02-06-2015, 03:42 PM | #89 |
Rep 3,089
Thank you! It appears that the Weisslichts are brighter than stock. I wish they would hurry up and make something for the 4 series.
02-06-2015, 07:18 PM | #90 |
BMW Fanatic
331
Rep 1,076
Wait you got the brake light LED's from Bimminan? How come they don't have them listed for both the F30 & F32?
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 |
02-06-2015, 07:23 PM | #91 |
Rep 3,089
02-06-2015, 07:26 PM | #92 |
BMW Fanatic
331
Rep 1,076
Nvm just found out F30's have the same bulbs for Turn signals and brakes... Why did BMW make the F32 Different!
02-07-2015, 01:25 AM | #93 |
BMW Fanatic
331
Rep 1,076
How are they in your opinion? Brighter than stock and error free?
02-11-2015, 08:25 AM | #95 | |
Rep 3,089
The stock bulb is white. The LED I used is red. |
02-11-2015, 08:46 AM | #96 |
Rep 114
02-25-2015, 02:21 PM | #97 |
Rep 1,437
Many thanks for the brilliant advice on this thread.
bimmian.com WeissLicht LED rock! For all you Brits, I ordered: WLF303YYY - Fogs, WTS302FAY - Front amber indicator, WTS302RAY - Rear amber indicator, WTS302RRY - Rear red outer brake and WTS302VWY - white reverse for my F30. That translated into: ... and this nice little package arrived: The bmw user manual can be used for fitting most of the bulbs as per above. For the fronts indicators, for me it was a made whole lot easier by jacking the car front up and allowing the wheel/tyre to drop and thus permitting better entry to the access panel and subsequent bulb removal/replacement. For the fogs, (sorry if this is a repeat) turning the wheel inwards and removing some of the wheel arch panel screws permitted the fog bulb to be replaced - see http://f30.bimmerpost.com/forums/sho...d.php?t=871554 for a good guide. I got confused with the flickering, thinking it was just while the bulb was on - but no, every 5 or seconds a pulse is sent to each LED resulting in ... err a flicker. Normally OEM bulb would not register the pulse to the naked eye, but those damn good LEDs do. Coding is needed then. |
02-25-2015, 02:32 PM | #98 |
Rep 3,089
Bimmian lights are nice...wish they made something for the F32 brake and reverse lights.
02-25-2015, 03:49 PM | #99 |
Rep 1,961
02-25-2015, 03:54 PM | #100 |
Rep 3,089
No man! WTF. So he said he has the reverse lights? The ones on the 4 series is like the front turn signals, it requires the bulb base. I am not sure if he can get those. It was the same situation with the front turn signals. All they had was the bulb but not the base so I ended up buying the Bimmian front turn LEDs.
02-25-2015, 03:58 PM | #101 | |
Rep 1,961
http://www.horizonleds.co.uk/cree-le...y24w-cree-leds Wait, just checked the ETK. Your front turns are PY24W. The rears are PW16W. They look similar, but he doesn't have those listed at all. Last edited by Mike_L; 02-25-2015 at 04:03 PM.. |
02-25-2015, 04:01 PM | #102 |
Rep 3,089
Reverse is PW16W. According to the pic image on realoem.com it has the bulb base.
02-25-2015, 04:22 PM | #103 |
Rep 1,961
02-25-2015, 04:25 PM | #104 |
Rep 3,089
Yeah the base looks smaller for the PW16W. I mentioned this to Zain and I think I scared him away! LOL!
02-28-2015, 09:53 AM | #106 |
Rep 1,437
09-08-2015, 06:58 PM | #107 |
Rep 817
Drives: bmw M3 F80
good
09-24-2015, 10:15 AM | #108 |
Rep 13
Do any of you have the white front turn signal bulbs instead of the amber?
I would love to see pictures/video to see how close in hue/temperature they are to the halo's when using them at night with the headlights on and how big the brightness/intensity difference is between them and the halos and headlights, since theyre "8x" brighter than OEM. Thanks! |
12-05-2020, 01:56 AM | #109 |
Rep 7
Thanks for writing up this great forum. I have a 2015 328i , what bulbs would work for my front turn signals... Im going for the clear/white bulb look that does not appear colored (the standard yellow/amber) with daytime/running lights but when the turn signal is activated it will have amber lighting. Hopefully this exist and Im not wasting your tine 🤣.. my bulb is a Py21w. Thanks!
