05-23-2018, 08:45 AM | #45 |
Barge driver
8656
Rep 12,425
Whether taking it off or not, if your engine goes bang then they will check and find out, they are not fools and know people fiddle with these cars it's all here for them to read.
Hence Audi brought in the TD1 flag.
730d/Z4C
05-23-2018, 09:00 AM | #46 |
Rep 1,446
Yeah not disputing that - you're rolling the dice and best to go in with your eyes open. The tuning boxes (once removed) are less obvious, but then I was lucky and had a DME replaced on a mapped car previously. If they decide to look though, you're probably onto plums.
Gone: G05 X5 40d M Sport, F15 X5 30d M Sport, F30 330d xDrive, F21 M135i, E87 123d
05-23-2018, 12:42 PM | #47 |
Barge driver
8656
Rep 12,425
The other thing to be mindful of is if you're on a PCP and BMWFS find out you've remapped the car they will issue a default on the contract screwing up your credit file.
730d/Z4C
05-23-2018, 01:57 PM | #48 | |
Rep 45
True, but a remap is better for the car. Performs a lot better. I’d be really interested to see vbox data for a 335D with a tuning box. I myself have a remapped F30 335D and the vbox numbers speak for them self. 0-60 in 3.7 0-100 in 9.3 1/4 mile in 12.1 Now that I’ve added an intercooler, and revised remap: 0-60 in 3.6 0-100 in 8.9 1/4 mile in 11.9 Depends if your motivation is to get the best performance from the car, or if it is resale. That’s the only benefit I see. My car has been in for both a full major service/vehicle inspection and warranty work all whilst being under 3 years old and remapped! The warranty work was on the wheels so unrelated, but it still went through diagnostics and had the idrive updated as part of the service etc too. Nothing noticed, nothing said. Map was still on the car when I picked it up. |
05-23-2018, 02:20 PM | #49 | |
Rep 28
The way I see it, if you want ultimate bang for your buck then get a remap. If you want slightly more peace of mind, like I do, then get a certified/approved module (as has been stated previously in these forums, the Steinbauer is essentially the same module as the ACS kit but with a very slightly de-tuned map). I’m more than happy to go with the SB, even if it does cost twice the price. |
05-23-2018, 02:31 PM | #50 | |
Rep 45
I can see your point but a proper remap wouldn’t push the car beyond its own internal limits. A proper remap shouldn’t interfere with the safety measures/sensors either. If anything, even a bad remap should at least still trigger safety sensors and throw it into limp mode to prevent any damage. Tuning boxes aren’t without issues - there’s probably not far off the same amount anecdotal negative feedback about them as bad maps. I don’t know too much about those boxes, but don’t folks say they trick the ecu by sending false signals/asks for more fuel to it to get more power? Surely that can’t be as refined or customised to the individual car as a dyno developed remap? |
05-23-2018, 02:44 PM | #51 | ||
Rep 32,881
05-23-2018, 02:50 PM | #52 | ||
Rep 2,271
IG: project540ix
G30 540i xDrive / Stage 3 via BM3 / xHP Stage 3 / Pure 800 Cast Turbo / 5" Catted Downpipe / MST Intake / Remus Exhaust / MSS Springs / 19" JR SL01 & Conti SC7 / 20" BBS CI-R & Michelin PS4S / F90 Sway Bars & Braces / Lots of Gloss Black |
05-23-2018, 03:25 PM | #54 | ||
Rep 28
Here’s a link to the Steinbauer PowerModule info sheet from their main UK distributor, Coord Motorsport - http://www.coordsport.com/attachment...werModules.pdf Last edited by Willsy33; 05-23-2018 at 03:41 PM.. |
05-23-2018, 10:42 PM | #55 | ||
Rep 7,484
What made you decide the standard one was not cut out for the job? Thanks |
05-23-2018, 11:31 PM | #56 |
Rep 1,721
05-24-2018, 02:09 AM | #58 | |
Rep 45
Virtually every tuner seemed to break 400 rather easily with a Wagner intercooler and a tune - up and down the country, where as with the standard cooler, the results were typically 10-15 bhp lower. I have at least 10-15 unique examples of dyno runs from various companies showing this consistent gain. The record holder for the fastest F30 335D 1/4 mile in Europe also uses a Wagner Intercooler. 2 and 2 together - that’s why I went with it. Also at the 1/4 mile, lots of folk always keep their bonnets open to try and reduce heat soak and aid cooling. The Wagner reduces temps by half so should help with that, right? This should make for more consistent runs. I went from a consistent 9.3-9.4 0-100 mph time to a consistent 8.9-9.0 time afterwards. How much of that was the new map vs the cooler, not so sure. My tuner said the cooler definitely helps. I went with a Wagner Competition Evo2. The European 1/4 mile record holder has a Wagner Performance Evo2 which is slightly cheaper - so this will be more than enough for anyone. I just went with the Competition as it was like 2 kg lighter and my rational is that if I go to the efforts of emptying the boot of a few kgs at the 1/4 mile track - I may as well be conscious of the few kgs difference between the two coolers too. |
Soul_Glo13346.00 |
05-24-2018, 02:45 AM | #59 | ||
Rep 7,484
05-24-2018, 04:50 AM | #60 |
Rep 2,495
That's not true at all, BMW FS cannot default you unless you miss 3 payments in a row. They can seek to repossess for modifications that do not adhere to their T&C's but highly unlikely.
Arrived! 2022 X4M Competition, SPY + Black Merino
Gone: 2019 X3M Competition, Toronto Red, Adelaide Grey. |
05-24-2018, 04:51 AM | #61 | |
Rep 2,495
Note - I work for the primary credit reference agency that BMW FS use, but regardless they cannot 'abuse' a credit file like this
05-24-2018, 12:05 PM | #62 |
Rep 1,641
I don’t think they can mark you credit file but they can 100% terminate the contract and ask for you to settle in full.
There was a guy on the seat forum that this happened to because he had modified the car |
05-24-2018, 12:16 PM | #63 |
Rep 204
I am thinking about getting a remap with a car on a pcp with BMWfs and having read this thread I rang them up and asked them what their take was. The guy said you can do what you want with the car as long as when/if you decided to hand it back to the finance company (not likely) the car was returned to stock
05-24-2018, 12:44 PM | #64 |
Rep 541
Those intercoolers are very expensive compared to the power gains. £700. plus fitting it you dont do it yourself.
Does anyone have a dyno run pre intercooler and post intercooler? |
05-24-2018, 12:57 PM | #65 | |
Rep 45
Agree. Best bang for buck is just a remap. +80 bhp for £500 (£100 per 20 bhp). Intercooler is expensive and the returns are not a lot + 15 bhp for £800 (£100 per 2 bhp). But that aside, it still does make a difference as outlined above. I do have a dyno before/after but unfortunately it’s not valid. I had my intercooler installed and a new remap added at the same time. So the after dyno is not reflective of just the intercooler on its own. That being said I went from 385/517 ft-lbs to 410/545 ft-lbs - that 410 was a one off, the rest of the results were around the 405 mark. All in all, a 20 bhp gain for me. But as I said, that’s including a more aggressive map uploaded at the same time as the intercooler install. You would generally get your map tweaked anyway with the install of a cooler - so it’s still reflective of what anyone can expect to gain. |
05-24-2018, 05:13 PM | #66 |
Rep 28
Just wanted to go back to this. I read on previous posts you said your 30d guzzled fuel with the potentiometer turned fully clockwise. Did you ever find a happy medium?
