04-19-2024, 08:27 AM | #1 |
Rep 9
Help, no crank no start only click
Hi everyone. For a long time I had a dying battery that I attributed to cold weather. Finally got it changed and a week later died again. Realized there was a parasitic drain somewhere so I started disconnecting the negative terminal when not driving. Couple days ago I gave my car a good full throttle and it was crapped out, started flashing drivetrain malfunction. Made it home and shut off the car, when I started it again no start or crank showing starter malfunction and drivetrain malfunction. Although I don’t believe it’s a starter problem. Any ideas?
04-19-2024, 11:36 AM | #2 |
///M
180
Rep 671
Drives: '18 F80 M3 ZCP, '14 F30 328i
What code(s) do you read?
F80 ///M3 2018 / ZCP / executive / 6-speed / nav
F30 328i 2014 / dinan sport kit / premium pkg / 6-speed / nav / hex trim / HK sound / B14 coilovers / oem roof rack / active autowerke exhaust / eventuri CAI |
04-20-2024, 05:36 AM | #3 |
Rep 1,699
Drives: 2014 428i and 2018 X5
Did you register the new battery after you installed it?
Does your code reader offer any clues?
___________________ 2014 F32 428i M-Sport 2018 F15 M-Sport |
04-20-2024, 07:14 AM | #4 | |
BMW CCA 69606
86
Rep 227
Has any work on lubrication system, like OFHG or oil cooler, been performed? Put battery on charger Put socket on front crankshaft pulley bolt and confirm engine can be turned over. Only turn CW, not CCW, from front. |
04-20-2024, 11:01 PM | #6 |
Rep 9
Also, I had the code come up about a few days before the no crank, even with that code the car was running perfectly fine in terms of no bad idle or anything
04-23-2024, 12:56 PM | #10 |
Rep 38
Could possibly be dealing with a seized motor. What engine do you have? Also have you done any maintenance like oil leak repairs or anything recently?
