10-19-2018, 10:34 AM | #1 |
Rep 242
Drives: 2013 328i 6mt
CNT catless downpipe? Installed! Please read
Any one here have any experience with CNT downpipes? Anyone running one with the stock exhaust? TIA
F30 328i 6mt
Injen, ER, BM3, Solowerks, IND, BMS, BBS E46 M3 smg2 Bimmerworld, H |
10-24-2018, 11:25 AM | #2 | |
Rep 1,397
Anyone? |
rackjuediger143.00 |
10-24-2018, 11:42 AM | #3 |
Rep 5,458
Drives: F30
Why anyone would choose anything other than the Circuit Werks catless DP is beyond me.
Catless Downpipe: A hollow pipe. Damn near zero engineering going on. It either fits or it doesnt. Find the cheapest one with solid build quality and move on. |
FastActionJax407.00 |
10-24-2018, 11:48 AM | #4 |
Rep 3,680
There are other elements, like some offering like a heat controlling coating and things like that, but for the most part, +1. If it's made well and fits, cheaper is better.
10-24-2018, 01:23 PM | #5 |
Big Turbo Boys N Girls
327
Rep 579
I have installed PLM, Circuit Works, VRSF, off brand ebay, and ER pipes for this platform. Pipe is a pipe. Just use new gaskets and you wont have leaks. Get one with the Flex joint at the bottom. If you have issues get a refund and get another brand. There is always some failure rate on mass produced parts.
2012 F30: G25-660 Bottom Mount Mani+ DP+ Intake, CSF FMIC, VRSF CP, Walbro 450 LPFP, PR Injection with AIC 4, S63TU Injectors, Tuned with BM3, ZF Race 4 Puck and Non SSA Pressure plate, Catless, 3.5" Quad Muffler, Custom Valved Bilstein B8 + H&R SS. Max 456 WHP - 452 WTRQ. Currently tuned down to 434 WHP and 362 WTRQ to save the rods.
10-24-2018, 01:26 PM | #6 |
Rep 242
I ordered CNT on Monday. It will be installed Tuesday so I will keep everyone posted. Are new gaskets required? Where can i order them from?
F30 328i 6mt
10-24-2018, 02:14 PM | #7 |
Rep 3,680
This thread goes through what parts you should have on hand during a DP install.
10-24-2018, 03:59 PM | #8 | |
Rep 5,458
Drives: F30
I use getBMWparts.com for pretty much all of my OEM parts purchases. Assuming you have an N26 ? You will need the following three parts: 18307606136 (DP to turbo clamp) 18307628660 (DP to turbo gasket) 18307628660 (DP to mid pipe clamp) I have the bolded item available for sale brand new if your interested. Will ship immediately. $18 via paypal, shipped. |
10-24-2018, 04:00 PM | #9 | ||
Rep 242
F30 328i 6mt
10-24-2018, 04:11 PM | #10 | ||
Rep 60
10-24-2018, 06:18 PM | #11 | |||
Rep 5,458
Drives: F30
Its the other clamp that's different. Let me know if you find it cheaper! |
10-24-2018, 07:18 PM | #12 |
Rep 3,680
Forgot to link this thread:https://f30.bimmerpost.com/forums/sh....php?t=1541854 in my above post lol. But sspade got it for me anyway. Those three parts should be on hand, and since you're N20 the DP to MP clamp will be different. Just go to realoem.com, get the PN and go to your dealer for all three parts. I got all three for like $60 from my dealer.
10-24-2018, 07:37 PM | #13 | |
Rep 5,458
Drives: F30
getbmwparts.com always beats them. |
10-25-2018, 07:13 PM | #14 |
Rep 191,143
Good luck OP
10-30-2018, 10:33 AM | #15 |
Rep 242
Update: I just went to my local dealership and picked up everything I need for $80. Not bad for getting everything the same day and not having to wait a week for the parts. The downpipe will be getting installed tonight.
F30 328i 6mt
10-30-2018, 10:39 AM | #16 | |
Rep 5,458
Drives: F30
Out of curiosity - do the part numbers match up with what was suggested? Will help others who use this post as a guideline for their own DIY. |
10-30-2018, 11:44 AM | #17 | ||
Rep 242
F30 328i 6mt
10-31-2018, 03:15 PM | #18 |
Rep 242
Update 2 Downpipe Installed!
Took about 2-3 hours but I got it done! The biggest issue was fitment however. I cut 8 quarter inch slices into the midpipe connection and lightly pressed in to fit the downpipe into the midpipe. I don't know if CNT suggested it be welded instead since the downpipe exit was the same size as the midpipe. I wish I took photos but completely forgot. Performance wise the car absolutely rocks. Pulls harder than before and has some nice pops and burbles when letting off at low rpm. Ended up not needing the gasket and clamp I bought from my local dealership since the original ones were in great shape. Theres no exhaust leaks and the turbo fitting fits perfectly I should add. And I plugged In the top o2 sensor as well.
F30 328i 6mt
10-31-2018, 09:20 PM | #19 | |
2095
Rep 43,350
fiveohwblow3633.00 |
10-31-2018, 09:24 PM | #20 |
Rep 5,458
Drives: F30
Circuit Werks N20/N26 downpipes on eBay for $160, shipped.
Guaranteed to fit. Why pay more for a hollow pipe? |
10-31-2018, 09:29 PM | #21 | |
Rep 3,680
Either way, happy to hear that. Hopefully the trend continues
10-31-2018, 11:17 PM | #22 | ||
2095
Rep 43,350
The N20 downpipe is the WIDEST and one of the longest downpipes BMW has designed and it only takes a single millimeter or two in any direction to turn a downpipe into a door stop. Quote:
Our jigs have been significantly improved (reinforcement, CNC fittings to simulate OEM connections) which guarantees relative flange angles as well as flange dimensions. Before a N20 DP or CP sees the inside of a VRSF box, each and every unit is fitted to two separate jigs. Afterward, they are manually measured and inspected by a separate VRSF employee. If they pass we then use a 3d scanner on a few units as well as the jig to ensure it's within spec. If for ANY reason the part doesn't pass any of these steps it's scrapped. The verification/QC step takes a bit longer now than it used to but improving upon the process has vastly improved quality and has significantly decreased our defect rate across the board. I'm really appreciative of the feedback we've received from the community thus far, without it we wouldn't have been able to improve and expand our lineup. |
