BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > DIY Suspension Install/Work
Studio RSR
      03-23-2017, 06:22 AM   #1
Polo08816
Drives: 2014 335i M Sport
Background:
I have 74,000 miles on my 2014 335i RWD M Sport. It has the stock passive Sport suspension. I plan to replace my suspension with either the BMW M Performance Suspension kit or Ohlins Road and Track coilovers between now and next fall.
I've searched for DIY suspension threads for the F chassis but they are few and far between.
Purpose:
This thread will serve as a DIY thread for various suspension work to include but not limited to:
  • Front spring/strut removal and install
  • Front roll bar removal and install
  • Rear spring/strut removal and install
  • Rear roll bar removal and install
  • Installing F8X Wishbones
ISTAD Rheingold documents for various suspension procedures as well as torque specifications.
Appreciate 7
zinner559.00
kern4174446.50
Fr3sh29.50
aps335.50
      03-23-2017, 06:31 PM   #2
mdai245
Drives: 440i XDrive
Where do you get these docs? From the rheingold software?
Anything for the F32? Ridiculous labor qoutes on dinan springs are making me contemplate DIY
      03-26-2017, 04:06 AM   #3
x328x
Drives: 2014 328i M Sport
good stuff.
      03-28-2017, 07:13 PM   #4
Polo08816
Here are labor and procedure quotes from BMW KSD which is used by the dealers to estimate time.
      03-31-2017, 09:48 PM   #5
Polo08816
GTBrandon260.00
zinner559.00
Fr3sh29.50
      03-31-2017, 11:02 PM   #6
zcspec
zcspec's Avatar
212
Drives: 911/Boxster/Model Y
I used the following as my DIY when I installed my H&Rs.
https://www.carid.com/images/ark-per...tion-guide.pdf
Polo088161610.00
      04-01-2017, 06:15 AM   #7
Polo08816
Do you remember the size of the strut bolt?
      04-01-2017, 11:50 AM   #8
zcspec
zcspec's Avatar
212
If you're referring to the strut's tophat bolt, I vaguely remember it being a 18 or 19mm.
      04-01-2017, 02:58 PM   #9
Polo08816
Yup, that's what I'm referring to.
I'm just trying to gather all the special tools to do this job. Hopefully the Auto Crafts Center at APG has these:
Spindle Housing Spreader Tool
Strut Nut Socket Set
Schwaben Strut Spring Compressor - they have the wall mount units which will probably be even better.
      04-01-2017, 04:01 PM   #10
zcspec
zcspec's Avatar
212
The tools you've listed above are great choice. You can though, skip the spring compressor. Go to your local auto parts store and see if they will rent you:
You will only need them for the front. You should also consider buying a set of torx socket sets as BMW loves to us them.
Lastly, power tools will be your best friend.
      04-01-2017, 04:53 PM   #11
Polo08816
The only tools I own are specialty BMW tools. I do most of my work here:
https://www.apgmwr.com/recreation-an...ts/auto-crafts
I used their facility to do the M Performance LSD install and wrote a DIY for it: http://f30.bimmerpost.com/forums/sho...=982938&page=8
      04-01-2017, 05:21 PM   #12
zcspec
zcspec's Avatar
212
well then...forgive my lack of knowledge of your skill set! Coils/Spring swap will be no problem for you then.
Polo088161610.00
      04-01-2017, 05:27 PM   #13
Polo08816
I've actually never done suspension on a car until this point so it's always a new learning experience for me. I'm just fortunate enough to have access to a lift, air tools, etc. to make these jobs easier. I can't imagine how much of a PITA it would be to do something on a driveway, miss a step, and go through the pain of lowering and then lifting the car again.
      05-02-2017, 09:43 PM   #14
Polo08816
Pictures of BMW M Performance Suspension Kit
I picked up my BMW M Performance Suspension kit from getBMWparts today.
Here are a few pics:
      05-02-2017, 10:33 PM   #15
R32DBP
Drives: 2014 335i M Sport, 2004 .:R32T
Subscribed for updates. Thanks for making a DIY!
      05-02-2017, 11:07 PM   #16
the dope steez
Drives: F30 335i M-Sport
Just did this job two days ago, pretty simple. Even more so if you have new top hats, might not even need your spring compressors.
      05-03-2017, 02:51 AM   #17
eddiehatchblack
Drives: 2014 F31 x-Drive Wagon
Anyone know the part numbers for the top hats? Trying to prepare to make mine a super easy install.
      05-03-2017, 05:07 AM   #18
Polo08816
My understanding is that you'll still need a spring compressor to remove the top hat from the spring/strut assembly.
      05-03-2017, 10:13 AM   #19
the dope steez
Right but why remove the top hat at all when from the looks of it you are building an entire new assembly on the bench and then reinstalling the entire spring/strut assembly in one piece?
I wish I would have done that as it would have made removal/storage a fair bit easier.
      05-03-2017, 11:16 AM   #20
Polo08816
For the new front spring/strut assembly, you're going to need to compress the springs in order to install the new top hat.
I won't have to disassemble the old front spring/strut assembly after removing it from the vehicle.
      05-03-2017, 12:01 PM   #21
the dope steez
Yeah that's one way to do it
I just put an impact gun on the top hat nut to get it tightened down enough, installed everything, dropped the car onto the ground and then torqued the top hat nut while everything was under load. You will find with the shorter springs you should be able to tighten the top nut a fair bit without needing to compress the spring, but that may not be the proper way to do the install
      05-03-2017, 01:30 PM   #22
eddiehatchblack
Yeah I don't mind renting (for free) a spring compressor. I just want to make the install and storage as easy as possible.
Does anyone have the part numbers for the top hats and whatever else I'll need?
diy
