BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Tracking / Racing / Autocrossing > Race prep 335i
      04-29-2022, 07:23 AM   #221
Tobz_au
Australia
245
Drives: F30 335i
Originally Posted by Polo08816 View Post
The oil on the track indicated that it was right at at the top of the hill. We were about to go downhill - well, we did go downhill. The rear axle locked up when the engine seized and we spun into the infield. It's really hard to countersteer because you lose steering assist.
Really lucky you had the run off… otherwise could have been a lot worse
      04-29-2022, 08:17 PM   #222
lens
lens's Avatar
2070
Drives: 2018 340i xDrive
I believe the engine just didn't have enough oil pressure to circulate the oil around especially with your bigger oil cooler. And with the braking and G's, it was only a matter of time, the M cars (even the M2 N55) have dual oil pickup and oil pumps for that reason.
I'm currently at 175k miles and my last track session was pretty good, I'm planning to pull bearings at 200k miles to inspect them and replace with coated ones.
Mind you I'm sitting at 420AWHP/438AWTQ.
      04-29-2022, 08:23 PM   #223
52172
52172's Avatar
Drives: 2015 Bronze Metallic 335i
Nice!
      04-30-2022, 04:04 AM   #224
Tobz_au
Australia
245
Drives: F30 335i
I’ve got the same oil cooler and also have king rod bearings. There is not a significant reduction in oil pressure due to the larger cooler alone and a small (1-2psi) drop in oil pressure at idle due to the bearings.
      04-30-2022, 02:35 PM   #225
Polo08816
Drives: 2014 335i M Sport
Also "lucky" it seized up as steering was almost completely unwound as opposed to in the process of turning into the apex.
