BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > 2013 bumper removal guide
Studio RSR
      01-24-2016, 08:09 AM   #1
sandpiperx1
Still Learning!
sandpiperx1's Avatar
Drives: 2013 328I f30
Hello
I am looking to replace my front headlights on my f30.
Can anyone guide me to a thread or other source with some instructions to remove and put back on a front bumper and or replace the Headlights.
I want to handle the work. Is it worth the effort or sent off to a shop.
Any input would be great.
have a great day.
m
      01-25-2016, 01:18 PM   #2
sandpiperx1
Still Learning!
Bump
      01-25-2016, 07:47 PM   #3
RarScaryFrosty
Drives: 2013 328i xDrive
This one helped me out when I replaced my headlights with aftermarket ones. It took me some time to understand, but getting down and dirty and working on it myself helped too. All together it took me maybe 5 hours from start to finish to do everything. It's perfectly do-able with one person. I've never done anything like this before but still was able to figure it out. Just maker sure you have the exact tools listed in the instructions, otherwise you'll be in trouble! A good mechanics socket set and a screw driver bit set is all you really need.
http://f30.bimmerpost.com/forums/sho...d.php?t=707251
      01-26-2016, 05:27 PM   #4
sandpiperx1
Still Learning!
Thank you RSF.
I have all the tools needed. We work on my trucks alot here. How was it as far as getting the headlight units out once the bumper was off? Just trying o make sure I have all the info before I started down this row. again I appreciate the help .
have a great day.
      01-26-2016, 07:00 PM   #5
RarScaryFrosty
Originally Posted by sandpiperx1 View Post
Thank you RSF.
have a great day.
The clips for the headlights are hell to remove. There's no sane or easy way. You'll just need to pray that the bolt isn't over tightened. New headlights will usually some with replacement clips, otherwise they're a few dollars a piece via getbmwparts.com
I was able to remove a few of the clips easily, while I cut the bolt in the others with a dremel since they seemed seized too tight.
