BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Water in the headlight
      11-12-2022, 11:07 AM   #1
90rr
90rr's Avatar
Drives: 2021 M340i
Yesterday I noticed condensation, in my headlights, I Left the car overnight and most of it disappeared, after an hour or so in the Florida sun, all remaining condesation was gone.
Yesterday:
To test, I took the car to the carwash and the fog inside the headlight returned immediately. It is interesting that when I got home from the carwash condesation disappeared but returned soon after I parked in the shade (is it possible that some water stayed in and condensed when the headlight cooled off)
After carwash
After sitting in the shade for 30 min (clear sunny day +80F)
The car has never been hit. I inspected the headlight outside for small cracks and checked the lightbulb door and everything looks fine. Any idea what are my options here? I have xenon adaptive headlights. Thank you.
      11-12-2022, 12:51 PM   #2
toxik
toxik's Avatar
Drives: 2017 340i xDrive 6MT
i could be wrong but from your pictures your lenses look worn and oxidized, if that's the case, I would just get new headlight lenses and have a shop reseal them. You could do it yourself but without practice, there's a good chance you'll have precipitation in there again. I know in NY, we have a few shops that do headlight modification, but a lot of people go there for the same problem you have and simply get their headlights resealed or swap to new lenses and new seals.
90rr106.50
      11-12-2022, 02:48 PM   #3
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Check the bulb access porthole covers.
      11-13-2022, 06:30 AM   #4
Yam_440i
Drives: White BMW 335i convertible
As above, look through the arch and see if your covers have fallen off. I had the same thing when the screw cap and the flap fell off and I started getting puddles of water in the headlight. Ended up frying a module but luckily I had warranty so BMW replaced the entire headlight.
I have actually customised my headlights and put aftermarket rings in there so I am quite familiar with condensation issues. I would say if all the covers are on and there isn't any visible route of water getting in, try put in those gel air condensation packs, which should get rid of any moisture temporarily.
      11-13-2022, 06:36 AM   #5
Solidjake
¯\_(ツ)_/¯
Solidjake's Avatar
Poland
945
Drives: '13 328i Msport 6MT
???? You can clearly see moisture in the headlight and the E46 was the last BMW model with replaceable headlight lenses.
Apex SM-10/DWS06+ | 400m/X-ice Xi3 | Injen Exhaust | Stoptech SS Lines | 335 Front Brakes
Hawk HPS 5.0 | RBF600 | ER Charge Pipes | Wagner Evo Comp 2 FMIC
      11-13-2022, 07:22 AM   #6
toxik
toxik's Avatar
all modern headlights have lenses that can be replaced, i think you're talking about replaced with screws/bolts, where it can be easily done by any owner. but the headlight housing and lens comes apart, they just need to be baked and then the sealant can be separated.
here's a link to the lenses: https://www.bavgruppedesign.com/prod...s-bmw-f30-f31/
here's a diy on how to do it:
i was also talking about his lenses exterior, the oxidation/wear on the outside or inside of the lens, as in it might be a good time to refresh and replace them. that's not the same as condensation, i know that there's water inside haha.
      11-16-2022, 11:51 AM   #7
90rr
90rr's Avatar
Drives: 2021 M340i
Update: Opened bulb cover and left car on the sun for couple of hours. So far so good, no fogging even after the rain !
      11-16-2022, 12:27 PM   #8
Jvac
Drives: 2015 335i rwd
If you're going to do that,ay I suggest sticking a silica packet in there for a time. The moisture has a way of disappearing into dark corners when it condenses and then reappearing when sunlight or heat causes it to evaporate again.
335i rwd auto, 2015 with m performance LSD and Dinan stage 2. Cts charge pipe, mad 5" stepped intercooler.
Fliplegend1471.00
90rr106.50
      11-17-2022, 01:38 AM   #9
vmaniqui
Drives: Toyota Land Cruiser/340i M
Looks like your headlights has openings or holes that the water is sipping in. Check this out.....
