BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Tracking / Racing / Autocrossing > Race prep 335i
      11-21-2018, 11:56 AM   #23
Gr-Racing
Gr-Racing's Avatar
206
Drives: E46, F30 335i, 1986 K75
1+ on removing the EDC, car feels way better with coil overs.
look for F80 control arms and find a sway bar the car handles way better
I do about 4 events a season and enjoy the 335 very much, Im running 245 / 265 setup for tires.
DVC I need find out more on coding the Elsd and other nannies out haven't tried that yet
      11-21-2018, 01:25 PM   #24
DVC
Diligentia Vis Celeritas
DVC's Avatar
Drives: 335i
Here's the thread on coding for the F chassis: <link>
I agree on the F80 control arms in addition to the sway bars.... The F80 front LCAs have a nice spherical bearing that is an improvement over the F30 bushing; the F80 tension struts are a must to maintain proper front wheel geometry when the F80 LCAs are installed, but the F80 TSs have the same mushy bushing as the F30 version, so I went with Dinan mono balls in mine. Also, I swapped 4 of the 5 rear control arms (no after market option for the roll over strut) with Megan Racing arms with heim joints, and then put delrin bushings and spherical bearings in the OE roll over strut. Not to mention solid rear subframe bushings. No rubber anywhere in my suspension at this point, so the car feels pretty dialed. And yet it's still more comfortable on the street than my friend's stock BRZ.
      11-21-2018, 08:47 PM   #25
97supratt
97supratt's Avatar
Drives: porsche and mercedes
When I used to track my c5 z06, the abs and stability control would kick in and ruin my lap times. There was no way around it unless I rewired the car. Less tech feels a lot better unless you are porsche or mclaren and you build a 1 million dollar hypercar.
      11-22-2018, 10:14 PM   #26
DVC
DVC's Avatar
Drives: 335i
Modern BMW ABS is so good...A lot of serious 911 builds swap in the Teves mk60 units from e46 M3s for a significant upgrade (excluding the GT cars, which use sophisticated Bosch units).
TC/DSC has come as long way too. Back in the early e46 days, it was unusable even in spirited street driving...but now Sport+ with a mechanical LSD allows enough slip angle to really rotate the car in turns without ever intervening. And if you code out the eLSD, then you can run in DSC off with zero TC/stability nannies.
      11-24-2018, 05:50 PM   #27
97supratt
97supratt's Avatar
Sounds good to me. Before I install anything, I gotta have the dealer repair some vibration coming from the rear. All my stage 2 parts are waiting to be installed. Anything above 70mph includes a horrible vibration from the rear end.
      01-13-2019, 09:21 PM   #28
52172
52172's Avatar
Drives: 2015 Bronze Metallic 335i
I had the same dillema. The M lineup will always be more race oriented but the issue I have with M's is that the rotors are still too soft for race pads, the dampers cannot be lowered with "springs". Any M vehicle is setup for perfection from factory. The 335 seems to react better to mods and is really fun in the corners.
So the cost offset going from a new F80 to a used 335i makes up for the upgraded rotors and mods on the F30?
For a lot less you can just get a c5 z06 and be done with it. Hahah
LOL true
You mean c6 z06
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s.
      01-19-2019, 07:04 PM   #29
97supratt
97supratt's Avatar
Originally Posted by 52172 View Post
You mean c6 z06
The C5 is a much stiffer chassis surprisingly. St1 and St2 class is full of really fast c5 z06's. For some reason the C6 chassis is too soft and feels too heavy around corners. Plus the vavletrain issues in the LS7 doesn't help. 🤔
      01-21-2019, 05:50 PM   #30
Niart906
Drives: 2017 M3, 2003 M3
C5 Z06's are no joke, my buddy has one with heads/cams/exhaust and it's a monster. For the money, they're a much more capable track toy than an F30 even with some mods. I just could not live with that interior, way too much shiny plastic.
2017 F80 M3 - Mineral White/Amaro Brown
2003 E46 M3 - Jet Black/Cinnamon
      01-21-2019, 05:58 PM   #31
52172
52172's Avatar
I had a 4th gen CAMARO with the ls1 that I had the heads ported and custom cam and ls6 I take was good for 420 rwhp. I never knew the c6 chassis was a problem. Lg Motorsports beat all their c5 times in a c6.
      01-30-2019, 11:20 AM   #32
97supratt
97supratt's Avatar
Ya lg had sequential transmissions in the c6's. I'm referring to normal track guys that attend hpde's or time attacks, nasa, scca. The c5's are typically faster and lighter.
DVC558.00
      01-30-2019, 11:25 AM   #33
52172
52172's Avatar
Gotcha
      03-29-2019, 10:36 AM   #34
DVC
DVC's Avatar
Drives: 335i
So what's everyone planning for mods this season? Here's my wish list...
  • Braille lightweight battery (current OE battery is shot anyway)
  • Stuffing 10" wheels and 275mm tires front and rear (will certainly require a mild fender roll)
  • Sunroof delete/CF filler panel (great way to drop 40+lbs where it really counts) - working with ECS Tuning to make one for the F30, but I could really use some help from an F30 owner local to Ohio!!
  • Seibon VS Carbon Fiber hood - only about 25# of weight savings, but better cooling and they look awesome
  • AutoPower roll bar - bolt-in rear cage to replace my current harness bar setup
  • Flash tune - more power is not a priority, but looking forward to linear throttle response and more headroom at high RPM
  • Wagner Competition FMIC (a must with the tune)
  • Oil catch can (also a must with the tune)
I will likely pull the trigger on the first 2 or 3 this Spring... not sure about the rest.
      03-29-2019, 12:19 PM   #35
52172
52172's Avatar
how are those Braille batteries for daily use?
      03-29-2019, 04:15 PM   #36
DVC
DVC's Avatar
Drives: 335i
I don't have any first hand experience with them, but as I understand it, the biggest one (B3121) is fine. It's still only 21#, but has a 31 amp-hour rating, and 550 cold cranking amps.
      03-30-2019, 12:44 PM   #37
brigade24
brigade24's Avatar
Drives: 2013 335 X-dive
For this year, I'll be getting some 18x10 arc-8s and running 265 RE71s. I'll also be doing the rear subframe bushings...more than likely going with the delrin units from bimmerworld.
My autox season has already started so I'll be doing all this in between events.
      03-30-2019, 01:16 PM   #38
cngo
Interested to see how you will fit 18x10" ARC-8s since they are only offered in one offset that is suited to E46/E9x/F8x M3/M4
      03-30-2019, 03:31 PM   #39
brigade24
brigade24's Avatar
Happy to share my logic and measurements with you.
according to my measurements the rear will not be a problem at all. The fronts will need a spacer and a fender roll. If I have calculated correctly given my spring rates, the car may also need to be raised approximately 4mm assuming camber is at -2 deg. Since I increase camber before every competition to -2.9, rolling the front fenders will still be required due to the arc8s 25mm offset will certainly be a factor. The section width will also be a factor. Suffice it to say it will be close in the front...
For perspective, the distance between my shock/spring assembly and the inner fender is approximately 269mm. the tread width of the 265mm RE71r is 246.38 mm (9.7 inches, courtesy of tire rack).
As a measure of insurance lets say the 10 inches for the wheel width is measured from the inner beads. So you can add a half inch for good measure so say 10.5 inches which is 266.7mm. Note that the wheel lines up with the shock and not the spring providing more clearance.
There should be enough room. I will be happy to share pics once its done.
This is what happens when autox becomes an obsession.
      03-31-2019, 08:45 AM   #40
EstorilMSport
EstorilMSport's Avatar
Drives: 2014 335i M Sport
Joining in on this thread... I just tracked my F30 335i at Sebring for the first time last weekend and pretty hooked. I ran with KW Clubsport coilovers, stock M-sport brakes, Motul RBF600 fluid and Michelin PS4S tires. The car/tires held up great but I did lose some pedal along the way.
Future mods list in order (would love feedback):
  1. Track brake pads (not sure what brand/model and what rotors to run)
  2. F+R sway bars (brand undecided)
  3. Track wheel/tire setup (need guidance on wheel and tire width and offset and square vs. staggered)
  4. Bushings
  5. M-performance LSD
Thanks for the help guys.
2014 335i M Sport: bootmod3 Stg 2 E30 Custom, AA CP, CSF FMIC, GFB DV , VRSF catless DP, aFe stage 2 intake, KW Clubsport coilovers, MP LSD, aFe sway bars, F80 LCAs, monoball thrust arms, Delrin rear subframe bushings, xHP Stage 3.
IG: German_car_connection
      04-02-2019, 12:48 PM   #41
jalkster
Drives: X3MC
adding WMI currently for this season. LSD already on
Current: 2021 M340i
Previous: 2020 X3M Comp BM3 E30 & 2016 340i 8AT DME Stage 2 | FBO/Catless Meisterschaft Catback | Ohlins R&T
      04-03-2019, 11:32 AM   #42
DVC
DVC's Avatar
Drives: 335i
A man after my own heart....
I am planning the same; I haven't run the numbers as thoroughly as you, but have also determined that they should JUST make it : ) I currently have a set of Apex ARC-8s in 18x9.5 with RE-71R tires in 265/35, and it does seem like I could squeeze another 1/2" in there.
      04-06-2019, 08:32 PM   #43
Logicoeur
Logicoeur's Avatar
993
Drives: F30 335i xDrive
How does -2 degrees camber front and rear look? I really like the meaty square look and the ARC8s will be the wheels I choose.
      04-08-2019, 09:46 AM   #44
brigade24
brigade24's Avatar
lol indeed, love this stuff. hmmm...some are saying that 10" is too wide for preservation of grip and at optimal temperature for the 265 so I wonder if the 9.5" would be more ideal. I took more measurements this weekend with the wheel fully cranked to one side and noticed the fender liner may need to be massaged a bit to fit a 275 at full crank...so since it is highly unlikely you'll be at full crank on the racetrack, it should be good. need to take more measurements to be sure.
On my way to Charlotte this past Friday, I stopped in Virginia to pick up my delrin subframe bushings from bimmerworld...Very cool place!. I also ordered some delrin bushings for the differential from Condor speed..I'm stoked to see the result.
DVC558.00
