BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > The $89 BMW performance spoiler on my EBII M sport
proTUNING Freaks
      05-03-2014, 12:57 PM   #441
TPA335
Drives: 2014 335i M-Sport 6MT
Just received mine. Did anyone use the adhesive that came with it? Where are you supposed to apply that?
2014 335i M-Sport 6MT MPPK
Alpine White/Coral Red
      05-03-2014, 03:52 PM   #442
Thackers
Yorkshire Sniper
Thackers's Avatar
England
Drives: F30 320d Sport
Pretty much up to you really..,
I just used some between the tape and the spoiler but didn't bother on the paintwork.
The most important point is to ensure both surfaces are completely clean using the alcohol wipes and leave for 24 hours without driving and no water contact after fitting.
A warm day also provides best results.
I also bought some additional wider 3M tape so I could cover almost the entire underside of the spoiler.***
***bear in mind the adhesive primer starts to set in seconds so ensure you offer the spoiler into position before applying and make some datum points with a marker to help
Thanks in Advance......
      05-03-2014, 09:48 PM   #443
heyqqqq
Drives: 320i
Originally Posted by euro-r View Post
This one look nice
Does anyone know where you can order the smaller M3 spoiler, OEM or Replicate? Also anyone have pics of liquid blue with the spoiler?
      05-16-2014, 05:31 PM   #444
dragonxflare
Drives: 2013 BMW 328i
Just picked up a black sapphire metallic from Emotors on ebay. Everything looks great, and color matched perfectly.
Ordered it on May 12th, received on May 16th. Great dealer
http://www.ebay.com/itm/360922872441
      05-20-2014, 08:14 PM   #445
JoshB25
JoshB25's Avatar
Drives: F30 318d M-Sport
Fitted mine the same day as I got the car. So happy with it!
eMotors again
      05-22-2014, 05:18 PM   #446
roxxor
roxxor's Avatar
1141
Drives: 2024 iX50
Just got and installed mine today. Black Sapphire Metallic, looks great! Another happy carbon king customer!!!
      06-12-2014, 02:00 PM   #447
MickAv8r
MickAv8r's Avatar
Drives: 2014 EBII 328ix
Just got mine in EBII(B45) from Carbon.king. Speedy delivery and arrived well packed and in good condition. Unfortunately the paint match isn't acceptable. Fairly sure I may hold off mounting it. Today is a cloudy day and the difference was bothering me when I test fitted it. The spoiler is darker and seems to have a yellowish tinge to it almost like they used the wrong clear coat or something.
Going to wait for a sunny day just to double check to see if I can live with it or not. Then probably just order an unpainted one and have a body shop paint match it for me or opt for flat or satin black instead.
Well weathered leather, hot metal and oil, the scented country air.
Sunlight on chrome, the blur of the landscape, every nerve aware!
2014 328ix EBII - Sport AT, Light Pkg, Blk Dakota, Moonroof, Navigation, Heated Seats, HK Audio, Driver Assist, Sport Pedals, Dinan Springs, Bilstein B8s, M-Performance BBK
      06-12-2014, 03:10 PM   #448
Dippydo
Drives: 2023 M8 Comp
2012 BMW  [1.00]
If you opt to not do it, just have the one you have repainted. No reason to buy an unpainted one and paint it.
      06-12-2014, 09:33 PM   #449
MickAv8r
MickAv8r's Avatar
Was thinking maybe I'd want to see a flat black spoiler on there first and part of my mind was thinking of saving them some paint prep work but yeah probably the best way to go. I just hope we get some sun soon so I can see it better.
      06-19-2014, 07:29 PM   #450
CQVD330
CQVD330's Avatar
Drives: 2017 340i MPPSK
Originally Posted by AWMSPORT
Hi. Would that be what they call "unpainted/unprimmed ABS" ?
2017 340i LCI //Glacier Silver Metallic //xDrive//MPPSK//Premium Package//M sport brakes //Vossen 20" CV7//6 MT//Performance front spoiler//Performance side blades//Performance diffuser//Performance trunk spoiler//Tinted//Coded//Painted reflectors//Matte black 340i badge//Powder coated MPPSK tips
      06-19-2014, 07:34 PM   #451
CQVD330
CQVD330's Avatar
Originally Posted by KANdaddy
Couple crappy phone pics of the matt black one they did for me. Very happy with the results! Well worth it.
Do you have the m replica front lip? If yes, does it match ?
Thanks
      07-02-2014, 08:20 AM   #452
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
Question Spolier Placement
Hi,
Ordered spoiler for my 2014 328 from eMotors2000 on eBay and got it yesterday; color match is super!
Having read this thread through a couple of times, before I install, I still have three questions:
  • First, is it advisable to wax the exterior of the spoiler BEFORE I install or just wait until it sets?
  • Second, a little tube of something like adhesive primer came with the spoiler (in addition to 3M 2-sided tape & alcohol wipe); should I use this primer?
  • Finally, how should the spoiler be placed; seems like either I can line up the trailing edge of the spoiler with the "break point" in the trunk, leaving the center gap OR l set the spoiler so that it sits right on the bend in the trunk?
Appreciate any advice
Thanks
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH|
Retired: 2014 328i
BMW CCA
      07-02-2014, 10:30 AM   #453
Dippydo
2012 BMW  [1.00]
1. First, is it advisable to wax the exterior of the spoiler BEFORE I install or just wait until it sets?
***Up to you. I put mine on and then waxed it right away that day. Makes little difference.
2. Second, a little tube of something like adhesive primer came with the spoiler (in addition to 3M 2-sided tape & alcohol wipe); should I use this primer?
***This is an accelerator and I would use it on the spoiler side and not the car side. It helps the adhesive of the tape stick to the ABS plastic better. To help before any of that is applied, wipe the area on the trunk where it is being placed and the bottom of the spoiler with rubbing alcohol to help remove the wax and the releasing agents used on injection molding on the spoiler.
3. Finally, how should the spoiler be placed; seems like either I can line up the trailing edge of the spoiler with the "break point" in the trunk, leaving the center gap OR l set the spoiler so that it sits right on the bend in the trunk?
***Not sure what you mean. I placed mine on the edge. The spoiler is molded to sit on the leading edge with a little overhang. There should be no gaps. If you lay it on the trunk, it should sit there without being held in place actually.
One other tip to help you align it is to put a piece of masking tape on the spoiler, set it in place without the tape exposed, then put a piece of tap on the trunk. This will help you stick it in the right place. Once you put it down, it is not easy to pull back off without damaging the adhesive.
      07-02-2014, 01:42 PM   #454
Thackers
Yorkshire Sniper
Thackers's Avatar
England
Originally Posted by RSnic View Post
Hi,
Thanks
I did the same process as above with the primer..ie spoiler side only.
Others have done both sides especially if they never intend to remove.
I purchased additional 3M tape instead to give better coverage to the underside of the spoiler because on my first attempt I wasn't 100% happy with the positioning as it was out by around 1mm.
Removal is tricky or that's what I found with primer on both sides, even after just a few minutes after fitting.
Offer the spoiler up to the boot prior to removing the tape and draw around with a non permanent marker or felt tip pen....this will simply polish off after completion.
Top tip..leave the spoiler to cure for 24 hours before driving or getting wet..Place a cover over if there's any chance of rain during the curing process.
      07-02-2014, 03:17 PM   #455
RSnic
RSnic's Avatar
Question
Dippydo,
Absolutely terrific advice!!
I am sorry for not being clear on my third point. To overcome that, I took two quick pictures:
  • The first is Spoiler On Trunk Lid; you can see spoiler goes up to lip, but not over it.
  • The other is Spoiler Over Trunk Lip; the spoiler rest on the lip
Both seem to fit well -- ignore the cracks as I just sat the spoiler and didn't try to properly position. So which is the way to go?
Thanks
Al
Retired: 2014 328i
BMW CCA
      07-02-2014, 04:15 PM   #456
Thackers
Yorkshire Sniper
Thackers's Avatar
England
Dippydo,
Thanks
Bottom picture is correct...top is INcorrect
      07-02-2014, 08:02 PM   #457
RSnic
RSnic's Avatar
Thackers,
Appreciate your advice; the reason I'm asking as I looked over this extended thread, seems that both ways are used, but more seem to use the On the trunk lid (the first picture) (see posts 136, 148, 159, 176, 250, 268, 296, 307, 364, 371, 374, 391, 403, 426)
Al
Retired: 2014 328i
BMW CCA
      07-03-2014, 12:30 PM   #458
Thackers
Yorkshire Sniper
Thackers's Avatar
England
Thackers,
Not sure what your looking at..but I've checked 391 and 403 and they are both as I've said.
There's only one correct way to fit the M sport spoiler
      07-03-2014, 01:27 PM   #459
f30GTR
f30GTR's Avatar
51
Drives: 2014 AW F30 335i M-Sport MT
Finally got my car and the alpine white 300 from carbon.king does not match BMW's actual alpine white 300 III. This is on a brand new F30 that rolled off the line. Not complaining just giving fair warning to those with alpine white cars. I was warned by carbon.king in an email that there is chance the white won't match because it yellows after time and they offered to refund me the $20 and send me a unpainted lip. I said no and hoped it matches. Not too disappointed since I will be paint matching rear diffuser and front splitter. I will take a pic later but it pretty noticeable.
      07-03-2014, 01:28 PM   #460
Thackers
Yorkshire Sniper
Thackers's Avatar
England
Black spoiler compliments AW F30 much more IMO ..
      07-03-2014, 01:51 PM   #461
f30GTR
f30GTR's Avatar
51
I was originally going that route but i have decided to go different direction.
      07-03-2014, 01:59 PM   #462
RSnic
RSnic's Avatar
AAh, I see -- Beaucoup Thanks!!
Al
Retired: 2014 328i
BMW CCA
