03-21-2014, 04:06 PM | #1 |
Rep 32,881
It appears that all Business Navigation cars built since at least September 2013 have the Combox in the boot, so EBT (Enhanced Bluetooth and USB) can be enabled with E-Sys. NBT Pro Media has the Combox built into the head unit so can also have EBT coded.
Edit 14/4/2015: Also it now appears that March 2015 onwards built cars with Business Media now have the Combox built into the head unit, like NBT. These have also been successfully coded for EBT, see demig's post #368. E-Sys, psdzdata files & install/coding guides can be obtained from shawnsheridan PM him a request, he is the coding master and a very helpful chap, also find him and lots of coding info in this thread: http://www.f30post.com/forums/showthread.php?t=696777 First follow the PDF guide that came with E-Sys 'E-Sys - Installation' Then follow the PDF that also came with E-Sys 'How to change FA in F-series car' but with these changes/additions 1. At step 2. select F020 in top window and check bottom option 'connection via VIN. 2. On step 3 you need to press 'save' after pressing 'read' then save file as any name you want, then the 'edit' button will be enabled. 3. On step 6 change 6NH to 6NS 4. Once all steps are complete: go back to expert mode, Coding => right click FA and select activate FA => Click read SVT Right Click on HU_CHAMP2 (HU_NBT for NBT Pro Media or HU_EntryNav for newer business media) (the ECU itself not the underlying CAFD) => Select CODE Wait for 'Abarbeitung beendet' which means finished completed. Right-Click on CMB_Media (step not required for NBT pro media or newer business media) (again the ECU itself not the underlying CAFD) => Select CODE Again wait for Arbarbeitung beendet 6. Click disconnect, Done! On the older systems to enable Bluetooth streaming: In idrive go to 'telephone' => 'Bluetooth telephone/devices' => highlight your phone => press option or click right => go down and select 'configure Bluetooth' => tick all the options => go back => go up to your phone and select it => tick audio now go to 'media' => 'external devices' => your phone will now be an option to play audio from! Either change track back or forward with idrive or control from your phones screen. Of course you will also now have Album art from USB stick and iphone through lightning cable, and also full control of music library from iphone in idrive using lightning cable. Don't forget to appreciate this post if you found it helpful! Last edited by teaston; 02-01-2017 at 01:57 PM.. |
23
CyclingBroStyle233.00 Skello45.50 realcam13.00 Stoo134.00 ColinDuff6892.00 McBeemer261.00 eluded3070.00 kchildsf3220.00 mm0wax88.50 haagm58810.50 CL5337.00 LesAshmore2.50 LaNcE0123.00 JayR328i38.00 CalBadda1.50 drewkelly3.50 yuwhehe3.50 |
03-21-2014, 05:20 PM | #11 |
Rep 32,881
03-21-2014, 05:22 PM | #12 |
Rep 179
Sounds a good idea. I've ordered pro, so hopefully I'll get album artwork over BT
03-21-2014, 05:23 PM | #13 | |
Rep 20,651
Will it accept ipad playing music as well? (I assume obviously it does). |
03-21-2014, 05:24 PM | #14 |
Rep 32,881
03-21-2014, 05:28 PM | #15 | |
Rep 20,651
Well, I will definitely be getting mine coded. Although by June, it will probably come with all options as standard lol. |
J335D7.50 |
03-21-2014, 05:41 PM | #16 |
Rep 32,881
I have the snugg ipad cover, the front part hangs over the back of the steering wheel so the screen sits perfectly on the front of the steering wheel!
03-21-2014, 05:49 PM | #17 | |
Rep 20,651
Means anyone tries stealing it, I can club them to death with it and my ipad will still work lol. |
03-21-2014, 05:51 PM | #18 |
Rep 32,881
03-21-2014, 06:38 PM | #20 |
Rep 260
Sorry a bit late to this but does Pro Nav have EBT? I can plug my iPod in using the normal iPod cable and have the newer touchpad iDrive.
Alex |
03-21-2014, 06:44 PM | #21 |
Rep 32,881
It only has EBT if you either added it as an option, or if you code it. Normal apple cable will work with pro nav regardless.
03-21-2014, 06:46 PM | #22 |
Rep 260
