06-04-2014, 07:47 AM | #1 |
Pace Car Driver
1547
Rep 3,164
OEM M3/4 19" 437M Black
Any reason to think these wont fit an F32? Of course they will right?
I'm really an OEM / OEM + kinda guy and would REALLY like the black on our soon to be ordered Alpine White. I guess the bigger question is .... any way to order the car from the factory with these wheels? I highly doubt it but maybe someone knows the trick? Of course I could always purchase some new M3/4 owners "take-off" wheels that will soon be hitting the streets. Last edited by G30 B58; 06-04-2014 at 01:07 PM.. |
06-04-2014, 10:26 PM | #2 |
Rep 1,728
The fronts seem a bit more aggressive than the rears but you may be able to pull it off. I'm not sure though. I am running 19x9.5 ET35 in the rear with 265/35/19 Michelin PSS and I feel like it is just perfect.
'11 Space Grey E92 335xi M-Sport (KWv1 Coils | Saddle Brown | Bamboo) (Returned)
'14 Mineral Grey F32 335i M-Sport (Dinan DHP | LED Lights | Coral Red | Hexagonal Aluminum) (Returned) '16 Mineral Grey F80 M3 ZCP |
06-04-2014, 11:55 PM | #3 |
Rep 5,140
The wheels should fit also on F32, not sure that OEM M3/M4 tire sizes will work though.
OEM style 437 for M3/M4: F: 9x19" ET29, 255/35-19 R: 10x19" ET40, 275/35-19 I think the rear will fit fine since F32 seems to handle a bit more aggressive offsets than F30. I'm more concerned about the front, not many has fit 255 tires up front yet especially not with as low offset as 29. Maybe 245/35-19 front and 275/30-19 rear, slightly shorter than OEM tires for F30/F32 but the probability that you avoids rubbing with this setup is much higher. |
06-07-2014, 08:46 AM | #4 |
Rep 140
This guy appears to have done it: http://f30.bimmerpost.com/forums/sho...d.php?t=992173
06-08-2014, 06:58 AM | #5 | |
Pace Car Driver
1547
Rep 3,164
Sadly those are 20's .......... which means they are not M3/4 wheels. |
06-08-2014, 08:31 AM | #6 |
Rep 140
06-08-2014, 09:14 AM | #7 |
Pace Car Driver
1547
Rep 3,164
My brother will acquire his M4 just a couple of weeks before we get our 435. He visits all the time so swapping at least one side of his wheels onto our car will happen at some point.
06-23-2014, 07:49 PM | #8 | |
Rep 140
06-24-2014, 12:32 AM | #9 | |
Rep 5,140
It's also possible to add some negative camber at the rear, but the front is harder. 9" wide front wheels usually has offset 32-35 on F30, so the 373 wheels are a bit more aggressive with 29. The wheel lips will be outside the fenders (at least if not lowered), and it's up to personal taste if you like that or not. |
06-24-2014, 06:54 AM | #10 |
Rep 4,323
These are a more aggressive style than the stock 400m's no?
I wonder what their weight is...
06-01-2015, 05:51 PM | #12 |
Rep 260
