06-13-2015, 01:55 PM | #1 |
Rep 577
N20 Boost Leak Testing
Hi Guys,
So I got the GSR Autosport Stage 1 Flash tune for my 328i N20 (MY14), and I almost immediately got CEL P0234 - "Turbo Charger Over boost condition". Following that I developed a boost leak, or at least that's what I think it is. I never had one with my Piggyback, so I guess the flash is pushing more boost. I should add, I have an ATM FMIC, ER Downpipe and AFE Momentum intake. I did have the Treadstone chargepipes, but I suspected they were the source of the leak, so I'm back to the stock ones. I will be installing the ER Chargepipes when those arrive. Anyway I got myself a boost leak tester, and plugged it onto the turbo end of the Hotside Chargepipe (leaving the other end connected to the intercooler). Only when I attached my tire compressor to the tester and fired it up, it never built any pressure, whatsoever... So, I started trying to work out what could be happening, and while looking around the various connections it occurred to me that the pipe that attaches to underside of the cold side charge pipe just before the bend and throttle body runs across the front of the block and connects back to the intake before the turbo, so I think the air is literally just flowing back to the intake and out. I checked and there aren't any one-way valves or anything, therefore nothing to hold the air in the cold side chargepipe. So now I'm thinking I'm going to have to connect the tester to the Intake pipe at the joint before all those other diverter and cold side return pipes connect. That way they're all under the same pressure. The turbo would also then be under that pressure, as would both sides of the diverter (so I wont be able to tell if the DV is leaking). Has anyone successfully done a boost leak test on an N20? If so would you mind sharing your method? As mentioned I do suspect that if the chargepipes arent the source of the leak, that the Stock Diverter valve may well be, since apparently it is very common on the N55 as well as many 2ltr VW/VAG engines. I have bought the GFB DV+ for the N20 (T9357), but upon further review, it is very difficult to install on the N20. The reviews for the DV+ are terrific from people running them. Pure Turbos is running them on the N55 and gave it a thumbs up. I'm confident it will be great for the N20 too with the added boost from the GSR tune, if only I could figure out the install. That said I definitely want to confirm that the leak is not coming from something else, before I install the DV+. Appreciate any help guys! |
06-13-2015, 05:02 PM | #2 |
Rep 1,436
very interesting. Good luck in finding that leak man, I took a log on stock map and found that car overboost most of time. hits 19 psi as normal and are that time it hit 22. it scared the shit out of me !!
06-14-2015, 05:56 PM | #3 |
Rep 112
When I took my car to the dealer a couple weeks ago to replace a failed mass airflow sensor, they performed a "smoke test" to ensure no leaks in pressure anywhere in turbo system
06-14-2015, 10:35 PM | #4 | |
Rep 577
There are so many place that there could be a leak, and pressurizing the inlet may actually not work since it's not designed for positive pressure. Really don't want to have to remove all my boltons so I can take it to the dealer, but may have to... |
06-22-2015, 07:52 PM | #5 |
IG @bmwF9xG80
3812
Rep 7,593
Stubok how is it going ?
How come you didn't go to Eurocharged?
60-130mph 6.5s X4M #HCP
06-22-2015, 08:17 PM | #6 | |
Rep 577
I'm almost at the point where I'll put the Stock intercooler and downpipe back and take it to the dealer to diagnose. Wish I new how to do a smoke test. Would love to be able to rule out a boost leak. Though I guess a smoke test wouldn't rule out a faulty Diverter Valve, which I suspect is at fault. |
06-22-2015, 10:02 PM | #7 | |
IG @bmwF9xG80
3812
Rep 7,593
06-23-2015, 12:02 PM | #8 |
Rep 577
Not totally certain it's the same as Goon's.
When I first drove with the flash, I got a cel (P0234 - Turbo/Super Charge Overboost Condition). I spoke to GSR Autosport and they now have an updated flash that prevents this overboost issue. So I will be sending it back for an update. My main concern now is that as a result of the overboost, I either caused a leak in the charge pipes/system or worse damaged the stock diverter valve. Apparently BMW list the replacement of the DV as a 6.5 hour job. I know because I looked at changing the stock DV with GFB's DV+ and learned this the hard way ($280 later). Basically it's impossible to replace without pulling the entire exhaust manifold/Turbo assembly. In any case I'm going to try get a smoke test done (with bolton's), to see and rule out a boost leak. Then it will either be the DV or the tune. I never got this before with my Piggyback. So know they didn't misbehave or leak before the tune. The price you pay for being a pioneer... Still I'm 100% confident GSR will stand by their product and customers. |
07-01-2015, 05:57 PM | #10 | |
Rep 577
Smoke test is my project for this weekend. |
07-01-2015, 06:20 PM | #11 |
IG @bmwF9xG80
3812
Rep 7,593
Stubok when you were getting the OverBoost issue did you by any chance have a obd2 dongle connected doing data logging or checking to see how much boost the car was producing?
I' want to see how much boost the car is producing then.
07-01-2015, 10:08 PM | #12 | |
Rep 577
07-02-2015, 01:11 AM | #13 | ||
Dream crusher
984
Rep 2,421
535i MIssion Performance, PS2, Helix HPFP Kit, Wagner FMIC, Spec 3 clutch, Steel SMF, Wolf Racing CP, UUC SSK, GFB dv, SprintBooster, Custom Dynomax Exhaust, M5 Sways, Eibach OE Springs, Koni Sports Adjustable, Custom Short Ram CAI
IG: @bmwdoubles |
07-02-2015, 08:40 AM | #14 | |
IG @bmwF9xG80
3812
Rep 7,593
For the N20 engine the 19.7 is pretty low(safe), I'd say max 21-22 for the N20 for long-term reliability but also depends on the mods of the car.
07-02-2015, 09:35 AM | #15 | ||
Rep 577
Clean or replace your MAF - apparently this has been a serial offender to rough running. Especially if you have run an intake that has an oiled filter. Oils carry over can coat and really cause issues with the MAF. Expect it to run a little rough when re-installed or first replaced while the ECU adjusts AFR. Check your coils. Good chance one or two are weak. Get a smoke test done. If you're running more boost there is a good chance you have a charge pipe leak. On the N55 apparently it is much easier to replace the DV than on the N20... Sigh |
uncleruckus129.50 |
07-07-2015, 01:38 PM | #16 | |||
Dream crusher
984
Rep 2,421
Not so much in 4-6 gears for some reason. 2-3rd are leaky I just order the DV+. Do you have a link that shows how to install on the N55? Keep us posted on your findings. Here's the I started for my leaks. We don't get much traffic over there :/ http://f10.5post.com/forums/showthread.php?t=1147538
IG: @bmwdoubles |
07-08-2015, 07:25 PM | #17 |
Rep 577
So I finally installed my DV+
It definitely behaves a better than the stock one. It really does do what they say it does. If you install it with their piston spring, the lag goes way down and boost is held so much cleaner than before. I guess that's because there is no leakage from it like there used to be from the stock one. I will write up a DIY and post some pics of the install. It is very fiddly, and very time consuming. Oh and now I know my boost leak is not my DV. The stock one was fine bye the way. Which means my smoke test is even more important now. I reckon one of my Chargepipes (remember I'm back on stock ones while I wait for the ER ones) is leaking or one of the seals between the joints. We shall see! |
07-11-2015, 09:01 AM | #18 |
Rep 265
Drives: 2014 328i AW
my guess is it's the tune. this is the same issue I was experiencing. you should try flashing back to stock
MODS: afe intake, afe scoop, afe scorcher module, 19" AG M580's, H&R Sports, AWE Tuning exhaust, LED conversion,wrapped interior, msport steering wheel, msport aero kit
FSociety3811.50 |
07-11-2015, 09:24 AM | #19 | |
Rep 577
07-11-2015, 01:44 PM | #20 |
Rep 3,258
Drives: 2015 F36 Jet Black Sport Line
Interesting. I hope it's not tune related and just a weaklink as described.
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint| |
07-13-2015, 03:31 PM | #21 |
Dream crusher
984
Rep 2,421
Same I hope it's not the tune either. Keeps us posted.
IG: @bmwdoubles |
