12-19-2015, 12:02 AM | #9660 |
Rep 40,774
PM sent.
12-19-2015, 10:04 AM | #9662 |
Rep 40,774
PM sent.
12-19-2015, 11:47 PM | #9666 |
Rep 40,774
PM sent.
12-20-2015, 12:00 AM | #9667 |
Rep 2
G'day Shaun,
Sorry to be another person to ask...... but could you please send me the links for the latest E-Sys and PSDZData? I am going to try coding my 2013 F30 328i. Really appreciate all your help. Thanks again. Paul |
12-20-2015, 12:37 AM | #9669 |
Rep 40,774
PM sent.
12-20-2015, 08:08 AM | #9671 |
Rep 21
Just Coding with xenon lights only and angel eye... without adaptative, auto leveling
Hello Shawn
can you help me please about this tread!? or someone expert i post this http://f30.bimmerpost.com/forums/sho...808444&page=11 User JC_Nitro ( Yesterday, 04:30 PM) thank you very much JC |
12-20-2015, 08:49 AM | #9672 | |
Rep 40,774
12-20-2015, 08:58 AM | #9673 | |
Rep 21
I need coding... I Fallow the tread f30/f31 xenon retrofit Now I have stoped at coding hello someone can help me about this question... i have a f31 01/2013 europe. i have just a xenon lights (original headlight)and angel eyes i have question about this coding... CODING: 41. Coding is the final step to activate these babies. This is done through Esys using a laptop and ENET cable. I am not going to explain everything about coding, but know it is 100% required in order for the headlights to work. If you do not know how or know someone who does, do not install the headlights as you will not be able to drive at night. 42. First add 522 (xenon lights) and 524 (adaptive lights) to your VO, and then write the VO to the car as explained here (courtesy of shawnsheridan): http://www.bimmerfest.com/forums/att...6&d=1338725691 43. Now, VO Code FEM_BODY: Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Right-Click on FEM_BODY (the ECU itself not the underlying CAFD) => Select CODE. 44. Then go back and FDL Code the following: LWR_AHL_TYP = auto./dyn. LWR+AHL = 03 C_FLC_ENA = F030disable (LWR, Leveling sensor) C_AFS_ENA = F030enable (Light Distribution) C_BLC_ENA = F030enable (AHL) C_CLC_ENA = F030enabl (Cornering light) BLC and CLC are enabled by default, but double check just in case. This should in the adaptive headlights functioning correctly and no error for the autoleveling sensors not working/installed. (Thanks to F30EDR for the help in figuring the correct coding). step 42 ( only need add 522) it´s correct here? step 43/44. in LWR_AHL_TYP = wath i supose select? C_FLC_ENA = F030disable (LWR, Leveling sensor) disable correct!? C_AFS_ENA = F030enable (Light Distribution) enable here ? i´m not sure C_BLC_ENA = F030enable (AHL) enable here ? i´m not sure C_CLC_ENA = F030enabl (Cornering light) disable here correct?? no need remove the halogen code or search about this?!?!? need activate or disactivate more itens .. i have angel eyes thank you very much JC QUOTE Last edited by JC_Nitro; 12-20-2015 at 10:33 AM.. |
12-20-2015, 09:02 AM | #9674 |
Rep 40,774
If you car has Xenon light from factory, why do you need coding?
12-20-2015, 09:07 AM | #9675 |
Rep 21
Sorry I not explain correctly. Is not original, the car have halogen from factory... But I buy the original headlights and follow the guide in other post I referred above
Sorry my bad English Thanks |
12-20-2015, 09:17 AM | #9676 |
Rep 40,774
Will you buy Xenon only or Adaptive Xenon lights?
12-20-2015, 10:36 AM | #9678 |
Rep 40,774
So, you would add 522 to FA and VO Code FEM_BODY, then FDL Code the following:
C_FLC_ENA = F030disable C_AFS_ENA = F030enable C_BLC_ENA = F030disable C_CLC_ENA = F030enable I am not sure about LWR_AHL_TYP. This should be disabled I presume.
12-20-2015, 10:40 AM | #9679 | |
Rep 21
i il try it tomorow |
