02-24-2024, 06:42 AM | #1 |
Rep 84
Broken head wheel anti theft lock nut
Hi guys.
Yesterday I reinstalled the front left wheel and I broke the lock nut head; I mean, the nut is screwed on the wheel, but the head has fallen apart. Just to explain, I’m in the same situation as per attached image. The only difference is that my nut is screwed in the wheel. What to do now? Any chance to reinstall the head or remove the nut to replace? Thanks |
02-24-2024, 08:34 AM | #2 | |
Rep 303
THINKWORK Lug Nut Remover, 6 Pieces Wheel Lock Removal Kit for Removing Stripped, Damaged, Frozen, Rusted, Rounded-Off Bolts, Nuts & Screws https://a.co/d/3VmddAW Just to add, I removed the remaining 3 and replaced them with non-locking bolts. |
02-24-2024, 09:40 AM | #3 |
No 55mph
1622
Rep 8,476
AGA Tools Wheel Lock Removal Tools
https://agatools.com/products/aga-wlrt Little expensive, but has everything you would ever need to even remove lock lugs with the spinning head...
02-24-2024, 12:10 PM | #4 |
Rep 84
02-24-2024, 12:21 PM | #5 | |
Rep 303
I hammered the extractor on with a mini-sledge and with a decent sized breaker bar (think I said pry above), the bolt came right out. I've attached an image of what I was left with. |
