03-02-2017, 02:01 PM | #1 |
Rep 1,201
Will the disks need attention??
Noticed this mark on my drivers side front disk:
Car has not even been for it's first service yet and done just over 15k miles. I ran my finger over it and I cannot feel it but it won't rub off either. Bit crap if I need to get the disks and pads replaced at it's first service (not covered in service pack) What's your thoughts people?
Current - 2021 G20 330i M Sport+
Gone - 2017 F30 335d M Sport + in San Marino Blue Gone - 2015 F30 LCI 320d M Sport+ Step Auto Gone - 2012 F30 320 ED Gone - 2011 E87 118d |
03-02-2017, 03:01 PM | #2 |
Rep 541
Something must have got trapped behind the pad to cause that. Whatever made the mark, I would say you should have the pads removed to check there is nothing there. If all is OK then it should fine to put back together. The mark will eventually wear out. Definitely not worth replacing an entire disc for that, especially as they should be replaced in pairs, with new pads... expensive.
If it did not go away or got worse then you would need to replace them. |
stu14t450.50 |
03-02-2017, 03:10 PM | #3 |
Rep 834
If it doesn't catch your finger nail then it will probably get scrubbed off by the pads in a few hundred miles. I wouldn't be surprised if this is down to a very small piece of tarmac that has been trapped/embedded in the brake pad at some point.
Worst case you could have the front discs skimmed on the car. They only take a very small amount of material off with a very fine cutting tool.
BMW X1 sDrive20i ///M Sport MHT
stu14t450.50 |
03-02-2017, 03:16 PM | #4 |
Rep 1,409
If you can't feel it, then whatever piece of road gravel that has got between disk and pad will probably not be on planet earth any more. I'd guess it will have had a negligible effect on the braking power, though front brakes do most of the work.
Your car will be serviced soon. You could mention it, but the cost of taking the pads off and maybe replacing sets of pads seems a bit overkill. |
03-02-2017, 04:47 PM | #5 |
Rep 1,201
It's some relief to hear that it's probably more superficial than damage to the disk.
The winter wheels will be off in a month or so, I'll take a closer look then. Might take the caliper off too.
