02-05-2013, 10:40 AM | #2531 | |
Rep 821
02-05-2013, 11:41 AM | #2533 | |
Rep 343
I'll try this out as soon as I get home and let you know... Fingers crossed!! hopefully it works..
2012 F30 328i, Alpine White on Black, Luxury, Premium + Exec. Package...
02-05-2013, 12:50 PM | #2534 |
Rep 821
02-05-2013, 01:08 PM | #2535 |
Rep 1,976
Drives: 2020 G20 320i M Sport
Ok, I finally managed to disable the BMW Assist menu and replace it with Connected Drive but when I go to BMW Live, it keeps asking to activate BT data service when I already enabled it on HU_CIC.
Shawn, is there a way you can do this through USB tethering? |
02-05-2013, 01:16 PM | #2536 | |
Rep 40,650
Did you replace 6NL with 6NK?
02-05-2013, 01:23 PM | #2537 |
Rep 1,976
I was actually on 6NH and changed it to 6NK. I just FDL coded a few things on HU_CIC and got connected drive to come up.
I think this is the part where I need to use a ghost vin like you said earlier. For me, I have nothing to lose since I don't have BMW assist. It just shows up on my menu with some phone numbers to call for service. |
02-05-2013, 01:27 PM | #2538 | |
Rep 1,879
Drives: 2012 F30 328i
Would be nice if a video output could be used.. I have two portable dvd screens in my car that have all cables hidden and such, so it looks neat, but it's not connected to the idrive... it would be cool if that was possible to achieve
Note: Many PM me for links to the software needed to code. Please note that I do not have download links to this software. Your best bet is using the search function in the coding thread |
02-05-2013, 02:05 PM | #2539 | |
Rep 3,780
02-05-2013, 02:43 PM | #2540 |
Rep 40,650
I have a pretty good idea how it can be done with E-Sys. When you are ready to try, PM me.
02-05-2013, 02:52 PM | #2541 |
Rep 3,780
PM sent!
02-05-2013, 05:09 PM | #2542 | ||
Rep 58
02-05-2013, 07:00 PM | #2543 | ||
Rep 343
OK.. DONE !!!! Works flawlessly.. This was the one thing I desired the most.. It's actually the easiest thing to do.. Thanks Aritaurus.. Banana here are the instructions Aritaurus gave me.. Under VCM, select read then save the FA (up top) then edit and on the FA folder, you will see something called salapa element. Once you're in there, you will see all the feature codes on your vehicle order; the one you want to change is 6NH which is your USB and Bluetooth feature - change this to 6NK and hit apply. Once you're done that, activate the FA and right click HU_CIC folder and select code. Once your idrive reboots, you will see the office menu and extended Bluetooth. After that, right click cmb_media and code. This will allow your iphone cable to sync with idrive in the armrest. One thing now.. I tried coding my other stuff back and it's now asking for EST something something? Est missing ? I just did a fresh install on a new system so I'm guessing its an install problem.. Any ideas anyone?
02-05-2013, 07:09 PM | #2544 |
Rep 343
Any update on getting office to work? It's doing the same thing for me ie Nothing!!
02-05-2013, 07:48 PM | #2545 | |
Rep 490
02-05-2013, 07:50 PM | #2546 |
Rep 490
do you have the code away.est file and have esys program properties point to this. This is the password pin file to code, but only works with esys 3.18.4 and up to psdzdata 48.2 (48.1 to be absolutely safe)
02-05-2013, 07:51 PM | #2547 | |
Rep 490
02-05-2013, 08:32 PM | #2548 | |
Rep 1,976
Is there a way I can obtain one with those options on it? |
02-05-2013, 08:52 PM | #2549 | |
Rep 1,976
Also, it took me a while to find out that you only see the messages at the time you receive them while in the car. All older and archived messages won't show at all. |
02-05-2013, 08:58 PM | #2550 |
Rep 490
Data I believe should be coding in COMBOX, again HU_CIC is just what you see on screen not the actual functionality, changes has to be made in conjunction with the relevant ECU to make them work together.
02-05-2013, 09:00 PM | #2551 | |
Rep 490
A friend informed Android also work flawlessly, so the problem is with IOS, though Apple said they support MAP, but all we see is half-ass sync using notification window. |
02-05-2013, 09:13 PM | #2552 | |
Rep 1,309
Drives: YMB M3
Garage List 2016 BMW X6M [0.00]
2018 BMW M3 [0.00] 2015 BMW X4 35i [0.00] 2015 BMW M4 (SOLD) [0.00] 2012 BMW 328i SL(SOLD) [0.00] 2008 BMW 328i (SOLD) [0.00] 2007 C230 Komp (SOLD) [0.00] 1999 BMW 328i (SOLD) [0.00] |
End of lease the service department doesn't look at it. Just someone from the sales department. Do what you want to the car now. They are not going to bust your balls over little stuff. If you are really concerned just code everything back before you turn it in. |
