07-13-2015, 09:11 PM | #1 |
Rep 391
Monster Pothole Ripped off Lift Point
I hit a major pothole the other day which caused the car to bottom out and rip off the lift point behind the front driver's tire. A bit of the plastic shielding and a metal part it attaches to peeled back which the dealership pinned back up along with the lift point.
I asked them to take a look at the suspension to make sure everything was okay and they said it was fine. The car was actually brought in to perform the fuel pump recall and re-apply a trunk spoiler that was falling off (again). Part of me feels like they didn't even look at the suspension and just said everything was fine. I've noticed the two following issues: 1) Noise from driver's side rear tire well when getting into or out of the car. Sounds like a squeaking spring. 2) When going over low speed bumps it sounds like there is "air escaping" from the front driver's side. It sounds cheap like an old Buick bouncing over bumps. Is this normal? What are some parts that could be causing this issue? I'll be calling the dealership tomorrow to schedule a date to bring it in but I would appreciate if anyone could provide any insight that would better prepare me to make sure this is taken care of by the dealer. Car tracks straight, some slight vibrations coming through are probably bent wheels which I won't be fixing at nearly $200 a pop... |
07-13-2015, 11:31 PM | #2 | |
Rep 807
2) Normal. Sounds like the shocks. Should be coming from all four corners. If you don't feel anything while driving, I wouldn't worry about anything. Just take it easy and bring it in to the dealer. I'm sure they will confirm what I just stated. |
07-14-2015, 01:04 PM | #3 |
Rep 710
That was some pothole!!! Hope all is well.
2018 Mustang GT | Royal Crimson | Black Leather | 6-speed | Cold Weather | Premium Pkg | 20" Alloy Wheels | Tuned to 510HP | Less than $45K
Previous loves: 2015 F30 335i / 2013 F30 335i / 2009 E90 335i / 2007 E90 328xi |
07-14-2015, 01:41 PM | #4 |
Rep 3,258
Drives: 2015 F36 Jet Black Sport Line
I can't see driving it with a bent wheel. The vibration at speed alone would drive me crazy and probably cause the tire to wear prematurely and 'funny'. At the very least, have it removed and checked at a tire shop (or dealer) to see if its still in balance or it it does indeed wobble. If it's minor enough, maybe additional wheel weights could be a cheap bandaid for now........
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint| |
07-15-2015, 04:18 PM | #5 | |
Rep 391
LaBeef - Thanks for the input. I haven't noticed the parking brake squeak/rattle again. |
07-15-2015, 05:15 PM | #6 |
Rep 693
Agreed.
now, OP, you said metal was ripped off the jack point? Now, to be clear, the jackpoint most people see and refer to is the pinch welds for the rocker and floor. There's nothing covering those. now the lift point for a shop lift are under plastic covers under the car, guessing that's what you are referring to, hopefully the metal was just a clip/attachment and not the body of the car. I think when a pothole causes the car to bottom out on the road it is officially categorized as a "crater". I hope you reported that to the road department, that's a major safety issue.
2018 M240i X-Drive | Sunset Orange Met
2015 328d X-Drive Touring M-Sport (Traded) 2015 Audi S4 Sepang Blue P+ | DSG | Tech Package | Adaptive Suspension | B&O 2015 Audi S3 Misano Red | 19" Sport pack w/Mag Ride | B&O 1983 Porsche 944 All stock |
07-15-2015, 05:43 PM | #7 |
F30 -> F80 Conversion
69
Rep 217
Fixing the bent wheel and checking the suspension would be my number one priority. Just a major safety issue in my opinion.
07-15-2015, 08:35 PM | #8 | |
Rep 391
Bent wheels were not covered under T&W protection, although I've had 1 or 2 covered in the past due to bends. Two tires were replaced for bubbles. I asked the SA to check the suspension as well and they did not find anything wrong with it, which I found a little hard to believe considering the hit the car took. They are a busy dealer, but I can't imagine any dealer would deliberately ignore something they could bill for. If what Labeef said about the two issues I mentioned are true, then maybe it's just me worrying. |
07-15-2015, 09:28 PM | #9 | |
Rep 633
