Wind et al will play a role but yes. One run where I was late for the channel tunnel and one run at ordinary speeds. Same time of day, same traffic load, same ish weather. Distance covered being 280miles.
81 run gave 40.4mpg. 100 gave 40.1mpg. The same run at 75 gives 44.7mpg. |
03-23-2014, 06:07 AM | #386 | |
Rep 633
03-23-2014, 06:28 AM | #388 | |
Rep 633
I bet there aren't many family saloon size cars that will touch 40mpg at 100mph. High gearing helps - just 2200rpm at 100mph in 8th.
03-23-2014, 06:36 AM | #389 |
Rep 385
That's the thinking I had too. I imagine while off boost between 2krpm and 2.5krpm it runs fairly lean to promote MPG at German unrestricted and 140kph limits.
03-23-2014, 06:52 AM | #390 | |
Rep 633
If I get pulled at a ton, I'll let them know 'I'm saving the planet'.
03-23-2014, 06:14 PM | #391 | |
Rep 15,858
Wonder what you'd be seeing in controlled conditions? What you indicate would be a very weird BSFC map, assuming both speeds were in 8th gear. There are not many controlled tests which go to, or above 100mph. A graph which I have seen for the M57 engine in a 535d shows a linear mph vs. mpg drop off from 50 to 110mph, is only then very slowly curves to 155mph. I can't see the current engine being much different... how did you get the average figures? OBC? HighlandPete |
03-23-2014, 07:58 PM | #392 |
Rep 1,442
I'm going to Switzerland this week diverting my route through Germany ( but only about 100 miles) and hopefully I can get my 1200 miles mark before so I will give it a kickdown and can see the "REAL" mpg
Current: 2019 C63 AMG Selenite Grey
Previous: 2017 C43 AMG Coupe Polar White 2014 F30 335d Msport MG with ACS springs 2007 E92 335i BS ultimate drive Last edited by FSE23; 03-23-2014 at 08:14 PM.. |
04-03-2014, 03:25 AM | #393 |
Rep 491
Currently i am averaging 41.2MPG. This is based over 320 miles of driving. The main drive is motorway but 35% has been on 30mph roads. I have also had a few blasts in the car.
Today driving into work on Motorway and normal roads i did just under 49mpg. NOW this included driving through about 9 miles of 50mph limits too and about 30% 30mph roads too. I cannot see a 335D doing 50mpg over a full tank but then again I haven't driven like a granny for a full tank either! Overall this impressed with the cars fuel consumption! 41mpg for a car thats only done 700 miles isnt bad?!?!? |
04-03-2014, 07:59 AM | #395 |
Rep 380
486 miles out of tank for a 300bhp+ car is really impressive. Were you taking it easy or just driving normally for that tank?
Current: F30 335d xDrive MSport (EBII/Black Dakota)
