View Poll Results: Which tune do you have experience with? | |||
None, stock | 64 | 47.41% | |
BMS Stage 1, no problems | 36 | 26.67% | |
BMS Stage 1, had issues | 1 | 0.74% | |
BMS JB4 (aka Stage 2), no problems | 19 | 14.07% | |
BMS JB4 (aka Stage 2), had issues | 3 | 2.22% | |
aFe Scorcher | 12 | 8.89% | |
Voters: 135. You may not vote on this poll |
01-06-2015, 02:58 PM | #45 | |
Rep 101
01-06-2015, 10:14 PM | #47 |
Rep 577
Really interested in RaceChips. Wonder how it compares to Dinan. Dinan give quite a lot of information on how they not only increase boost, but they adjust timing and fuel amongst other things. While most others just add boost and rely on the cars engine ECU to work out the other adjustments (which can cause flat spots). Maybe I'm missing something and all these chips do that too, but only Dinan says so.
I really like that RC also uses OEM style connectors and there is no splicing. Almost $1k less than Dinan. That's huge. I get that the Dinan has "warranty", and I would love that piece of mind, but man that's a lot of coin that could be spent on coil overs, or a better FMIC & charge pipes, or the MP BBK. Really Wonder how this unit stacks up against the others from a technology standpoint as well as a performance standpoint. |
01-07-2015, 12:54 AM | #49 | |
Rep 577
What I'm trying to understand is how they each physically work (obviously I don't need secrets to be divulged but would like the high level points) and what makes them different from an operational standpoint. Is there anyone that can give a more technical breakdown of how they work and are different? |
01-07-2015, 11:40 AM | #50 | |
Rep 3,990
2014 X5 50i X-Line // Mineral White
01-08-2015, 11:02 AM | #53 | |
Rep 115,980
Race chips, DTMHaus, et. al. are just more expensive versions of the BMS Stage1. They don't have CAN bus access and thus are much more limited in the scope of tuning they can do. They won't be able to do anything a JB4 can do for example. No gear dependent boost control, no AFR & knock monitoring, no map switching in dash, no over temperature or cold oil protection, etc. Dinan is more like a JB4 in terms of the scope of tuning but they've chosen to keep power levels close to BMS Stage1 levels, since they are paying for any subsequent repairs. Mike |
01-08-2015, 11:06 AM | #54 | |
Rep 577
Do you know if JB4 will ever get a harness that uses OEM connectors? I'd prefer to avoid any wire tapping or splicing. |
01-08-2015, 11:15 AM | #55 | |
Rep 115,980
Mike |
01-08-2015, 11:49 AM | #56 | |
Rep 3,990
01-08-2015, 12:18 PM | #57 | |
Rep 115,980
Mike |
01-08-2015, 12:19 PM | #58 | ||
IG @bmwF9xG80
3813
Rep 7,593
A simple look at the max settings we can achieve with RaceChip ultimate are showing 296hp 310 lb-ft torque. There are other N20 members already with Stage1, JB4 and now RaceChip. They're are seeing how much easier it is to install RC, increase or lower the settings as well and its unit is water-resistance quality. BMS is no slouch but to say JB4 is like Dinan is not right. The dynos for N20 on BMS site shows JB4 is not even near Dinan performance, JB4 def surpasses stage1 but ... (not sure if more than 310hp for our engine) but you will need other mods which end up costing you more than Dinan after all is said and done. Quote:
RaceChip Ultimate Max: 296 HP 310 torque $600-769 Known in Europe as King for Diesel becoming famous in the USA as of recent for Petrol engines, Settings can be changed directly from Unit no need for laptop or usb cables extra cost. Dinan Max: 310 HP / 328 torque $1500-2000 BMS Stage 1: $380 + $30-35 cable I'm confused going by the website the stage1 N20 page says Unmodified N26 233hp\253tq , N26 PumpGas 264hp/291tq, N26 RaceGas 283hp/317tq. But then the Stage2 dyno says N20 w/ 91 oem 233/241, N20 stage1 257/280 and JB4 stage2_91 268/302 .. So in the stage2 page comparison dyno it lowers the hp/tq originally found in stage1 link/chart. BMS Stage2/jb4: 268hp | 302 tq - $529 + $30-35 for USB Cable to change settings or datalog Sure you can reach 303hp/348tq with JB4 only when you do the E85 mod (and it doesn't work on all N20) which no one with a lease will or in their right mind do it. Afe Scorcher: up to 38 hp and 49 lbs-ft torque $375-$480 And its hard to say every vehicle will reach the same max settings too many variables. Just adding to what opasha mentioned , thought I chime in on what I have learned in the past 6 months in researching all these tunes and hearing good/bad experience on others with different cars not just 1. Kendroz can chime in on his experience with BMS and RaceChip gragi has AFE None of these piggyback are bad, it is meant for different individual and modding levels. Some do not have a garage, experience, or time to data log, hook up a usb cable to their laptop and work, but then some do. Some rather have something with warranty or something less expensive that works and can be tweaked from the unit (simple). I am not repping RC or any piggyback brand etc. I have friends with AFE Scorcher/BMS/Dinan/RC/Remus/ and soon custom ECU. In the near future I may or may not, take my X3 to my local tuner who works with European Performance Tuners, to dyno with my piggyback, without it and then I might do a custom tune he also works with BR-Performance thats overseas.
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 Last edited by FSociety; 01-08-2015 at 12:46 PM.. |
01-08-2015, 12:37 PM | #59 | |
Rep 3,990
Here's some very basic information on the differences in case anyone is lost on our discussion between the MAP and MAF sensors: http://www.enginebasics.com/EFI%20Tu...0vs%20MAF.html
01-08-2015, 01:17 PM | #60 | |
Rep 115,980
If you are going to quote dyno numbers then it would be great to post up some dynojet charts. It seems many of these non-USA tuners either never show actual dyno charts or use non-dynojet numbers that are inflated. Dinan rates their tune in CRANK HP which is also imaginary so can't be compared to dynos. In order to really compare the power output of various tunes, the very least they need to be done on the same type of dyno. (ideally same dyno but thats difficult to do unless someone does a tune shootout or testing day) Would be great if we could see your dynojet chart for Race Chip & Dinan. You will see that they are most likely similar to BMS Stage1 curve here: And with a JB4 you can make over 300whp on a dynojet with the proper fuel to support it... Regarding the BMS Stage1 the harness & software were revised and it's now a simple clean 2 connector only harness. This is something a few customers including myself have asked for. Boost can be adjusted from 0 to 6psi over stock using the free software interface, default value is 3psi over stock. Mike |
01-08-2015, 04:50 PM | #61 | |
IG @bmwF9xG80
3813
Rep 7,593
DINAN_GT Dinan-M can you confirm this?
01-08-2015, 04:50 PM | #62 |
Assassin
144
Rep 156
Drives: 2013 F30 335i Xdrive M-SPORT
It is nice to see some dyno charts...like i stated in another post, there are too many variation with the crank and wheel hp/tq gains across all tuning manufactures.
Dinan - rates crank RC- I assume rates crank BMS- shows dyno as wheel gains. BP-R - Emailed about if hp / tq gains are crank or wheel, did not get back to me ...so? Let make is simple people! ALL DYNOS SHOULD BE WHEEL HP/TQ GAINS! Non of this "crank" hp/tq gains. Wheel hp/tq gains are what the car is putting down to the street so im my mind thats the REAL world gains |
01-08-2015, 04:57 PM | #63 |
Rep 1,490
I dyno'd my car with only a BMS Stage 1. The dyno was a Mustang dyno on a 75 degree day. My car is AWD and N26. So we're talking large drivetrain loss/low reading dyno here (at least 20%).
I put something like 230 HP down and like 250 or 255 FT-LBs of torque. That would equate to around 285+ HP at the crank/300+ FT-LBs of torque. Not bad. I would say the BMS Stage 1 is a pretty decent tune for its price, even though I would definitely like to try the Race chips tune as well.
Current: 17 Mustang GT no bmw
Gone but not forgotten: 07 E90 335I, 04 UA6, 95 E36, 04 EP3, 16 S550 EB, 14 F30 328I Stg 1, 08 E90 328I |
01-08-2015, 05:08 PM | #64 | |
Assassin
144
Rep 156
01-08-2015, 05:18 PM | #65 |
Assassin
144
Rep 156
As stated before...by ROBNYC
" BMS Stage 1: $380 + $30-35 cable I'm confused going by the website the stage1 N20 page says Unmodified N26 233hp\253tq , N26 PumpGas 264hp/291tq, N26 RaceGas 283hp/317tq. But then the Stage2 dyno says N20 w/ 91 oem 233/241, N20 stage1 257/280 and JB4 stage2_91 268/302 .. So in the stage2 page comparison dyno it lowers the hp/tq originally found in stage1 link/chart." *Mike (BMS), why does it show two different results for stage 1 BMS? I'm running the N26 engine as well, and in NJ i will be running it with 93 octane( since i fill up with 93 now stock), so is it the one posted at (N26 PumpGas 264hp/291tq)? With no other modifications on my N26 i should see those results on a dyno at my wheels? |
01-08-2015, 08:52 PM | #66 | |
Rep 115,980
As far a dyno power expect around 7whp per every pound of boost added. This will be true for any tune. Stage1 adds 3-4psi while the JB4 adds 3-6psi depending on the engine speed and conditions. Mike |
