12-23-2012, 06:41 PM | #23 |
Rep 1,549
What?!?!? Are you pressing the camera button manually David?
12-23-2012, 06:43 PM | #24 | |
Rep 1,549
Thanks for updating us that the service was minor. Cheers. |
12-23-2012, 07:54 PM | #25 |
Rep 4,553
Well that's idiotic. If it doesn't switch on automatic then what's the point? Is this a coding thing or another bug?
12-23-2012, 09:00 PM | #26 |
Rep 3,566
Ever since the software update last week, yes. Most annoying but I'm getting used to it. You do, when you have to.
I took it to Stillwell earlier today and they thought they fixed it within 2 minutes, but just did what I did and pressed the camera on button (top icon). It only works for that reverse engagement only. I have to press it on each time I engage reverse. So as I want Andrew from SouthernBM to change setup values (otherwise commonly known on F30Post as 'coding') on a number of operational items once his system is up & running, I will ask him to change the camera to default on. Otherwise it's leave it at Stillwell's for a few hours and I'm not going to do that again, if I don't have to.
12-23-2012, 09:03 PM | #27 |
Rep 3,566
Tell me about it. The updates should be 'cleverer' than that, especially when there's a camera installed. It should have defaulted to on. Yep, it's a 'coding' thing as it automatically came on each time I engaged reverse prior to the update last week.
12-23-2012, 09:11 PM | #28 | |
Rep 4,553
BMW needs to hire Apple to program their cars. Everything except mapping. Google for mapping! BTW, Merry Christmas to those celebrating in a few short hours. |
12-24-2012, 04:44 AM | #29 |
Rep 3,566
Nope. All good there. Just the rear camera at this stage.
12-27-2012, 10:13 PM | #30 |
Rep 3,288
The FEM update is to address an issue with incorrect voltage going to a system (can't remember which) when the wipers are also in operation.
12-28-2012, 11:38 PM | #31 |
Rep 49
12-29-2012, 06:11 AM | #32 |
Rep 3,566
The update also reset the Journey computer and erased saved radio station settings.
12-29-2012, 07:26 AM | #33 | |
Rep 3,288
I don't have the problem you have with your rear camera not defaulting to on either post-update FYI. |
12-29-2012, 03:35 PM | #34 |
Rep 3,566
According to Stillwell BMW's service tech, they haven't had this happen to any other F30 after update. I'm used to pressing the iDrive knob to activate the camera
