01-31-2019, 12:27 PM | #23 |
Rep 172
Drives: 2015 328i
Damaged keyfob could be drawing incorrect current under load which will cause incorrect voltage values under load. But 2 of us already put in new batteries and it didn't solve the issue. More like a damaged board on the remote. Strangely it has only fell 1-2 times where as my old Dodge Dart fell every other day and had no issues.
I am leaning to believe the keyfob is damaged. While it's just a minor annoyance, suggesting a battery swap is not the correct answer. I'll do some more investigation, but so far this mostly happens with comfort access and rarely when unlocking from the button. |
01-31-2019, 08:02 PM | #24 | |
Rep 209
All of that does not mean that your keyfob is not at fault. Just it seems unlikely to me that it would fail so easily. I accidently washed one of mine, kicked it down the steps, my little son got a hold of it....and its still working. Just saying , before you go the expensive route, you might want to try exact replacement battery - in my case it was Sony. On a different note, BG as in the country alakazam or am I misreading it? |
02-01-2019, 12:35 AM | #25 |
Rep 172
Drives: 2015 328i
Bulgaria, yes. I'll get an exact Sony battery at some point. But the second keyfob doesn't display the issue. Either way, working on it.
02-01-2019, 06:55 AM | #26 |
Rep 209
08-11-2019, 09:16 AM | #27 |
Rep 460
Drives: BMW 330i G20
I had the same issue. Got the warning, changed battery (took from spare fob).
Still got warning. Found other thread that stated that fob sends voltage info to car and needs 5 consecutive "ok voltage interactions" before the message disappears. So, I realized that I had probably only interacted 2-3 times when googling the problem. Went down to car, clicked lock/unlock a couple of times and then no more error message. |
desmat36.50 |
10-13-2019, 02:18 AM | #28 | |
Rep 615
Went to do some shopping and waited for the car to go to sleep. You only need around 15mins after locking. I came back and before doing anything else, I used the remote to unlock and relock the car, not with the comfort access but rather using the Keyfobs buttons. I did this 3 or 4 times. After that the problems went away. Never came back. |
10-13-2019, 06:48 AM | #29 |
Rep 6,038
This reminds me that I should see if I can get them to replace my 12v battery while I'm still under warranty and pre paid maintenance coverage for free rather then buying and registering a new battery myself. I have been using a maintainer though not consistently. Those things do work as I use one to maintain the battery on my other car and it has lasted twice as long as any battery in that car before I used a maintainer.
10-13-2019, 09:49 AM | #31 |
Just Copacetic!
178
Rep 616
My fob battery was replaced by the technician at the 2nd service, I was not having any issues with it nor did I request a replacement. Kinda was a nice surprise when I checked the service invoice and saw that the battery had been replaced. I would have brought in my other key (wife using it) had I known.
'01 X5 3.0 AlpWhite
'16 428i GC AlpWhite '19 230i MSptPkg AlpWhite |
10-13-2019, 10:35 AM | #32 |
Rep 16,140
They'll swap out the fob batteries under the service plan, they only cost a couple of dollars. They're not going to swap out the car battery for no charge unless it's dead within the warranty period for it.
10-14-2019, 06:56 AM | #33 |
Rep 6,991
Those fob batteries are pretty expensive at my dealership - they wanted $35 to swap it out. I bought a new battery for a few dollars and it didn't fix the problem despite being the exact same battery.
04-07-2024, 07:11 PM | #34 | |
Rep 1
Old battery tested (without a load, so I r ealize that only goes so far...) at 3.0V, so I thought that it was ok, but no, needed to drop in a new battery with 3.3V, no fancy brand, something from China. Leaving the car for >15 mins and trying again didn't work. Don't have Comfort access, 2014 F30, BOTH fobs were operational with new batteries. Error message stubbornly remained. Finally fixed by using fob to lock/unlock 4-5 times, then all cleared and back to normal. Thought I'd share for folks that come along afterwards. |
04-08-2024, 12:54 AM | #35 |
Running Late
89
Rep 168
I had this issue with mine for almost 2 months thinking it was a bad car battery and was on its way out. I replaced the batteries in the fobs twice and it still wouldn't go away so I gave up dealing with it.
I ended up buying a new pair of batteries from Walmart and what do you know? The error went away. I'm thinking the batteries I swapped in came from the same pack and had somehow gone bad? Make sure to replace both fob batteries.
04-10-2024, 03:40 PM | #36 |
Rep 6,991
This was several years ago, but I bought my batteries at a local grocery chain. I prefer name-brand batteries such as Duracell.
04-10-2024, 08:02 PM | #37 |
Rep 4,903
I second buying "real batteries". I have a ton of automation sensors that use that same CR2450 cell, so I was buying cheap ones off Amazon. They'd work for 6-12 months in these always on sensors, but would toss the "low battery" warning within a month on my fobs. Bought some energizers from Home Depot one day and it's been flawless for months now.
RoundelM31838.00 |
