06-02-2017, 03:13 PM | #67 |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, www.hpautosport.com
06-07-2017, 02:19 PM | #69 |
3847
Rep 54,376
Drives: F80 M3
06-07-2017, 03:20 PM | #70 |
electrified
32
Rep 127
06-07-2017, 04:16 PM | #71 |
3847
Rep 54,376
Drives: F80 M3
How much heavier is it compare to a 328i or 335i? If only a couple of hundred pounds, there is enough adjustment to compensate for the weight.
06-07-2017, 04:40 PM | #72 |
electrified
32
Rep 127
Took a quick look online, it seems that the 330e is 160kg (350ish pounds) heavier that the 328i (now 330i) equivalent.
06-07-2017, 05:10 PM | #73 | |
3847
Rep 54,376
Drives: F80 M3
Did you say most of the weight is in the rear of the car? The pre-load position is only 22 mm so you have plenty of adjustments for the added weight of your car. Spring used is a 160n/mm and that is also plenty. |
06-09-2017, 11:09 AM | #74 |
Rep 1,291
FWIW i have KW coilovers for 335i on my AH3 which has a 200lbs battery in the boot, so similar situation to your 330e vs. 328i and it's fine, i suspect it's a little lower than a 335i with the same rear height settings but that's really all I can say about it.
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
07-20-2017, 11:31 PM | #75 |
3847
Rep 54,376
Drives: F80 M3
There is enough adjustability to compensate for the weight difference.
07-23-2017, 11:23 PM | #76 |
Rep 397
Geez, I really really really want these.... The only problem is finding a competent installer that isn't charging a grand to install these around here.
2016 BMW 328i M Sport 6MT (Mineral Grey over Coral Red)
*BPC DME Custom Stage 1 Tune *Evolution Racerwerks Competition Intercooler & Chargepipe *M Performance Big Brake Kit |
07-27-2017, 12:04 PM | #77 |
3847
Rep 54,376
Drives: F80 M3
10-03-2017, 05:33 PM | #78 |
Rep 2,044
Hello BMW Experts!
A few questions, pls.... - Do you get to choose your spring rate? - At the highest position, is it as high as any stock 3-series suspensions (we like snow)? - Can a normal person install these, or is a garage needed? TIA! Murf Last edited by Littlebear; 10-30-2021 at 06:03 AM.. |
10-11-2017, 01:25 PM | #79 |
Rep 203
I’m a big fan of Ohlins DFV or otherwise known as Road and Track. I have a set fitted to my Nissan 350z and handling is simply amazing.
I have been looking at KW DDC which appears to be a nice setup however I do not like the very low ride height and the fact that you cannot adjust height and preload independently where as you can on Öhlins. Does the Ohlins F30 model fit an F32 non adaptive damping model? |
10-12-2017, 12:25 AM | #80 | |
Rep 1,291
What’s the interest of adjusting preload? Never thought about that. And yes i wish my DDCs had a bit more room for adjustment on the high side :-/
10-12-2017, 12:57 PM | #81 |
Rep 203
Basically as you apply more preload the spring has more tension and vice versa. More preload does not necessarily make the spring stiffer but changes the behaviour characteristics of the spring. Article below explains.
http://teinusa-blog.com/preloading-it-up/ |
11-25-2017, 02:48 PM | #82 |
Rep 8,499
For anyone considering Ohlins Road & Track you may be interested in my review of them on my F31 330D.
http://f30.bimmerpost.com/forums/sho...ins+road+track They are outstanding for fast road use and occasional track sessions - I highly recommend them. A quality passive setup is hard to beat and shows just how wrong BMW got the EDC/adaptive setup on the F series. I doubt I'll ever spec OEM adaptive dampers again.
11-25-2017, 03:37 PM | #83 | |
3847
Rep 54,376
Drives: F80 M3
Yes, you can run it at stock height or even a bit higher. Yes, you should be able to do this if you have all the right tools. You will need a professional wheel alignment afterwards. |
12-05-2017, 01:43 PM | #84 |
Rep 1,499
Dog Face Pony Soldier9719.50 |
12-05-2017, 09:17 PM | #85 | |
2006 TIME Person Of The Year
9720
Rep 6,445
12-06-2017, 09:58 PM | #86 | |
3847
Rep 54,376
Drives: F80 M3
JaredG_F301106.00 |
12-07-2017, 04:56 PM | #87 |
Rep 10,256
Walmart just like Amazon sells products from other merchants, or - acts as a lead generator by displaying content only - no inventory. This set is sold by another merchant.
12-07-2017, 05:39 PM | #88 |
3847
Rep 54,376
Drives: F80 M3
Ohlins, as far as I know, do not allow their authorized dealers to sell through Amazon or Wallmart.
