08-27-2012, 02:13 PM | #1 |
Rep 244
All Season Wheel Tire Combo
Decided to get the Enkei Racing PF01 rims (18.2 lbs/35mm offset) with the Bridgestone Potenza RE970AS Pole Position (Ultra High Performance All-Season 28 lbs) tires for this winter (46.2 lbs/wheel). Square 18x8 225/45R18 91W. As this is a regular tire and not a RFT, my plan is to carry a small compressor, slime plug kit, and a jack kit in the trunk to fix flats. I have a compressor and plug kit readily available. I'm somewhat at a loss for a small jack kit that will fit the F30.
Does anyone have any experience/recommendations on where I can find a compact jack kit that will fit the F30 and is reasonably priced? On another note, I recently saw a 2012 Porsche Carrera S promotional video clip and it had wheels very similar in design to the Enkei Racing PF01. At first, I wasn't too certain how it would look on the bimmer. But after seeing it on the Porsche, I'm now very optimistic that it will enhance the overall sports appeal on the bimmer. The wheels were delivered with the TPM, tires installed, and balanced. Just waiting for the weather to cool down before making the swap from summer tires. It will be interesting to check the weight of the OEM wheel/tire combination. |
08-27-2012, 04:35 PM | #3 |
Rep 244
I might get 7-10 days of actual snow driving per winter. When it does snow, the roads are plowed and salted almost over night. Winters are mostly driving in cold dry surface. Between xDrive and cold weather driving with limited exposure to snow, the all weather should get me through the winter just fine.
08-29-2012, 02:20 PM | #4 | |
467
Rep 4,592
I'll take a BMW with RWD and Snow tires over one with X-Drive and All seasons any day of the week. |
08-29-2012, 02:29 PM | #5 |
Rep 4,721
I had driven awd cars & suv in the past with just stock tires (so called all season), I can tell you it's one hell of a scary drive, esp. having the feeling of the tire slipping and not able to stop when you really want to stop.
That's why I rather pay to be safe than sorry. Just my 2 cents. |
08-29-2012, 03:39 PM | #6 | |
Rep 28
Your choice my friend, but you'll never see me on all seasons in the winter. Cheers
2012 BMW 335i Sedan Sport Line, Mineral Grey Metallic, 35% tint, premium package, sport suspension |
09-02-2012, 02:18 PM | #7 |
Jacko
Rep 8
Drives: 2012 335i Sport line
I've had winter tires slide on icy roads the same way as a all season or summer tire. If the road is covered with black ice nothing works. Having x drive is better than just rear wheel drive because if you do slide of the road your chances of recovering your car and getting back on the road heading the way you want to go are better.
(I'll take a BMW with RWD and Snow tires over one with X-Drive and All seasons any day of the week.) RIGHT! Rich@GTB .That really makes sense. But, it depends on the person and what he really believes until he finds out different. Move to Fairbanks Alaska and say that. |
09-03-2012, 07:21 AM | #8 |
Rep 244
Wife has a 2002 RX300 with AWD and AS tires. During inclement weather when most RWD cars are slipping and sliding all over the road, the RX300 will handle and drive like a dream. Have occasionally taken it out to test the limits of adhesion when the roads were packed with snow and the local authorities are encouraging everyone to stay home. It reinforces my sense of security knowing that I have to push the driving limits fairly hard before reaching the threshold of control. The threshold is so far above normal driving habits that snow pack roads during inclement weather is not even an issue.
Seems to me that I get the best of both worlds driving in snow or hard dry asphalt in 10 degree weather. You guys drive what you want. More power to you. As for me, I'm perfectly content with AWD and UHP AS tires. |
10-06-2012, 01:39 PM | #9 |
Rep 244
Installed the A/S tires early. Summer tires definitely have the softer/smoother gliding on ice affect. Noticed a bit more road roar coming through in the A/S tires. The A/S wheel time combo is so much lighter then the OEM wheels its amazing. Hard to notice any difference between summer and A/S tires. Will Probably need to push the limits of adhesion on a test track to really sense any difference between the two tires. Seems the wheels are designed to show rotors and calipers when driven. Very pleased with the initial results.
10-07-2012, 07:59 AM | #10 | |
Rep 397
Drives: 11 E90 M3 ZCP
Or is this wheel/tire combo supposed to be used all year long? |
10-07-2012, 09:06 AM | #11 | |
Rep 821
Why do so many forget that a/s tires harden in the cold. Your dry pavement grip is compromised even without snow and ice on the ground. Not to mention the OP got "ultra high performance" all seasons; which means they are pretty close to summer tires. If you're spending the money already on extra rims and tires, it doesn't make any sense. The extra foot or two of braking distance may mean the difference between crashing or driving away. |
10-07-2012, 09:11 AM | #12 |
Rep 300
A/S tires have more grip on dry pavement than winter tires. Why'd you think otherwise is interesting. Heavily siped tread blocks "squirm" like crazy making predictable handling much harder.
I'm speaking from experience and also from asking this direct question of Tire Rack this week, as I shop for a similar set.
| '13 328i M Sport - Estoril Blue | '12 300C SRT8 | '12 Wrangler Rubi Unlimited - COD MW3 Edition|
10-07-2012, 12:17 PM | #13 | |
Rep 244
10-07-2012, 09:13 PM | #14 | |
Rep 821
10-07-2012, 09:15 PM | #15 | |
Rep 821
10-07-2012, 09:19 PM | #16 |
Rep 300
you mean dry doesn't mean freezing? get out!
10-07-2012, 10:50 PM | #18 | |
BMW 4 Life...
149
Rep 3,360
Exactly the reason why I went with a dedicated set for summer and now a set for winter.
