06-26-2014, 02:17 PM | #23 |
Rep 205
Well I only have enough funds for 1 car, not to mention one spot in my parking deck. That being said, i only drive about 6-8k a year so not much. Do you guys suggest it as a second or third car simply cause it's somewhat fatiguing to drive? I know even in my f30 with the tune, sport+ can be considered 'harsh' to some, I'd imagine that the m3 is only that x10.
'13 328xi M-Sport
Black Sapphire Metallic, M Sport, Technology, Lighting Package, DHP, Harmon Kardon, Sport Auto, Heated Front Seats |
06-26-2014, 02:33 PM | #24 |
Rep 2,023
06-26-2014, 02:34 PM | #25 |
Rep 190,721
I never said its a bad thing.
Im a big fan of the e46 M3, im just stating that the 2 cars are completely different in terms of feel and power delivery.
06-26-2014, 03:31 PM | #26 |
Rep 2,023
Fair enough, but you did list in a list of negatives so was reasonable to assume you thought it was a negative.
06-26-2014, 03:35 PM | #27 |
Rep 962
I would opt for a new car if funds allow it. A car that has been around for 10+ years will have rubber seals and gaskets deteriorating everywhere. In fact, I've always been skeptical of old BMWs with low mileage. These cars are meant to be driven and the more they sit the faster they age.
For example, I can almost guarantee that if you leave an 8 year old BMW sitting in the garage for 3-4 months it will have a leak from the oil filter housing gasket when you start it again. |
06-26-2014, 03:53 PM | #28 |
Rep 1,730
I'm currently trying to find an e46 for a track/weekend car. Keep in mind those cars have trouble with rear subframe mount cracking, vanos needs maintenance, stay far away from the smg, you'll want zcp. Cooling system can go. I'd figure on a nice 20k e46, you should probably expect about 1.5-2k of maintenance annually, which will skyrocket if you don't know how to wrench. Kind of the ultimate enthusiasts vehicle imo, especially if you take it to a track.
06-26-2014, 03:58 PM | #29 | |
Rep 205
'13 328xi M-Sport
06-26-2014, 07:36 PM | #30 |
Rep 4,341
Ok, I have a 2003 330i ZHP, very similar to your M3 except for the motor. Here is what you need to be prepared for.
The cooling system will fail regardless of miles. It gets brittle. If the current owner hasn't done it, you should replace the radiator, expansion tank, hoses, thermostat, water pump with a new BEHR or OEM items. I did it on my previous E46 using the OEM parts or even dealer parts if you wish. I had a trusted independent do it. You will have to adjust the valves every 15K miles. Make sure the M3 was inspected by BMW for the subframe cracking recall There are couple of valves that get old with age regardless of miles but you drive low miles and the car will be rewarding. Yes, a new car always makes a better daily driver from the reliability perspective but the E46 is pretty well built as long as it was taken care of. It is also very desirable car especially as all the new cars are turbo charged, many miss the visceral sound and throttle response of NA motors. Make sure you change the and trans oil regularly too. |
06-26-2014, 07:46 PM | #31 | |
Rep 1,730
Regarding engine VANOS issues, you'll need to have the valves re-shimmed every 20-50k miles, depending on how hard you drive it. A new VANOS unit for the S54 will run you 2.5k at the dealer, maybe you could get it done for 1.5-2k at an independent using "Dr. Vanos" (whatever the hell that is, heard the e46 guys talking all about it at the BMW event I went to). Inspection II is a major maintenance milestone. Oil changes need to be frequent and always use the correct oil. The subframe mount cracking is the biggest issue with the e46 M3, especially if the car is driven hard. Apparently it's not an if, it's a when. All solutions yield potential new issues down the road, such as rusting due to welds etc. I personally wouldn't get this car if you don't know how to at the *very* least do your own maintenance and minor replacements. Otherwise you will get *killed* at the dealership with all the little bushing replacements and other odd ends that are $200 part jobs that cost $800 at the stealership. Even with a "pristine" low mileage/high priced/single owner car, you're still getting into a car that should be worth about 15k if it was driven normally. You won't have a turn key race car unless you really know your shit. The other option which I've been considering is just getting an e36 M3 weekend/track car, they're really light and can be found pretty cheap (maybe 7k for ~120k miles, decent shape), only caveat is NA got stuck with the POS de-tuned S50/S52, which are fine motors for driving around town, but lack all of the red-line HP that ///M engines are legendary for. Definitely the black sheep of the M3 family. |
06-26-2014, 08:01 PM | #32 | ||
Rep 1,730
Not sure what price point you can start to talk Porsche. But I can see that being a more special drivers car, but it would still be incredible to get into that S54, with proper setup I'm sure it would be hard to find a faster hpde car for the price. |
06-27-2014, 09:01 AM | #33 |
Rep 1,003
I looked at E46 M3s as well. Since I have an E30 it doesn't make much sense for me. If it's your only car and you don't do more than 10k miles/yr I could see replacing an F30 with it.
The quality is good but hasn't stood the test of time so well. Better than E36 but not better than E30 - due mainly to additional technology and luxury features. One thing sticks in my mind, the creaky door armrest. Yes it can be fixed, but my old E30 is rock solid with zero creaks and it's on stiff coilovers. Plenty of plastic in the E46. I disagree on needing ZCP, especially if it's your only car. I'd rather have the multifunction steering wheel with durable leather and put ZCP wheels on later. I also disagree that it's "not fast" by today's standards. 0-60 in 4.8 seconds and low 13s in the 1/4-mile are fast numbers. This is a car that will, realistically, keep up with F30 335s and brand new S4s (when equipped with 6MT). |
06-27-2014, 09:39 AM | #34 | |
Rep 205
'13 328xi M-Sport
06-27-2014, 10:41 AM | #35 | |
Rep 1,003
I love a fast car, but although I'm still young I don't find myself willing to sacrifice the comfort. I am amazed by my stock N20, and I gotta believe the stage 1 power is great. But, I use my F30 in such a way that comfort takes priority. I have the E30 for when the mood to race around in a 6-cyl touring car strikes me. The thing to note in my mind is that while a very fast car, the S54 isn't very torquey, and it's not very alive when you're just driving around town below 3-4k rpm. It's good, but not great. It won't feel much different than the N20 (and perhaps it'll feel slower) until you really open it up. I'm 9+ months out of the E46 market, but here's what I'd suggest. If this is the perfect color combination for you with the right options and the car really checks out, $23.5 seems like a really great opportunity. Enthusiast auto group is driving prices sky high, and the number of clean 6MT examples is dropping. Your F30 has likely depreciated a fair amount, maybe not a ton but it's on a slippery slope. The E46 M3 is not. Given that you don't do a lot of miles and it's your only car, I would lean towards the E46. Retrofit the iPod connectivity and I think you'll be just fine without HUD and a hi-res screen. Pay it off then go get a modern BMW if/when the need arises. But first, you need to drive one. |
06-29-2014, 11:07 AM | #36 | ||
Rep 205
I may see if I can get agreement at $20k which may be a stretch and then have both for a bit and get rid of the f30 if things go well with the 46 otherwise probably just keep the 46 for the thrills
'13 328xi M-Sport
06-29-2014, 01:25 PM | #37 |
Rep 190
Having owned both an E46, and now a F32, I highly recommend going with a F3X.
I have also owned a '03 CL600 Brabus (yes it was a Brabus), and I know for a fact that as a DD that my F32 435i is a better car than my E46 and Brabus. Sure my F32 isn't as analog and as small as my E46. However, on a day to day basis my F32 rides like my Brabus on the comfort side but is somewhere between the Brabus and E46 on handling. As for the power the Brabus could not get the power to the ground very effectively (Because: Torque!), and being N/A in the E46 could not get up to speed unless you were high in the RPM's. Turbo's are amazing with power delivery! The one downside is that I miss is the sensation of speed (rev'ing through the gears and having a loud exhaust...I don't have a exhaust on the F32, but Eisemann sounds amazing!), and as a result to my N/A and slow throttle, I was not getting anywhere fast. If you want a fun car that can be on the track or in the canyons get a miata, S2000, or a z4 (M?) and keep the F3X as a DD. Also I highly recommend the F32 over the F30 unless you have people in your car consistently, because the back seats in the F32 can fit me in the back comfortably (I'm 6'1"). As for a F22 I have only driven a m235i, but wasn't impressed with the comfort in it. If I would want something similar to the F22, I would have gone back to the E46 and saved a lot of money. |
06-30-2014, 04:12 PM | #38 | |
Rep 205
'13 328xi M-Sport
