05-18-2017, 10:32 AM | #375 |
Rep 8
05-18-2017, 12:54 PM | #376 |
Rep 499
You diagnosed the issue before arriving, they misdiagnosed the issue, then bilked you out of $900 -- some of which included an unnecessary software update.
I'd say it's on them. The engine could have been salvaged when you brought it in, originally. And now....? I'm surprised they are only saying $5500. Is that for a new engine? Other people were quoted three to four times that. Either way, it's not your fault. |
05-18-2017, 03:12 PM | #377 | ||
Rep 8
As far as I know everything else is fine, the service representative just mentioned there was slack in the timing chain and that it needs to be replaced. |
05-18-2017, 06:44 PM | #378 |
Rep 943
Drives: 2012 328i Modern Line
I've never heard of a loose timing chain that hasn't grenaded an engine causing limp mode. That being said $5,500 is almost double what mine cost (covered under CPO). My posts are earlier in this thread but basically a tech heard the notorious whine while I was getting my OFH recall done and a PUMA case was opened.
:wave:
05-19-2017, 12:18 AM | #379 | |
Rep 8
05-19-2017, 10:05 AM | #380 |
VIP
41
Rep 151
Life is not measured by the number of breaths you take but by the moments that take your breath away...
05-26-2017, 05:03 PM | #381 |
Rep 305
I've been following this thread and it's really scarring me. I went back and reread a few pages but I don't recall anyone having this issue (at least not yet due to low mileage and age) for a mid 2015 produced N26. Has this problem been fixed on the newer cars?
On a personal note: Who the F**K thought it was good idea to use plastic in an engine with hot oil? I mean doesn't heat = bad for any plastics? Especially on such a critical component? What were they thinking? Last edited by turbocomppro; 05-26-2017 at 05:25 PM.. |
05-26-2017, 06:30 PM | #382 |
Rep 1,343
I believe VAG cars use plastic chain guides too.
There are many engine components that are made with plastics. I think it comes down to design. |
05-27-2017, 02:24 PM | #383 | |
Rep 305
Inside the engine where heat typically degrades plastics no matter how high the grade, on a critical part that if it breaks it grenades the engine, not easily replaceable nor inspected, not cool. |
05-27-2017, 03:03 PM | #384 | ||
Rep 943
:wave:
05-28-2017, 03:40 AM | #385 | |
Rep 305
A radiator or OFH or most things outside the engine itself is considered non critical. If those break, they are inexpensive and quite easily replaceable. They certainly wouldn't grenade your engine. And you'll likely have plenty of early warnings (sudden low water level or oil/antifreeze on your driveway) to prevent being stuck on the side of the road or have a catastrophic engine failure. Sure the number of failures hasn't been insane, but the repair cost sure is. Worst is that they are lasting just outside of the warranty period so people are stuck with forking the bill or fighting an uphill battle against BMW to cover some of the costs. From what I've read on the other forums, the only warning you MAY get is a whining noise coming from the front of the engine and it changes pitch with throttle position. This is caused by slack on the timing chain. This may indicate that the tensioner is broken. |
05-28-2017, 04:03 AM | #386 | ||
Rep 943
:wave:
05-28-2017, 01:46 PM | #387 |
Rep 94
Thread scares me hearing about the plastics. I'm actually getting a burned plastic smell from my car lately. Hope it's just a plastic bag that got caught on my exhaust system.
05-29-2017, 02:52 PM | #388 | |
Rep 305
Point is, that part shouldn't be breakable that easily. It should of been made like the valves and cams and connecting rods. Under normal conditions, those parts should last the life of the engine. Thing is, it isn't even the guide itself (the part that's putting actual pressure on the chain) that's breaking. It's the supporting housing with thin plastic pieces that's breaking. I don't understand why that couldn't be made with metal other then to save cost. |
05-29-2017, 05:20 PM | #389 | |||
Rep 8
They replaced the timing chain but the drivetrain malfunction light is still on. I will go ballistic if they try to tack on another 5 grand. |
06-01-2017, 08:54 PM | #390 |
Rep 5
Mine just broke
So last Thursday while driving in town I got the Drivetrain malfunction warning, followed by the low oil pressure light. I pulled off the road and called BMW service and they had a tow truck come pick it up and take it to the dealership. Dealership is saying that the oil timing chain is "stretched" and that the oil pumped stopped working. The dealership has been helpful at this point and are working with BMW NA for resolution. He quoted me $1200 to just diagnose it, $5K to replace timing chain and pump and if it ruined the valves or cylinder walls due to no oil, could be $20k for a new engine.
I have a 2012 328i with 57,000 miles. |
06-01-2017, 09:07 PM | #391 | |
Rep 785
Keep us posted |
06-01-2017, 09:32 PM | #392 | |
Rep 943
[IMG]http://d.pr/i/AXuy+[/IMG]
:wave:
06-02-2017, 12:26 PM | #394 | ||
Rep 134
Willing to put money that this will not happen to engines made after 04/2015. Timing chain was replaced with a new part # 01/2015 and oil chain was replaced with new part # 04/2015 - meaning it took 4 years for BMW to track down and solve the problem. Both chains stretch and a service bulletin should have been issued. I have not heard of a single case on a newer car (04/2015 or newer) with this happening and believe the new chains fix the issue until I am proven wrong. Quote:
Rather than taking a $6200 jump hoping the chain alone solves it, demand an oil analysis of what came out of the car. Will tell you pretty quickly if the engine has failed. They did my timing and oil chains first then proceeded to call and tell me the engine was gone... which added more labor to the job compared to if the engine failure was properly diagnosed in the first place. |
06-18-2017, 09:17 AM | #395 |
Rep 205
Is the consensus that the B48/B58 share the same timing chain design (plastic guardrails) but with whatever improvements were made in 2015? haven't found a clear answer.
06-19-2017, 06:17 PM | #396 |
Rep 27
My Mazdaspeed6 had a bad timing chain that required replacement at 90,000 miles.
It stretched and was a known issue. Mazda did a half assed program extending warranty on it to 7 yrs /70,000 miles. First symptoms were poor idle followed by occasional hard starting. All during 4 trips to dealership where it was misdiagnosed everytime. Finally repaired by independent garage. In the end you could lift timing chain up off gears thru oil filler cap. 25,000 miles later burned a valve due to carbon buildup from poor DI design. I bought BMW F30 for drivetrain reliability my friends experienced with their BMWs. Now I'm concerned I can't afford to hang on to this car long term. |
