      10-20-2013, 05:44 AM   #4841
ioschi2003
Drives: BMW X3 3.0
Originally Posted by shawnsheridan View Post
After Step 3, where you verified in the Coding Module that the VO you have loaded and activated has 4U2 and 0812 in it, did you Right-Click on HU_CIC and select Code, before checking HU_CIC => ECO_MODE?
Yes,
4U2 and 0812 was OK after a "new connection" and "read VO"
Is it necessary other coding after VO 4U2 Coding ?
HU-CIC ECO_mode nich aktiv
      10-20-2013, 05:48 AM   #4842
shawnsheridan
shawnsheridan's Avatar
Originally Posted by ioschi2003 View Post
Yes,
No. I have no idea why VO Coding isn't working for you. I give up.
No matter though, while more work, you can manually FDL Code what you need.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      10-20-2013, 09:04 AM   #4843
ioschi2003
Drives: BMW X3 3.0
Yes I coded Manually
as follow but is not possibile to flag some options ( see the pictures )
HU_CIC > 3000 HMI > ECOMODE >Aktive
HU_CIC > 3000 HMI >HVAC_MSD_EFFICIENCY >Aktive
HU_CIC > 3000 HMI >EFF_DYN_SYS_CID >Aktive
HU_CIC > 3000 HMI > ECO_FDS_POPUP>Aktive
HU_CIC > 3000 HMI > ECO_MODE_CONF>Aktive
HU_CIC > 3000 HMI > ECO_ROUTE>Aktive
HU_CIC > 3000 HMI > ECO_TIPPS>Aktive
KOMBI > 3003 FZG >VERBR_HISTORIE_ENABLE>Aktive
KOMBI > 3004 ERM > CTR_HSTY_DISP_KI_APPL >Aktive
IHKA > 3000 > ECO_PRO_MODE >aktiv
ICM ECU: 3000 -> IcmKod_B_ECONOMIC > verbaut
Could yopu help me to find the right options ?
      10-20-2013, 11:52 AM   #4844
shawnsheridan
No. I would need you car, or another F25 to play with. As I wrote in my F10 case, it never would work 100%. Your car may be the same.
      10-20-2013, 12:01 PM   #4845
legaleye3000
Drives: 2014 328i; 2015 X3
I must have the wrong info...
Can someone tell me where to code for pushing "lock" on your fob and the mirrors automatically fold in? Not holding the "lock" button, just a quick push.
Thanks.
      10-20-2013, 12:13 PM   #4846
shawnsheridan
Thanks.
There is no such thing. You would have to code KMFRT_SCHLIESSEN = Werte 00 to make the folding near instant.
      10-20-2013, 12:19 PM   #4847
legaleye3000
That must be it because I did it awhile ago but then the dealer just performed an upgrade and I lost everything.
Can you remind me where that is located? FEMBody? Which # (i.e. 3110)? Thanks.
      10-20-2013, 12:27 PM   #4848
shawnsheridan
CAS module on F10, and FEM_BODY on F30.
      10-20-2013, 01:35 PM   #4849
Rasengan
Drives: 2014 BMW 428i M Sport
Hey guys,
A few questions:
- I'm supposed to have a free year of satellite radio but I do not see Satellite under Radio at all or anywhere in the menus. Is that something I need to code in or bring into the dealership?
- I also have the snap-in adapter (iPhone 4 Media version with the fan) and am trying to watch a video but I do not see the option for "Video" under External Devices > SnapIn Adapter. Does that (menu option) also need to be coded in?
- Is there a way to have the folding mirrors fold automatically when you either lock the doors or turn the car off? I have coded it to where you can hold the lock button down on the remote (werte = 00). I was wondering if there was a completely automatic way to fold in every time.
      10-20-2013, 01:42 PM   #4850
shawnsheridan
Originally Posted by Rasengan View Post
Hey guys,
A few questions:
1) Does car have have option 655 or 693?
2) Does car have option 6NR?
3) No.
* Check car options at http://www.bmwvin.com/ if you don't know.
      10-20-2013, 02:03 PM   #4851
ioschi2003
Drives: BMW X3 3.0
Probably the problem is here,
could you check your options & Value for :
3003 ECO_FDS, 3C
FDS_MENU_TEXT"n" & FDS_MENU_SIGNAL"n"
Thanks
      10-20-2013, 02:08 PM   #4852
shawnsheridan
3003 ECO_FDS, 3C
Thanks
My car is not a good example. When I could not get it to work 100%, I uncoded it all. I don't have any ECO Pro Coding anymore.
You need to compare your car to a car with working ECO Pro from the factory.
      10-20-2013, 02:22 PM   #4853
ioschi2003
Drives: BMW X3 3.0
you are right,
Anybody in the forum has X3 F25 with ECO PRO function from the factory ?
      10-20-2013, 02:25 PM   #4854
shawnsheridan
you are right,
You should ask that here, which is basically this same type thread for F25 owners, happening on x3.xbimmers.com:
http://x3.xbimmers.com/forums/showthread.php?t=715297
      10-20-2013, 02:50 PM   #4855
ioschi2003
Drives: BMW X3 3.0
ok thanks I'm going to do it immediately ....
http://x3.xbimmers.com/forums/showth...7#post14842767
      10-20-2013, 07:18 PM   #4856
Rasengan
3) No.
I've never had luck with that site, it can't find my VIN. I had to use this one to get my car details:
http://www.bmwarchiv.de/vin/bmw-vin-decoder.html
I do have these listed:
- S693A
Vorbereitung BMW Satellitenradio Preparation BMW satellite radio
- S6NRA
Apps Apps
      10-20-2013, 07:58 PM   #4857
shawnsheridan
- S693A
- S6NRA
Apps Apps
693 is Sat Radio Preparation and 655 is Sat Radio. If you are supposed have Sat Radio, then the dealer needs to enable it your car, which would be to chnage 693 to 655, and add the FDC Enabling Code and program the car.
You should have Video function if you have 6NR. I am not sure if there is a "Video" menu option though, or if you just select Plugin, and it plays automatically if you start a video. The device must be in the Snap-In Cradle and not connected to the Center armrest USB Port for video to work.
      10-20-2013, 08:06 PM   #4858
Rasengan
Oh is that how it works? I thought maybe there was a menu you could select and it would list folder contents of playable videos. I never tried just playing a video. I did try playing a video podcast but it does not play video, just the audio from the podcast
      10-20-2013, 08:10 PM   #4859
shawnsheridan
I don't have 6NF Base Plate so I can't say for sure. Someone with factory 6NF and 6NR needs to chime in an confirm.
      10-21-2013, 08:45 AM   #4860
kon
Singapore
Drives: F30 310i > G20 310i
Saw some 'commercial' coder manage to activate Asian font for CIC for F10, anyone know how this is done in F10?
      10-21-2013, 10:43 AM   #4861
Rasengan
ouch...this comes from my CA:
For 2014 Navigation Pro/iDrive 4.2:
Smartphone Integration
This gives the customer the ability to connect their phone to the vehicle using the optional snap-in adaptor (sold separately) and conveniently store it out of sight, while still making/receiving calls and listening to music from their phone. In combination with the suitable snap-in adaptor, the phone is connected to the external antenna of the vehicle to increase reception.
Please note, PlugIn and Video Playback are no longer available through the snap-in adaptor.
surely there must be a way to re-enable PlugIn and Video through code?
      10-21-2013, 11:40 AM   #4862
gnuke
Drives: 2012 328
Hi Shawn,
Sorry to add to the never ending list of peeps in need, but can I get a link to the latest and greatest versions/lists/etc.
Thanks for everything you've contributed,
G
