01-15-2023, 01:59 AM | #1 |
Rep 8
wheel and tire fitment on a 2015 335i m sport rwd
Hey so I’m new to the forums I was wondering what et on wheels I would need in order for me to run a 255 in front and 275 in rear? I want to run a 19 inch wheel
01-15-2023, 04:49 AM | #2 | |
Rep 5,392
He’s the guru and I believe someone recently asked the same question |
alohasurftoad3081.50 |
01-15-2023, 08:44 PM | #5 |
Rep 8
Yeah I’m looking for the most aggressive look bc I want a 275-30-19 in the rear and 255-35-19 in the front but idk what offset I need for the wheels in order for me not to rub it’s on stock suspension and how wide wheels would I need too
01-15-2023, 10:14 PM | #6 | |
Rep 4,333
275/30/19, 25.5", 3.2" sidewall This is a slight reverse rake diameter stagger and may look a bit odd profile view. I suggest doing one of these staggered combos instead 245/35/19(25.8") & 275/30/19 or 255/35/19 & 285/30/19(25.7") to reduce the reverse rake to a bit more level, or 255/35/19 & 275/35/19 & 275/35/19(26.6"), which'll be forward rake and look better than reverse. front: 9" or 8.5", ET35ish rear: 10" or 9.5", ET45ish will work for all of these. . Last edited by alohasurftoad; 01-15-2023 at 10:21 PM.. |
K_O_S4.50 |
01-15-2023, 10:47 PM | #7 |
Rep 8
Ok thank you it makes a lot more sense now
01-15-2023, 11:07 PM | #8 |
Rep 8
Would there be any rubbing issues with a 19x9 with a 245-34-19 in the front and a 19x10 in the rear with 275-30-19 and could I run a et35 in the front and a et40 in the rear with a 5mm spacer or would it rub
01-16-2023, 01:19 AM | #10 |
Rep 8
Ok thank you for the help. What setup do you have on yours?
01-16-2023, 01:52 AM | #12 | |
Rep 4,333
https://f30.bimmerpost.com/forums/sh...&postcount=290 https://f30.bimmerpost.com/forums/sh...&postcount=321 . |
K_O_S4.50 |
01-16-2023, 01:56 AM | #13 |
Rep 8
That’s nice it looks perfect with that setup
