01-27-2022, 12:39 AM | #1 |
Rep 394
Do you clay bar, then wax, then apply ceramic coating?
Hello
My car is a black 2014 328i, pain is in good condition, but i have a lot of water marks, and im looking to clay bar it, and hope the water stains go away, then i want to wax it by hand, i bought the wax butter, and i was thinking, can i then apply the ceramic coating? This is my first time for all these 3 things. my goal is to have a shiny as possible car without watermarks and possible minor scratches waxed away by hand. Is the clay bar, wax, then ceramic the correct order? or some of those dont mix? Thanks all! |
01-27-2022, 08:14 AM | #3 |
Rep 16,184
IMO none of the above. Depending on how much correction is needed I buff with Menzerna polishes, Steps 1, 2 and 3 (Step 1 for serious spider webbing) and finish it off with Jescar Power Lock. If you were to use ceramic it would go on in place of the Power Lock. Wax is fine...on linoleum.
01-27-2022, 12:44 PM | #4 |
Rep 3,902
A few things:
- Watermarks will most likely not disappear with a clay bar. Clay bar has a different purpose - to remove particles which are stuck on the clear-coat. Try chemical products for water marks (E.g. chemical guys have such a product, never tried it myself though: https://www.chemicalguys.com/heavy-d...t-remover.html). If that doesn't work - polishing / buffing is the way to go - Waxing is a good idea once you clean the clear-coat of watermarks / dirt / particles - Ceramic coat is also a good idea, but you don't put ceramic coat on top of wax the same way you don't put mayonnaise on top of butter! It is either, or! Research and inform yourself about the Pros and Cons before selecting. Both have advantages and disadvantages. Very top-level sequence: 1. Pre-wash 2. Thorough wash 3. Clean surface (tar removal, ironX, IPA, clay bar - any or all of those, depending on the clear-coat condition and how thorough you want to be) 4. Buffing/Polishing - optional, depending on clear-coat condition. 5. Wax / Sealant / Ceramic coating - depending on the desired outcome, all 3 have advantages and disadvantages. But it is any of the 3, never more
01-29-2022, 11:56 PM | #5 |
Great Teacher
1138
Rep 1,319
Drives: 06 e91 325ix
I use the chemical guys stuff on my glass shower door to take out HARD water spots, it is a gel so easier to apply than that other standby… vinegar.
Mostly what you geton a car though would come right out with any of the speed wax products. I used to use meguirs, and now I use chemical guys. Prefered the meguirs.
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
01-30-2022, 03:01 AM | #6 |
Rep 3,902
Vinegar solution is a well known method for removing water stains in the bathroom. Wouldn't use it on a car clearcoat though.
01-30-2022, 02:40 PM | #7 |
Rep 113
I would say the only true way to get water spots removed would be to polish as they are usually ettched in the cars clear coat or ceramic. You are on the right track with clay bar. As a paint prep.
If it it was me. I would 1Decon wash the car 2 iron/ tar remove 3 clay bar 4 polish 5 protect with ceramic or wax got to pick one as these don't mix well think oil and water Now if your worried about etching in the future from hard water or rain I would recommend wax as it's easier to deal with a good combo is jecar power lock topped with colinite 845. You can always top up the wax after every wash if you want completely up to you though. |
03-23-2022, 03:12 AM | #8 |
Great Teacher
1138
Rep 1,319
As indicated above, Never clay bar bar (ie scratch up) your paint unless you are go)g to polish it (ie remove paint) to flatten it back out,p and get rid of the scratches you put in it after. keep in mind also you only have a limited number of polishes and such before your clear is too thin so don’t be one of those people that clays and polishes every other weekend.
Yes a ceramic coat goes on before wax. The wax protects the ceramic and the paint underneath, other wise you are ceramic coating your 2-4 week lasting wax job not your decade lasting paint.
08-04-2022, 11:17 AM | #9 | |
Rep 46
New F31 owner here. Black over black, and it has tons of water spots from the previous owner. If I'm going to spend an entire weekend with "wax on" and "wax off" exercises, I wanna make sure that I get it right the first time. Thanks! |
08-04-2022, 03:32 PM | #10 |
Great Teacher
1138
Rep 1,319
Megs speed shine (blue color) worked great with less product than the CG… but is now apparently defunct. So I use CG (pink color) instead.
CincyBearcats30.50 |
09-01-2022, 12:10 PM | #11 |
Rep 46
Thanks!
Thanks to everyone for the advice here and on other similar threads. In particular, a big thanks to Billfitz! His recommendation of Menzerna products got me on the right track.
I just purchased a 2017 F31 in sapphire metallic. The previous owner had completely neglected the paint. It was covered in swirl marks, deep scratches, rock chips, and various blemishes. I was able to remove 95% of the swirl marks, 90% of the scratches, and 100% of the blemishes. While not perfect, it looks WAY better than it did a week ago. The metal roof and sunroof glass are now nearly indistinguishable! From a few feet away, the entire car looks like a black mirror. I ended up going pretty deep down the detailing rabbit hole. If you care to come along, here are the steps that I took:
09-03-2022, 10:34 PM | #12 | |
Rep 906
Above is a pretty good procedure, but if you're going the ceramic route, the deviations start after Step 15. You'd need to decon with alcohol one last time prior to applying the coat per manufacturer's procedure.
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, M-Sport Pkg
2020 i3 Rex: Capparis White, Giga World |
09-12-2022, 01:37 PM | #13 | |
Rep 46
Regarding the additional alcohol decontamination step, why is that necessary? I did alcohol decontamination after the last polishing step. I then washed with Simple Green to remove the polish dust that had remained in the various cracks and seams. Would the residue from the Simple Green and rinse water really have that much of an effect on clear coat that had already been decontaminated? |
09-14-2022, 12:06 AM | #14 | |
Rep 906
09-14-2022, 08:56 AM | #15 | |
Rep 46
09-23-2022, 04:50 AM | #16 |
¯\_(ツ)_/¯
950
Rep 1,763
Jescar Powerlock Plus is amazing, been using it for years. I apply it three times a year (before winter, after winter when it warms up and sometime around June as a refresher)
Billfitz8296.50 |
09-24-2022, 08:31 PM | #17 | |
Rep 2,219
https://www.youtube.com/watch?v=LdWN...6AutoDetailing
