06-11-2015, 03:57 AM | #1 |
Rep 308
chargepipe and exhaust
i have some questions regarding the chargepipe and exhaust from downpipe to the end, and maybe stage 1 piggyback. Its for n20 engine.
After these mods, is it OK to not have it tuned? Or getting it tuned is absolutely necessary? I wonder if not getting it tuned would cause the car to run rich or something. I know getting it tuned brings the most power out of each mod but the budget won't allow it yet.
F30 328i sedan
06-11-2015, 07:00 AM | #2 | |
Rep 1,490
A chargepipe (imo) is pointless without a tune. The stock one should be fine for stock boost. Even a Stage 1 tune, it is not necessary. A downpipe + exhaust will give you some more power, and a lot more noise. But a tune would be able to utilize those mods better. If you can't afford a $300-500 tune, 1) why are you driving a roughly $40k car? 2) save your pennies for the tune before doing other mods. you will notice the most benefit with the tune first and supporting mods will be at their full potential
Current: 17 Mustang GT no bmw
Gone but not forgotten: 07 E90 335I, 04 UA6, 95 E36, 04 EP3, 16 S550 EB, 14 F30 328I Stg 1, 08 E90 328I |
06-11-2015, 09:34 AM | #3 | |
Rep 308
I was talking about ecu tuning which is more expensive then stage 1 piggyback.
I thought with ecu tuning, you can make fine adjustment rather than just upping powering. so i guess my question is, after downpipe+exhaust, chargepipe, and maybe intercooler, is it necessary to put the car on dyno and smoothen out the curves using ecu tuning. Quote:
06-11-2015, 11:47 AM | #4 |
Rep 190,975
No need for an ECU tune.
If anything the Piggy at this stage is a lot more powerful and has more features than the ECU tune. If you are looking for sound, get an exhaust If you want power, start with a JB4 + CP + Catless DP + FMIC. In this order. If you do not want to get catless DP, get a stage 1 instead of the JB4.
06-12-2015, 02:11 AM | #5 | |
Rep 308
i thought that if i'm changing either CP or FMIC then why not change them out at the same time. Do you think these would work without having to worry about running the car too rich or too lean? And this setup would bring pretty good amount of power?
F30 328i sedan
06-12-2015, 12:13 PM | #6 | |
Rep 190,975
Changing the intercooler and charge pipe at the same time is a very good idea. You probably want to also add the turbo to intercooler charge pipe to as well. If you are getting a DP, you should get the JB4 instead of the stage 1
06-12-2015, 01:14 PM | #7 | |
Rep 265
Drives: 2014 328i AW
MODS: afe intake, afe scoop, afe scorcher module, 19" AG M580's, H&R Sports, AWE Tuning exhaust, LED conversion,wrapped interior, msport steering wheel, msport aero kit
06-12-2015, 01:20 PM | #8 |
Rep 308
i did a search and it says that i could get the CEL canceller which would only cost like $20. would that work?
F30 328i sedan
06-13-2015, 01:08 AM | #9 | |
Rep 18,723
Also, keeping the car ECU on learning mode on every reset, which causing the car not running fully optimized. I would just leave the CEL light instead of spending $20 and the hassle. It does the same thing but with the engine will be optimized. Regarding your mods, I would do in this order: - Chargepipe (since I wouldn't want it to break, because it does break under stock boost) - Tune (RaceChip Ultimate or BMS Stage 1 if you are not planning for catless downpipe, but BMS JB4 Stage 2 if you are going with catless or just ignore the light) - Catless downpipe - FMIC (I put this in last since the stock one is sufficient enough. But would be better if you got the budget to do it. Ideally, labor wise would be more cost efficient to do it together with the chargepipes). Good luck and I hope this help answer the question.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
06-17-2015, 02:23 PM | #10 | |
Rep 232
Some folks would argue money spent on making your car more reliable is always the best money spent and strengthening components that receive additional stress from other mods before those mods are installed should be prioritized.
2016 528i Msport/Premium/Drivers Assist II/ACC/Cold Weather/Harmon/Pwr trunk
2012 Kawasaki ZX10R ABS 1978 Honda CB750k, 1977 Yamaha XT500 1975 BMW R90/6 & 1969 R69S |
