01-06-2016, 11:11 AM | #1 |
Rep 171
Drives: X3 M Comp
Can/How to Code Sport+
I have read a number of posts, but I'm not 100% sure if I can code to have Sport+ and the Automatic Sport Transmission enabled on my car. I only have ECO Pro, Comfort, and Sport when switching modes. I do have the 8-speed transmission, but Sport+ isn't shown when switching modes. Can anyone give some guidance if I can enable Sport+ and the other Automatic Sport Transmission codes. Thanks.
-NVE |
01-07-2016, 02:11 PM | #2 |
Rep 171
Drives: X3 M Comp
Just in case anyone is wondering or looking for the same info, I found the answer in the F30/F32 Cheat Sheet Rev. 1.7 Got everything coded and works like a charm!
-NVE |
01-07-2016, 03:27 PM | #3 |
Rep 26
thanks. I saw that after seeing your question, but didn't provide that solution as i thought there was more to it.
MODIFY THE READ FA - Change 205 to 2TB from the vehicle FA. VO CODE - EGS, ICM, and KOMBI. what is the VO Code changes? I have coded a few things successfully FDL- but not VO. any tips? also, 8 speed auto is all required? does sport+ do more than sports mode? i.e.. further enhanced? |
01-07-2016, 03:55 PM | #4 | |
Rep 1,201
It's almost the same as FDL but instead you right click on the ECU, instead of the CAFD and CODE to upload the updated information for the new FA See attachment
Current - 2021 G20 330i M Sport+
Gone - 2017 F30 335d M Sport + in San Marino Blue Gone - 2015 F30 LCI 320d M Sport+ Step Auto Gone - 2012 F30 320 ED Gone - 2011 E87 118d Last edited by stu14t; 01-08-2016 at 02:21 AM.. |
03-01-2016, 10:47 PM | #6 | |
Rep 1,067
03-02-2016, 07:05 AM | #7 | |
Rep 105
I just FDL coded the following: Code:
Kombi/ 300C /ECO_FDSF /Function / -> FDS_MENUE_TEXT_1=> menue_3 -> FDS_MENUE_SIGNAL_1=> menue_3 -> FDS_MENUE_TEXT_2=> menue_3 -> FDS_MENUE_SIGNAL_2=> menue_3 -> FDS_MENUE_TEXT_3=> menue_3 -> FDS_MENUE_SIGNAL_3=> menue_3 -> FDS_MENUE_TEXT_4=> menue_3 -> FDS_MENUE_SIGNAL_4=> menue_3 ICM/3000 Daten -> IcmKod_B_Sportlenkung -> verbaut ICM/3000 Daten -> IcmKod_B_S2TBA -> verbaut EGS/3000 Applikation -> Sportschalter_alt -> aktiv EGS/3000 Applikation -> Sportschalter -> aktiv Do I need to remove 205 and add 2TB anyways? |
03-02-2016, 12:59 PM | #8 | |
Rep 1,201
There is much more "coding" for 205 as opposed to 2TB oddly enough. 205 is coded first then 2TB makes changes??? not sure
Gone - 2017 F30 335d M Sport + in San Marino Blue Gone - 2015 F30 LCI 320d M Sport+ Step Auto Gone - 2012 F30 320 ED Gone - 2011 E87 118d Last edited by stu14t; 03-03-2016 at 02:22 AM.. |
03-03-2016, 02:27 AM | #10 |
Rep 1,201
If you change the VO it just makes it a bit more robust if it goes to the dealers.
Most FDL coding gets lost if there is an updated at the dealers. This is less likely if the VO is changed.
Gone - 2017 F30 335d M Sport + in San Marino Blue Gone - 2015 F30 LCI 320d M Sport+ Step Auto Gone - 2012 F30 320 ED Gone - 2011 E87 118d |
05-18-2016, 01:41 PM | #11 |
Rep 39
