BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Tracking / Racing / Autocrossing > F30 328i Makes a Decent Track Car
      07-27-2022, 12:46 PM   #23
phefner
phefner's Avatar
Drives: F30 340, F80 M3
Video from a rainy day with the PCA. Took my 2013 F30 to the track and we had a blast passing all day long. Not a single point bye. Intermediate Group.
Enjoy!
Quietly Effective
      07-31-2022, 11:45 AM   #24
sygazelle
Drives: 2014 328i M-Sport, 2019 X5 40i
Enjoy!
What engine do you have in that 2013 F30? Mods?
Great video (unless you own a Porsche)
phefner369.00
      07-31-2022, 10:07 PM   #25
phefner
phefner's Avatar
Stock F30 with PS4S tires. The equalizer was the rain. And maybe that I've done a number of track days in rain, not to mention my hardware isn't nearly as costly so running balls out wasn't so scary.
Tracking in the rain is a blast. Don't let a rainy day keep you away.
I've owned a couple of P-Cars. Our local PCA puts on some great events.
Quietly Effective
      08-01-2022, 08:39 PM   #26
MacklinUSOB
Drives: f30 328i 6MT Sport
PS4S is the rain tire of choice and your driving shows it off really well. I did a PCA event at LRP a few years ago, think there was some rain. Fun crowd.
I had a set of PS4S on the car in, first thing I changed on it, actually. They kicked off my suspension rabbit hole.
Living in an apartment I had to run RS4 for drive on/off (NYC). Inferior to the PS4S in the wet, no doubt, but more manageable than the other 200TWs.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines |
Past: E36 328is & E38 740i
phefner369.00
      08-01-2022, 09:51 PM   #27
dangerus_car
Drives: F30
f30 stock suspension is a little soft for me, i have no confidence when i track the car earlier this year.
i will change the setup soon enough and try again
      08-02-2022, 09:27 AM   #28
MacklinUSOB
Not sure how old your car is or if M-Sport or not, but most F30's are getting to that age where replacing the suspension, even with new OE/Bilstein parts, makes a large improvement.
Camber is what really changes the game, though. There are even some OEM options for that as well if you want less of a project.
      08-02-2022, 11:53 AM   #29
dangerus_car
Drives: F30
ah i see. it's about 7 years old, so i guess it's due. still thinking if i should buy the monoballs or not to replace the upper/thrust and lower control arm.
as for camber, what is the right setup? should i buy the camber plate as well?
      08-02-2022, 01:20 PM   #30
MacklinUSOB
Replacing your control arms and struts is not a bad idea at that age. It will firm/sharpen things back to new. FCP Euro has reasonable prices and you buy in to the lifetime warranty. If you ever hit a pot hole or something wears out, you're covered.
If I were to suggest 2 mods alongside a front suspension refresh it would be the Millway Street Camber Plates and the Millway Street thrust arm/tension strut monoballs. Both add very little NVH which is great for a daily, but you get the benefits of camber adjustment on top of the reduced deflection on the thrust arm.
I have been running -3/-2 for a while and it has a great balance. Toe you can leave stock, or start getting closer to neutral on the front end. For a more streetable alignment -2/-1.5~ with stock toe raises the limit quite a lot without going too crazy.
https://www.millway.se/camber-plates...0-f31-f32.html
https://www.millway.se/front-control...w-f20-f30.html
phefner369.00
      08-02-2022, 01:39 PM   #31
dangerus_car
Drives: F30
damn, everyone on the forum suggest the monoballs, the options are either VAC monoball or millway monoball. i guess i m probably going to get the VAC monoball because it's already pressed in, and just simple removing and install.
the monoball itself is cheaper by its own, but looking at 7 years old age, changing the arm is not a bad idea, i would think... so it can go another 7 years.
how about rear suspension? no need to refresh them?
      08-02-2022, 03:01 PM   #32
MacklinUSOB
Millway will actually sell you a new set of arms with these pressed in as well:
https://www.millway.se/front-tension...lemforder.html
As for the rear suspension, it typically gets less wear than the front. I am still on stock hardware for the most part on my 2012 and it's still tight and holds alignment well. You could replace the struts, they are pretty easy and inexpensive.
      08-04-2022, 07:05 PM   #33
n55david
n55david's Avatar
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
I'm just here for the dodge hate.. I love it
Yeah IC is a must even on a stock car etc
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
