01-27-2017, 11:01 AM | #23 | |
Rep 100
For the record, first transmission was fully broken in before car was ever launched. I'm not sure when the whine first developed, but I noticed it shortly after my first oil change at 5K miles. I followed break-in on the replacement tranny on my own accord. My SA was useless when I asked him if there was anything I needed to know. He said first tranny was just a faulty part. Also as mentioned in my post, the 2nd tranny started whining within the first 200-300 miles of getting the car back. Car had not been launched at that point, which is why I'm convinced LC is unrelated. First launch prob happened around 2K miles into the replacement. I only waited to bring it back to the dealer since my oil change was coming up at 10K. Had I known I would face a problem, I would have never launched it until after dealer visit. I don't know if I came across as an idiot in my post, but I can assure I know how to take care of my car. I would not be pursuing this if I abused the car, and risk having my entire warranty voided. EDIT: Here are some links to others reporting the same ZF8 problem I'm having. http://www.2addicts.com/forums/showthread.php?t=1327254 https://www.tapatalk.com/topic/16845...-gearbox-whine http://f30.bimmerpost.com/forums/sho....php?t=1271346 http://www.babybmw.net/forum/viewtopic.php?f=74&t=84455 http://www.babybmw.net/forum/viewtopic.php?t=80100 http://f30.bimmerpost.com/forums/sho....php?t=1309227 Last edited by simsimma777; 01-27-2017 at 11:34 AM.. Reason: added links |
01-27-2017, 11:18 AM | #24 | |
Rep 100
The 4 launches were on the replacement tranny (well after break-in), not lifetime of the vehicle. All 4 where not done at the same time. I still don't see that as excessive, and even if LC is too blame, 4 launches done properly should not damage a tranny, and if it does, should be covered under warranty. That's like $2K a launch. Also, they would have people at their dealership everyday with LC caused tranny problems. Again that's a moot point because the whine developed before use of LC, just not sure how to prove that to them since I waited for an oil change to bring the car in to the dealer. Dealership tried to convince me that is just a noise and won't fail, but I think the field rep is just being a cheap-skate since 2 trannys would be half the cost of the car. |
01-27-2017, 11:26 AM | #25 | |
Rep 2,825
any sort of hard revving on a new transmission could ruin it. how did you drive when you got the second transmission? |
01-27-2017, 11:34 AM | #26 | |
Rep 715
01-27-2017, 11:46 AM | #29 | |
Rep 100
I'm not handling my car with white gloves, but its far from abuse justifying a warranty denial. I take care of my car. Again, I want to emphasize that the whine started about 200 miles in, LC was not used at that point. I edited my earlier comment to add some links to others reporting this issue across a wide range of models. Would encourage you to take a look. |
01-27-2017, 01:19 PM | #30 | |
Rep 2,825
01-27-2017, 02:50 PM | #31 |
Rep 1,985
Have you lawyered up? If they don't state any limits or clauses in their user manual regarding use of launch control, then i don't see how they can deny your claim for using it. If its that damaging to the car, just don't offer the feature, period.
Some cars which have this feature state the limit. I recall reading that the new NSX has to have its clutch replaced after xx number of launches. At least they are being clear about its use. With respect to using it right away after the tranny was replaced, this again could be fixed by software if they really wanted you to break in the transmission before using it. Limiting its use until 1k or 2k or whatever transmission experts think is the proper break in period is an easy thing to code in. |
01-27-2017, 02:54 PM | #32 | |
Rep 2,825
the break-in procedure for a transmission takes much longer then 1-2000 miles. this is likely why he blew his second transmission in a row. |
01-27-2017, 03:02 PM | #33 | |
Rep 1,985
01-27-2017, 03:32 PM | #34 | |
Rep 3,943
The answer is it depends. The problem is a part of transmission reliability and failure rates relate to heat. Heat will kill your torque converter and transmission. This is fact. If you look at the differences between transmissions and even incremental revisions such as the ZF 8HP45 and ZF8HP50, there's almost always changes into the heat exchanger/transmission cooling as each transmission has different heat production/cooling properties. So when someone says, "My car has a tuned N55 with [x] power/torque and the transmission hasn't grenaded itself...", you have to understand their use case. If the most they do is 10-30 second pulls at WOT with that setup, the transmission may be fine. 10-30 seconds is not that much time to build up and may not overheat the entire system. However, if you're running your car at 10/10ths for 20-30 minute sessions at a HPDE or Race School, there's a very good chance that an aftermarket tuned setup would generate enough heat to damage or significantly reduce the life of the transmission. |
01-27-2017, 03:52 PM | #35 | |
Rep 2,825
so, if you run your transmission hard, an oil cooler will help protect it? would you also need to reflash your transmission for the extra power? |
01-27-2017, 04:05 PM | #36 | |
Rep 3,943
Like I said previously, if by "handle" you mean the transmission hasn't suffered a catastrophic failure with a couple short WOT pulls, then I guess the transmission has "handled" it. However, that use case is significantly different from driving the car to its mechanical limit for 20 to 30 mins. Will an oil cooler help protect it? Maybe. By how much... who knows, unless someone has done thorough testing. Also, a reflash won't do much for the longevity of your transmission unless you're using software to address an engineering defect. It's already this late into the game that if BMW felt there was a software fix, it would have already been incorporated into the EGS flash for PsdZData. My philosophy is if you think you're going to be be tracking your car, the total cost of doing it correctly the first time is usually less expensive than experimenting with unknowns, breaking something, and then trying to fix it. In other words, it is far less expensive to purchase an F8X M3/M4 and track it than it is to purchase a F3X, mod it to try to keep up with an M3, experience a catastrophic failure that won't be covered by warranty, and then pay to have it fixed. This is with the understanding that you're far more likely to push a car to its engineering envelope/mechanical limit at the track that you would be doing 10-20 second WOT pulls. |
01-27-2017, 04:33 PM | #37 | |
Rep 100
BTW, my car is completely stock (other than cosmetic stuff). They said the car hasn't thrown any errors. The car still drives fine, but the noise is very loud. I understand 2 failures in a short period would invite extra scrutiny, but I think they went in with that bias and automatically assumed LC when they saw it was used, and didn't look any further. They haven't shown me a shred of proof how they can definitively say it was LC, and how they have ruled out other possibilities. Per the SA, this is what the field rep determined based on his experience. Also I don't understand how the first failure wasn't related to LC, but the second one is. Below is what the manual says regarding break-in and LC to clear up some misconceptions. That's how I knew what procedure to follow since my SA was useless in the info department. As noted, LC will be locked out if you try to use it too soon. General information Moving parts need time to adjust to one another (break-in time). The following instructions will help accomplish a long vehicle life and good efficiency. During break-in, do not use the Launch Control, refer to page 74. Engine, transmission, and axle drive Up to 1,200 miles/2,000 km Do not exceed the maximum engine and road speed: ▷ For gasoline engine 4,500 rpm and 100 mph/160 km/h. Avoid full load or kickdown under all circumstances. From 1,200 miles/2,000 km The engine and vehicle speed can gradually be increased. Following part replacement The same break-in procedures should be observed if any of the components above-mentioned have to be renewed in the course of the vehicle's operating life. ------ Steptronic Sport transmission: Launch Control The concept Launch Control enables optimum acceleration on surfaces with good traction. Hints Component wear Do not use Launch Control too often; otherwise, this may result in premature wear of components due to the high stress placed on the vehicle.◀ Do not use Launch Control during the break-in, refer to page 152, period. To increase vehicle stability, activate DSC again as soon as possible. An experienced driver may be able to achieve better acceleration values in DSC OFF mode. Requirements Launch Control is available when the engine is warmed up, that is, after uninterrupted driving of at least 6 miles/10 km. Before using Launch Control, allow the transmission to cool down for approx. 5 minutes. Launch Control adjusts to the surrounding conditions, e.g., wet pavement, when used again. |
01-27-2017, 09:03 PM | #38 |
Rep 153
01-29-2017, 07:41 AM | #39 |
Rep 4,989
01-29-2017, 10:18 AM | #40 |
Rep 4,871
The ZF comes in various torque variants. The one in the 340 is designed to handle 450 ftlbs at the input shaft. They have lower torque units as well as higher torque units (ending up in the Dodge trucks for example).
A flaw in the transmission housing can cause re-occurring failures, and has nothing to do with the user. If they pull the same transmission, and just fix the innards, it's possible to have another reoccurring failure. Mind you, abuse could have put a twist in the housing (unlikely but still possible). If the tranny was swapped for new, then it's purely a user issue. That being said, if you want to substantially reduce the life of any auto transmission, use launch control. If basically puts the transmission in 1st and reverse at the same time. It's now locked, and cannot spin. When you rev up the engine, the torque converted crosses it's low engagement RPM, and starts to slip heavily. That heats the crap out of the oil and puts huge strain and pressure on the torque converter. Releasing the brake releases the reverse gear, and you get a huge torque input on the transmission. Nothing about LC is remotely friendly to the transmission or driveline. Sure, it might be fun to do, but it is really hard on it, and perpetual use will definitely cause you premature transmission failures. |
01-29-2017, 10:24 AM | #41 | |
Rep 2,825
I've used launch control a couple times before, and will never do it again. I havent in a while anyways. the thing about ZF's is that they tend to feel a little gutless in the first two gears. third onwards you really feel the torque, so I tend to accelerate mainly in the higher gears these days. |
01-29-2017, 02:52 PM | #42 | ||
Rep 886
01-29-2017, 03:53 PM | #43 |
Rep 2,825
08-31-2017, 05:17 PM | #44 |
Rep 3
Hi guys, new member here a new a first time BMW owner.
Wanted to open a new thread but it seems I don't have enough privileges. To make it short I bought about 10 days ago a BMW F30 320ed 2013 with almost 60k miles. Until tonight everything was fine, when I started hearing this sound coming out of gearbox when I shift from parking to D, or D to N and vice versa. From N to R it's okay. So problem seems to be the D. I have no idea what it might be, and can't go to the dealer until Monday. Can you guys help me out? I recorded the sound with my phone: Last edited by LT87; 09-01-2017 at 05:41 AM.. |
disestablishmentarianism, squatty potty |
