10-20-2014, 08:47 AM | #178 |
Rep 713
Both are studded tires and not permitted in Ontario if you are looking for normal road tire. Nokian does have a great non studded tire in the Hakkapeliitta R2. I had the previous gen and found it to be a great tire and heard these are an improvement over them. Getting mine installed tomorrow.
10-22-2014, 10:51 PM | #179 |
Rep 6
studs optional
Hi I was at the tire place yesterday , you can get the hakka8 without the studs.
I have hakka7 s on my other car . you are correct no studs in ontario but in quebec it is ok between certain dates. i am plated in ontario so no studs for me , with a lot of highway its too noisy with studs. I am wondering about size , I would like the narrowest tire that will fit on a 335ix with m brakes , all is see is 225 /45 18 for now but am wondering if there is anything narrower that will fit |
10-23-2014, 06:16 PM | #180 |
Rep 145
Hi, I'm looking at getting Hakka R2 mounted on steel rims. BMW only sells mags but they gave me the right specs:
7,5 Jx 17 ET 37 M14 x 1,25 Bolt Pattern Please I need advice: If I have the Hakkas mounted on the regular steel rims, anything to be aware regarding the tyre pressure sensor or whatnot? Thanks!
2018 X3 30i / Alpine White
10-23-2014, 09:06 PM | #182 | |
Rep 145
Cannot find the part available in Canada or US I'm afraid. I will give it to the dealer parts section and see if they would get it (probably not since they don't want to sell it here....).
10-24-2014, 11:08 AM | #183 |
Rep 76
Looking for decent winter rims. You guys on the East coast know anything about http://replikawheels.ca/ ? Thanks!
10-24-2014, 08:47 PM | #185 | |
Rep 4,721
Cdn company established by Fast wheels. Braelin is another name Fast wheels created as well.
Quality is questionable at best and don't expect them to last too long. They are normally made in China, gravity cast wheels. Some say the finish may last only a year or two due to salt and winter debris. It looks like the wheels are made in China and then they are shipped to Canada for final machine drilling (bolt pattern) for the various needs for different cars, thus claiming the wheels are made in Canada. Quote:
10-25-2014, 08:13 AM | #186 | |
Rep 145
I managed to get a set of the OEM BMW ones you told me on eBay.de for $485.53 CAD including DHL shipping to Ottawa. And got the Hakkas R2 16'' FR for $206 each vs the 17'' at $269 each (Tiresbyweb.com). Question: Would I need to ad any type of sensors or special valves to make them readable by the tire pressure system? Or I can have them mounted and installed just like regular tires?
10-25-2014, 08:21 AM | #187 | |
Rep 936
10-25-2014, 10:48 AM | #188 | |
Rep 1,345
Drives: 04 Z4, 18 X3 M40i
TPMS
Earlier the question of studded tires in Ontario was asked - that is true for the south. In Northern Ontario they are allowed. With all the freezing rain that we get we should allow them outside the GTA. |
10-25-2014, 11:02 AM | #189 |
Rep 4,721
Yup. bmw changed to indirect tire pressure many years ago. It should really call Flat Tire Monitor instead of TPM because it does not give out actual reading on the FTM.
Like the poster above said, if your factory oem comes with rubber stem valves, then that's the proof that TPMS is NOT used. Thus, no need to get them. |
10-26-2014, 02:00 PM | #190 |
Rep 1
Re: winter RTF, Nokian & EH2+ wheels
Going through this thread, forum board and the internet, it’s clear the post below repeats a lot of information found here and there. But hopefully my recent experience shopping for an alternative to BMW’s approved winter tire + wheel package will help with info in one place.
Ottawa, Canada. My 2015 328i xDrive sedan (I don’t have M Sport or Performance Braking package). BMW approved winter package for my vehicle is Pirelli Winter 210 Sottozero Series II RFT 225/50R17 94H + 17" V-spoke style 413 wheels, 7.5 J x 17", ET:37, bolt pattern: 5 x 120mm, hub bore: 72.56mm, bolts: M14 x 1.25. First experience owning a BMW, indeed any car with run-flat tires. Have always bought winter tires for my previous cars. Of course, need wheels because the all-seasons are 18”. What I learned: 1. Run-flat winter tires or not? I don’t have a spare in my trunk and don’t want to gamble. Plus my BMW salesperson stated that if I had tire troubles, required warranty/roadside assistance, and didn’t have winter run-flats on, it would be declared “non-compliant operation of vehicle” (my words) – and all on my dime. 2. Which tire? Five reputable local shops had five different opinions. But one name surfaced all the time – Nokian. 3. If I’m travelling out-of-town and catch a flat, is there a tire dealer nearby stocking a Nokian replacement or am I in trouble? That’s important – for any winter tire brand. 4. Nokian Hakk 8s. New in 2014, includes run-flat sizes, normally a studded tire, is available *exclusively* in Quebec studless. Caution: if you’re stuck with a flat anywhere but in or across the border from Quebec, the local Nokian dealer *won’t* stock a studless Hakk 8. 5. Nokian Hakk R2s have a run-flat version in the size I seek, but their speed rating is “R” (170km/h) not the BMW approved “H” speed rating (210km/h) of the Pirellis. Possible issue? The Nokian Ontario territory sales manager stated that as long as I understood the “R”-rated tire would not be as “performing” in dry conditions compared to a stiffer “H” speed rated winter tire, then there was “no incompatibility” with an “R”-rated winter tire on my car. The stiffer “handling” winter tire vs. softer “snow/ice” winter tire debate. Back at my BMW dealership, I asked specifically if putting an “R”-rated (run-flat) winter tire on my car would affect my BMW warranties/roadside assistance. No one said that was an issue. 6. Tire pressure monitor sensors (TPMS)? My car doesn’t need them, as tire pressure is monitored though the ABS. 7. Wheels specifically designed to mount run-flat tires have the EH2/EH2+ designation. There is a design difference between “conventional” and “run-flat” designed wheels. Differences include extra lip on rim of EH2/EH2+ wheel to support run-flat sidewall, and stronger construction to handle increased shocks transmitted through stiffer run-flat sidewall. 8. Must you have EH2/EH2+ wheels for run-flat winter tires? Apparently it depends on the tire manufacturer. Nokian’s website claims “Nokian Flat Run system tires can be installed on conventional wheels”. I contacted Bridgestone about this, but have received no reply as yet. The five local shops I spoke to were all over the map on this one. Interestingly, tirerack.com glosses over this question completely when you use the website’s “snow tire & wheel package” advisory system – no mention whatsoever if any of the recommended wheels are EH2/EH2+. What does my BMW dealership say? No guidance, really – and no clear answers whether using “conventional” wheels impacts BMW warranties/roadside assistance. 9. Does an EH2/EH2+ after-market wheel for my car exist? I found one made by RWC, a Montreal-based company. A 17” BMW replica wheel exactly to match F30 3-series dimensions, with EH2+ designation. I found RWC wheels sold by two local shops at least. One of the shops told me they had a 5-year history with supplier RWC and “no issues”. My point is not to tout Nokian or RWC. I don’t have first-hand experience whether the Nokian Hakk R2s are that much better (or worse) that a competitor’s tire. I do not know if RWC wheels are as good as (or worse than) any other after-market wheel, and whether any of them can hold a candle to BMW OE wheels. I meant this post to flag some decision points and options: run-flat winter tires yes or no, run-flat designated wheels yes or no, and “R” speed rated tires yes or no on a new BMW 328i xDrive sedan. Safe winter driving all. Last edited by BMW_Mouse; 10-27-2014 at 01:37 PM.. |
10-27-2014, 11:30 AM | #191 | |
Rep 76
10-27-2014, 12:07 PM | #192 | |
Rep 4,721
If the clearcoat & paint do come off after 1 yr or so, you can have them powder coated for $750 or so (set of 4). Of course, you will then ask "What's the point of this, I would be better off by buying a more decent set to begin with".
TSW or Enkei may be a better alternative. Price them out to see if it meets your budget. Quote:
10-28-2014, 11:45 AM | #195 |
Rep 76
Thanks Malik. They look nice actually. But I'm concerned about quality. What do you think of them so far and how's the fit? Does weight matter?
By the way anyone know of a tire/rims guide for dummies? Thanks. |
10-28-2014, 02:57 PM | #197 |
Rep 43
I'm not too worried about the quality. I've used replicas for several cars without issue. Decent sidewall and being careful helps. Haven't cracked or bent a wheel yet (fingers crossed). For what it cost, if I did damage one and buy a new one id still be way ahead had I gone oem or high end aftermarket. So far so good. These are my winter wheels so I'm less concerned. Summer wheels different story.
10-29-2014, 06:12 PM | #198 | |
Rep 76
