10-16-2014, 01:02 AM | #1 |
Rep 70
F32 M Sport Dynamic Suspension + aftermarket coilovers
Hey guys,
Is it feasible to retain the m sport dynamic suspension settings (normal vs eco vs sport) with aftermarket coilovers so i can adjust the ride height? If so, what is needed in terms of parts and service? Thank you in advance for your progressive inputs. |
10-17-2014, 03:20 PM | #2 |
Rep 70
Sorry, here's to clear some confusion..
Objective: Retain DHP + lower vehicle Could the dynamic handling package functions be retained from aftermarket coilovers? or only with aftermarket lowering springs? |
10-20-2014, 08:24 PM | #3 | |
Rep 282
You can find the part numbers if you use KW's German web site. Cheers, |
10-21-2014, 11:22 AM | #4 | |
Rep 102
2015 BMW M4 Mineral White
2018 Audi RS3 ? on the way |
10-21-2014, 11:30 AM | #5 | ||
Rep 282
Cheers |
10-22-2014, 07:46 PM | #7 | |
Rep 282
10-23-2014, 02:26 PM | #8 |
Rep 70
Found the KW DDC plug and plays for the 435i coupe. sorry, no love for the x-drives =/
http://www.turnermotorsport.com/p-20...-with-edc.aspx |
10-23-2014, 09:51 PM | #9 | |
Rep 282
Thx again |
11-01-2014, 08:07 PM | #13 |
The Ox
91
Rep 319
11-02-2014, 01:47 PM | #14 |
Rep 282
Thank you PSA55. I think that Dinan will be the best solution for me too. Their web site says they have springs for the 435, but not the 435x-drive...
11-29-2014, 12:33 PM | #15 |
Rep 62
Hey OP i am in similar situation as i just purchased a 2015 435i xDrive M Performance edition and i want to eliminate the wheel gap and drop it a bit but from reading through the forums the spring method seems hit or miss as it just compromise the ride.
I am very new to the forums and and making any suspension modifications and my understand is with the DHP system on the car the dampening of the shocks adjusts depending on your driver mode selected (comfort/sport) and if you installed KW V1 you would lose that auto adjustment but they make a V3 that will retain this feature and lower your car? I have attached the link below for what i think is the write set, let me know if this looks correct.. http://www.kw-store.com/products/kw-...it-v3-299.html Any advice or info from anyone would be greatly appreciated. |
11-29-2014, 04:48 PM | #16 | |
Rep 713
I believe even the DCC sets still function independently of the BMW system and require a button to be installed to provide three different suspension settings, unless they've recently changed and now can be integrated.
01-10-2016, 11:43 PM | #17 |
Rep 902
Drives: 13' F30 385xi VNV Speed Custom
Garage List 2013 Mercedes SL63 ... [0.00]
2010 VW Tiguan 2.0 ... [0.00] 2015 Tesla P85D [0.00] 2014 Mercedes S63 AMG [0.00] 2007 Mercedes GL450 [0.00] 1967 Ford Mustang [0.00] 2013 BMW F30 335xi [0.00] |
Re opening this thread because KW does make a DDC EDC plug n play for the xDrives now.
http://www.turnermotorsport.com/p-20...-with-edc.aspx I'm on the edge of my seat to get them but haven't found a single review yet. Might just talk to TMS to see if they have an opinion since they're one of the few us vendors who carry it.
13' 335xi, ACF Tuned, ACF Stage 3 Turbo Kit (67mm),PDU PI, ACF Stage 4 LPFP, M-Perf Brakes, AEM CM10 Meth/Nitro, CG DR-1 + VS-1 3.5" Turboback, AFe S2 CAI+Ram Scoop, ER Chargepipe, Wagner EVOII Comp. FMIC, Stop-Tech SS Brake Lines, BMS Sport Oil Cooler Valve+Spacers F10mm R15mm, 19" Bridgestone Potenzas, KW EDC Coilovers, CF Seibon Hood + CSL trunk. Track:Pagid Race Pads, Stop-Tech Custom Pads Front+Rear Racing Tow Hooks
01-27-2016, 06:04 AM | #18 | |
Rep 2,410
Drives: E30 M3 Cecotto, F85, G05, G07,
01-27-2016, 09:36 AM | #19 | ||
Rep 902
Bilstein didn't even touch the whole F3X platform with their own EDC plug n play systems like they do for the F10 etc. I ordered my coils and their on backorder from KW in Germany. So just s couple weeks and I should have mine in
03-30-2016, 11:35 PM | #21 | |
Rep 902
I have the Plug n play DDC set and they've been great so far, just need to get my Dinan shockware reflashed for free and then I think they'll really be exactly what I want. I previously had factory EDC with Dinan springs and shockware, and even without shockware the KW's blow the Dinan springs out of the water. I only want to get my Dinan Shockware reflashed since I paid for it already, and the last BMW stealership I visited purposefully wiped the flash when coding my brakes.
03-31-2016, 08:32 AM | #22 |
Rep 68
Ah thanks for the clarification. I don't need the WiFi connected app to change my settings on the go. I'd prefer doing the switching via the DHP BMW factory buttons and just having 3 settings pre-setup.
Does the Dinan Shockware make noticeable difference ie. worth purchasing? |
