06-29-2017, 06:57 AM | #1 |
Rep 74
Driving on run flat with sidewall blowout
I had a blow out two nights ago, and was able to drive the ten miles home on the run flat, so they proved their worth (although, I don't think I would have had a blowout on a conventional tire). My question is, with it sitting and having sidewall damage, is it safe to drive the four miles to the tire shop from my house? I don't want to cause any further damage to the vehicle. It drove fairly well under 50 mph on the way home, all things considered. Attached are pictures of the damage.
06-29-2017, 07:23 AM | #2 |
Rep 16,082
It might make it, it might not. It got you home, so in that sense it did its job. I'd be inclined to say don't press your luck, lest you damage the rim.
06-29-2017, 07:38 AM | #3 |
Rep 74
06-29-2017, 07:27 PM | #4 |
Rep 79
I had a similar situation, but just a nail in the tire. It got me home but sat overnight before I could drive to the dealer in the morning. The ride was similar to a regular flat after sitting over night. Seems like the sidewall lost its stiffness over time with the full load of the car on it overnight while flat.
06-29-2017, 08:33 PM | #5 |
Rep 1,686
Drives: 2014 428i and 2018 X5
Do you have another car?
If so jack up your car, remove the wheel and bring it to the shop to get a new one fitted.
06-29-2017, 10:18 PM | #6 |
Rep 4,109
Drives: BMW M3
If you/a friend have AAA, just have the car flatbedded to the tire shop. I wouldn't drive on it like that, it doesn't seem safe.
If not, maybe try out the BMW roadside assist, have it taken to the dealer. Charles
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT |
06-29-2017, 10:48 PM | #7 |
Rep 689
yeah I would have it flatbed to dealer. Which RFT is that? Perilli or Conti? and how did the tire just "blow" did you hit something or was it a mfg. defect? the dealer may be able to get you money back thru the tire mfg. Happened to my Perilli on my old car and BMW got me the money back for replacement under mfg defect reason "side wall collapse"
06-30-2017, 06:37 AM | #8 |
Rep 1,329
1. I would take it off and bring the wheel in for tire replacement.
2. Swap on a winter wheel/tire if you have and drive to shop. 3. Drive the 4 miles slowly and have a passenger keep an eye on it. 4. I would only consider towing it if I had zero other options. I never ever want to hook my car up to a tow truck - flatbed or otherwise. Have you seen how many tow truck operators treat cars. Or throw the money out the window. Tow will cost nearly as much as a new wheel in the unlikely event you damage it driving slow for 4 miles. If this weren't a run flat, I would not drive 50 feet on a dead flat tire - rim damage almost immediately.
2002 325i sport - sold 2009 135i M sport - sold
2009 550i M sport - sold 2005 M3 6MT Jet Black w/Cinnamon 2016 F30 320i ZSP 2003 E46 325it ZSP 5MT Last edited by metallicpea; 06-30-2017 at 07:12 AM.. |
06-30-2017, 09:14 AM | #9 |
Rep 74
Thanks to everyone who replied. I took the wheel off and had it replaced with a used tire with matching wear to the other 3. I hit a bump in the road. I did not see a pot hole. I was thinking of taking it to the dealer to try to warranty it, but assumed that would be hard to prove. Now I'm second guessing my decision since a previous reply was able to get their money back.
06-30-2017, 09:49 AM | #10 | |
Rep 4,210
On the other hand, I had a recent experience with my BMW (not related to tires) and used the service manager as my ambassador and it helped. So...working through one's dealership might help. |
06-30-2017, 09:55 AM | #11 |
Rep 1,329
I'm not sure the specifics of the new car warranty with tires, but that looks like a pretty good whack. Probably a road defect you didn't see. Tire defect is unlikely. So unless you have road hazard warranty, you could try, but I would say, "**it happens" and move on and not feel bad you had to pay for a used tire.
Just trying to stay inside the intent of the type of warranty you have. Even though people will try to get anything they can and I understand that, as companies always try to take anything they can, but sometimes it just isn't worth the argument if it is likely not a defect anyway. Glad you could get it resolved with no additional cost or damage than was already done.
2009 550i M sport - sold 2005 M3 6MT Jet Black w/Cinnamon 2016 F30 320i ZSP 2003 E46 325it ZSP 5MT |
