05-30-2013, 10:08 AM | #1 |
Rep 110
Sport +
Sorry if this is a stupid question, but I generally never play around in Sport +. Well this morning on my way back from the gym, I hit an open stretch of twisty road and threw it all the way into Sport +.
What is confusing to me is the display tells me "Dynamic Traction Control Activated" but then the icon for traction contol "OFF" is illuminated. Photo below What is really going on here? Are there any other advantages to Sport + versus plain old Sport? |
05-30-2013, 10:16 AM | #2 |
Rep 710
As far as I know, the only difference between Sport and Sport+ is that traction control is turned OFF (Or severely reduced, at least) I believe the throttle response and steering is the same between Sport and Sport+
05-30-2013, 10:18 AM | #3 |
Rep 110
That was always my understanding as well, except the dashboard's verbiage is confusing when it says "traction control activated"
05-30-2013, 10:21 AM | #4 |
Rep 2,612
Drives: F30 328i Luxury - Sport Auto
Pressing Sport + or DSC (Dynamic Stability Control) once turns on DTC (Dynamic Traction Control) which is a part of DSC. This optimises forward momentum with reduced vehicle stability. So that means that if wheel slip is what will optimise forward momentum, it'll let it slip. But because of this, there is less stability control so the car will slide about more until the system (DSC) intervenes severely.
Gone: 2006 BMW E60 520d SE 6MT Gone: 2009 BMW E90-LCI 330d SE 6MT Current: 2012 F30 328i Luxury 8AT On Order: 2015 Audi A6 Avant Ultra, Black Edition (sorry!) |
05-30-2013, 10:55 AM | #5 |
Too much is never enough
655
Rep 3,079
Normal traction control will kick in to eliminate ALL slippage. DTC will only intervene if you're spinning wheels in any direction other than straight ahead - in which case dynamic stability control will kick in.
In a nutshell, it'll allow you to do burnouts all day long so long as you don't crank on the wheel. |
05-30-2013, 11:14 AM | #6 |
Rep 3,780
Sport+ is a great way of having a bit of safety left as TC/DSC is not turned completely off. But it allows you to have some wheelspin. I cannot deal with SPORT as it cuts power on my 1-2 and 2-3 shift, bogging the car. Sport+ allows the wheels to spin.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc) '15 Buick Regal "T"(wife) '06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc) |
05-30-2013, 12:06 PM | #7 | |
Rep 387
Find yourself a deserted, obstacle free parking lot - an autocross would be ideal - and test out full-throttle tight turns. You'll find the engine power severely cut back to prevent wheel spin while in SPORT, but in SPORT+ it wont be nearly as intrusive. |
05-30-2013, 12:09 PM | #8 |
Rep 876
For some reason I feel that Sport+ is a tiny bit more aggressive than Sport. If you really want to kill all nannies just hold down the DTC button for like 5 seconds. That will turn off DTC and DSC.
