01-05-2017, 02:42 PM | #1 |
Rep 805
M Performance Suspension Noisy
Need some advice, I've had M Peformance suspension fitted to my 320d M Sport, and since doing this I am finding the road noise has increased significantly, especially on the motorway. The tyres are the same as before, and on every surface I would say the road noise is much more audible, to the point motorway driving is becoming a pain.
I know many people have ACS which is the same drop and some people are running birds suspension kits, but not seen anyone complain about the noise. To give an idea, I travel the M4 at least once a week, and before you could hold a conversation with the passengers quite easily, it's now raised voices verging on shouting. For those of you with experience of lowered/uprated suspension, can you please share your experience? Is this normal? I have got it booked in, but just wanted to check I am not being OTT about the noise? PS - the car has also had MP brakes and power at the same time, i will do a full write up once I have this issue sorted Last edited by Archer-s; 01-05-2017 at 02:48 PM.. |
01-05-2017, 02:43 PM | #2 |
Rep 19,982
I've had ACS springs, and now ACS RS coilovers and never noticed any change in road noise afterwards.
01-05-2017, 02:53 PM | #4 |
Rep 19,982
The drop is huge, so any change can't be related to the drop in itself.
01-05-2017, 05:04 PM | #7 |
Rep 805
03-12-2017, 11:14 AM | #14 | |
Rep 15,858
You are running the same tyres and let's suggest the geometry has been set to the same calibrations as the normal M-sport suspension. If so, then there should be no difference in tyre to road contact. Tyre noise to the interior of the car has two specific transmission routes, air-borne and structure-borne. The air-borne route is virtually the same, using the original tyres, give a slight change in ride height and wheel position in the body/wheel cavities. Let's assume the suspension geometry is in spec' for an M-sport suspension. Therefore the radiated tyre noise and cabin insulation/sealing to air-borne noise has not been changed in this instance. Air-borne tyre noise should be near identical, pre or post changes. Structure-borne tyre noise transmission can now be completely different. A new set of working frequencies, with your modified setup. You have a different strut, damper and spring rates. Plus you have changed the brakes, so a completely different unsprung weight. This can translate to a change in vibration frequencies, from the wheel and tyre. Transmit in a completely different and unpleasant frequency range, to the car's body and interior. |
03-12-2017, 11:18 AM | #15 |
Rep 805
Had it since December, it sticks to the road much better, much flatter in the corners, it does highlight the lack of feedback from the steering and the noise is becoming an issue on long journeys. Comfort wise, it's actually really good, it is stiffer but not harsh. Cost was circa 1400.
After speaking with birds (didn't find BMW much help with the noise), it's prob the top mounts that supplied with the kit, they look like they might be different, might be a cheap mod for others if someone can confirm the part numbers for the mounts. My gut feel is non rft is the way forward, will prob be near perfect once added, but with a young family and lots of motorway miles, I really don't want to go non rft. The current ones are Bridgestones, so maybe newer rfts will reduce the noise or I might go back to the original suspension setup. If anyone is interested in the M Performance Suspension, make me an offer on PM. |
03-12-2017, 11:29 AM | #16 |
Rep 805
@highlandpete, think that's spot on, combination of things, the brake size has only changed on the front, from 330 to 370 as I had the m sport brakes before. Hopefully the answer is to sort it at source, ie tyres, but seriously considering going back to std due to the m way miles
Little bit disappointed there isn't a huge amount of support from BMW |
