06-22-2016, 10:53 AM | #1 |
Rep 22,755
getBMWparts.com | Dinan F2x F3x Adjustable Anti-Roll Bar Set for xDrive Models!!!
getBMWparts.com | Dinan Lightweight Tubular F2x F3x Adjustable Anti-Roll Bar Set for xDrive Models!!! Part number: D120-0595 Fitment for: F22 228i, F22 M235i, F30 320i, F30 328i, F30 335i, F32 428i, F32 435i, F33 428i, F33 435i, F36 428i, and F36 435i Install Time: 6.1 - 7.4 hrs depending on application. Description: Almost all street cars come from the manufacturer with an anti-roll bar as it is a common part of modern suspension systems. However they are designed to be overly soft for maximum comfort. An anti-roll bar does exactly what it says by reducing body roll in all situations. Every Dinan tuned anti-roll bar is built and tuned specifically for each BMW chassis. Lowering the amount of body roll keeps your BMW more level than stock (while still allowing just enough body roll) to improve mechanical grip. This improvement gives the driver a much more planted and confident feeling in every corner. Front Anti-Roll Bar (for xDrive) Add a 25mm Lightweight Tubular Adjustable Front Anti-Roll Bar to reduce body roll, improve grip and stability while saving weight at the same time. This anti-roll bar is adjustable up to 45% to 93% stiffer than the stock bar*. This 3 hole bar can be mounted in 3 different positions with stock BMW end links. Benefits of the Dinan Adjustable Tubular Front Anti-Roll Bar: • Less Body Roll • More Mechanical Grip • More Stable At Limit • Large 25mm size* o Stock bar is 23.6 mm on the M235i which means the new bar can be adjusted from 45% to 74% stiffer than the stock front sway bar. o Stock bar is 22.5 mm on the 228i/320i/328i/428i which means the new bar can be adjusted from 61% to 93% stiffer than the stock front sway bar. o Stock bar is 22.5 mm on the 335i/340i/435i which means the new bar can be adjusted from 54% to 84% stiffer than the stock front sway bar. • 3 hole bar with 3 possible positions on the bar • Tubular (Hollow) Construction Includes: Lightweight Tubular Adjustable Front Anti-Roll Bar, Urethane Bushings, Heavy Duty Brackets w/ Grease Fittings. Rear Anti-Roll Bar Add a 19mm Lightweight Tubular Adjustable Rear Anti-Roll Bar to reduce body roll, improve grip and stability while saving weight at the same time.This anti-roll bar is adjustable up to 359% to 474% stiffer than the stock bar*. This 3 hole bar can be mounted in 3 different positions with stock BMW end links. Benefits of the Dinan Adjustable Tubular Rear Anti-Roll Bar: • Less Body Roll • More Mechanical Grip • More Stable At Limit • Large 19mm size* o Stock bar is 12 mm which means the new bar can be adjusted from 359% to 474% stiffer than the stock rear sway bar. • 3 hole bar with 3 possible positions on bar • Only tubular anti-roll bar with a large range of adjustment on the market • Tubular (Hollow) Construction Includes: Lightweight Tubular Adjustable Rear Anti-Roll Bar, Urethane Bushings, Heavy Duty Brackets w/ Grease Fittings. Available on our Dinan Catalog here - PM for forum pricing + FREE US Ground Shipping!!!
Evan Winstead · Internet Parts Director
Contact Us | Facebook | Twitter | New: Shop Porsche & Audi parts! Last edited by Evan@Tischer; 03-15-2021 at 03:43 PM.. |
Tags |
dinan, getbmwparts.com, roll bar, sway bar, tischer |
