BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Engine oil for track use
European Auto Source
      05-05-2016, 12:00 PM   #1
lijiahua790
lijiahua790's Avatar
Drives: 2012 328i n20
Smile Engine oil for track use
Hey, guys, I just got my N20 back with a new motor. After all, I am glad!
Lesson learnt, which is not to use piggyback tunes.
Anyway, here is my concern, my BMW master technician at EMW, who fixed my blew engine in as less as 1 week, recommended me to use 10W40 instead of factory 5w30, and add Archoil friction modifier.
Any suggestion from you guys?
JB4, Evolutionracewerk IC, Evolutionracewerk CP, Evolutionracewek Catless downpipe, AEPX ARC-8, AG M510, APEX stud conversion, Remus Catback exhaust, P3cars gauge, Trinity Autosport.
(Exercise? I thought you said extra fries!)
      05-05-2016, 01:34 PM   #2
roundel335
roundel335's Avatar
Drives: 13 335i Sedan, 16 228i Cabrio
Best to stick with factory recommendations on oil. Failure to do so may complicate future warranty claims relating to the engine and its components. If you go racing and spend long periods running the car hard, then all bets are off anyway. Things break when pushed hard enough, and it's doubtful that the wrong viscosity of oil or any additives could cause or prevent internal component wear. Lack of sufficient lubrication would definitely be a big factor, though.
Interesting to note that the M engines have a different oil viscosity recommendation (something like 10W60), but those are entirely different animals that were meant to be run hard from the get-go.
2013 F30 335i M-Sport 8AT/MPE/MPPK/JB+, 2016 228i M-Sport Cabrio 8AT
      05-05-2016, 01:39 PM   #3
Polo08816
Drives: 2014 335i M Sport
This. Oil starvation will definitely cause your engine to fail.
BMW provides a range of acceptable oil viscosity/weights. Use something that is approved within that range.
I have been using the Mobil1 0w-40. I believe it's no longer BMW LL-1 certified and I'll probably switch to something that is still certified once my inventory at home is depleted.
      05-05-2016, 01:40 PM   #4
lijiahua790
I have just ordered 5W40, guess will be the best choice for now, higher viscosity and recommended in the service manual! I chose ROYAL purple, which has the best viscosity index in the class. Thanks for the reply, appreciated
      05-05-2016, 02:14 PM   #5
Polo08816
Personally, I think any BMW LL-01 oil would suffice.
The Castrol EDGE 5w-40 and M1 0w-40 are ~$27/5 quarts at Walmart.
I also change my oil on a 5,000 mile interval if it has been used at the track. I'll change at the 7,500 mile interval if it has not seen track use.
* I know M1 0w-40 is no longer BMW LL-01 certified.
      05-05-2016, 02:23 PM   #6
nicknaz
nicknaz's Avatar
Drives: E84 X135
No issues here using factory fill 5w30 in my s55
I wouldn't mess with non LL01 oil, personally
Either the oem 5w30 or 0w40 for me.
10w60 was for the previous non turbo motors
Btw when I was in non bmw world, shell rosella t 10w40 or synthetic 5w40 was really interesting (but I wouldn't use those for my bmw)
      05-05-2016, 10:13 PM   #7
eluded
2JZ-GTE
eluded's Avatar
Bulgaria
994
Drives: 340 6MT
glad to hear you have your car back!
      05-06-2016, 06:17 AM   #8
cncmastr
cncmastr's Avatar
Drives: E30, E46 M3, E53, E39, F31
Send a message via AIM to cncmastr
Do you get oil analysis performed on your oil that dictates 5000 mile limits? It's your car so do what you want. I ask because I've been doing Blackstone analysis for 4 years now on 4 different bmws and I'm finding the oil lasts close to 10k before it needs to changed. There are still plenty of additives at that change. For me I'm doing 8-9k oil changes.
      05-06-2016, 06:33 AM   #9
Polo08816
No, I have not. I have just done them at 5k until recently because it was the mid-way point between the BMW maintenance plan service intervals.
It sounds like you have. Does the 10k limit include track usage?
      05-06-2016, 06:38 AM   #10
cncmastr
cncmastr's Avatar
Track usage no, I change it sooner for the S54 and M42 motors if I tracked the car, usually after the season.
      05-06-2016, 08:28 AM   #11
Polo08816
I've had my car for 1 year and 11 months and have put almost 58,000 miles on it.
This usually causes me to change it pretty frequently (date-wise) relative to most.
      05-06-2016, 02:54 PM   #12
lijiahua790
Hahaha thanks bro
      05-06-2016, 08:52 PM   #13
XKxRome0ox
e90noob
Drives: '08 E90 M3
i was going to say .. but you already qualified your statement
the container on the left includes BMW
the one on the right does not
i guess Mobile-1 changed the formula or something so it is no longer BMW LL-01 certified
2008 E90 M3
      05-06-2016, 08:53 PM   #14
XKxRome0ox
e90noob
Drives: '08 E90 M3
so what went wrong in the old engine?
2008 E90 M3
      05-06-2016, 10:22 PM   #15
WHL102
Drives: '16 GTI S, DSG, 4-Door
Going a bit off topic.
How quickly does it take for a mfg. to certify a new formula?
I guess the question is did it fail certification or is just not certified YET? Sorry if this is a stupid question, not really sure how it all works.
      05-06-2016, 10:24 PM   #16
Polo08816
Yes, that's basically what we saw at the local Walmart.
      05-07-2016, 11:03 AM   #17
tifosielia
Drives: E46 M3 comp, m2 comp on order
SMH. There's so much to said here but I don't have time.
1. With the OP there's zero problem running 10w-40, actually for spirited driving it's better. Only downside would be if you live in a cold climate (slightly too thick at startup) and ever so slightly worse fuel economy. With high oil temps it will protect better... And yes there will be a protection difference at operating oil temps.
2. LL-01 is not some high standard it's primary focus is fuel efficiency and longer change intervals. There are far better formulas. For one it doesn't have enough zinc for a stressed turbo (tuned). For high performance applications don't feel tied to it.
3. Royal Purple has some of the junkiest additives in that class. Everyone who knows there stuff steers clear of it.
4. If your going to track grab motul xcess 8100.... Don't be cheap. There several other oils... One by amsoil but it escapes me.
      05-07-2016, 11:06 AM   #18
tifosielia
New standard is LL04 it probably hasn't passed yet.
      05-08-2016, 11:57 AM   #19
BEAR-AvHistory
2018 440M-Sport MPPSK/THP
BEAR-AvHistory's Avatar
388
Drives: 2018 440M-Sport MPPSK/THP
Just a thought. If anyone decides to use a pure race engine oil be sure to change it back to quality street car oil. The race oil does not have suitable additives for long term street use.
Kevin
2018 440M-Sport MPPSK/THP - 2017 CX-5 - 2016 Genesis R-Spec Coupe 6MT - 2013 135is Cab 6MT/JB4 - 2009 V-Star - 2009 Expedition 4X4 - 1998 Ranger 4X4 5MT - 1965 Cobra MK-IV 5MT BUILD LOG
      05-08-2016, 08:47 PM   #20
glennQNYC
glennQNYC's Avatar
Drives: M Sport 335i
2014 335i  [4.83]
I learned this lesson back when I tracked my old '94 Honda Civic. Adhering to anything close to heavy use OEM service schedules while running race transmission oil in that car resulted in a blown trans.
      05-09-2016, 11:01 AM   #21
lijiahua790
Hahaha I just got royal purple 5W40, actually thinking of 10w40 for the next oil change, but I'm concerning the heavy load on the oil pump and potentially cause it to fail
      05-09-2016, 12:08 PM   #22
Polo08816
The higher the viscosity the better the protection.
There are plenty of people running gear oil to get maximum lubrication. Something like an 80w-250 will ensure your engine will get to 1,000,000 miles.
If you're running an N20 with a tune, downpipe, etc. you should consider this.
10w40, 5w30, engine oil, f30, n20
