BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > USA - NY / NJ / CT / PA > *SOLD* CG Precision VSC-1 Exhaust Valve Controller
      05-25-2020, 09:27 AM   #1
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
Drives: F32 435ix MSport
Arrow *SOLD* CG Precision VSC-1 Exhaust Valve Controller
I Have FS:
(1) CG Precision Exhaust Valve Controller VSC-1
Purchased Fall of 2019 to use on my MPE - now that I have switched to AWE Exhaust I have no need for this
> Can be used on ANY exhaust system that utilizes the Factory Exhaust Valve Controller
> EZ Install - simply bolt unit under factory muffler hanger on DS using existing nut, plug stock Exh Control Valve car Connector in to unit, plug unit in to factory Exh Valve Controller
Unit can be programmed to activate from one of your Homelink Buttons, or by using the remote
I have used one of these on several BMW's I own(d) very reliable and a quick way to gain control of your exhaust valve at all times
> DEFAULT Setting - Automatic (Factory Control)
> ACTIVATED Setting - OPEN
This currently goes for $199 from CG Precision...
https://www.cgprecision.com/#!/VSC-1...egory=17975132
SOLD - Thanx!
No Worries Dealing with Me - Check My iTrader/Long Time Forum Member
I Will Entertain Offers - But Lowballers Will Be Ignored
Includes:
  • VSC-1 Control Unit
  • PNP Wiring Harnes
  • Qty. (2) Remotes
From the Mfg:
  • Make your vehicle as loud or as quiet as possible with direct control of the exhaust valve.
  • Direct plug-and-play for F30, F32, F87 M2*, G20**, and more!
  • Control the exhaust valve with the included remotes or the HomeLink system.
  • Easy to install and remove, includes CNC laser cut mounting bracket and all required hardware
  • Designed for most vehicles with the N20, N55, B48 & B58 engines.
  • Compatible with many exhaust systems including CG Precision VS-1 catback, stock and more!
On with the Pics:
      05-28-2020, 02:25 PM   #2
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
SOLD - Thanx
