      04-18-2013, 02:24 AM   #3323
kon
Singapore
Drives: F30 310i > G20 310i
Originally Posted by Aritaurus View Post
Looks like you need 49.2 where the only difference is that file you mentioned - cafd_000000f9.caf.007_006_009.
I think Shawn should be able to just give you that cafd file and you can just plug it into your existing cafd directory and code HU_CIC. I'm taking my car in for service soon as well so I might need it too if they update the software on my car.
Got that one file from Shawn
Seems 49.2 is really just one update to a specific HU_CIC
      04-18-2013, 03:45 AM   #3324
shawnsheridan
shawnsheridan's Avatar
Originally Posted by ykau View Post
Hi Shawn, I think i have asked before, but would like to ask again if the odometer mileage value can be just changed via esys or fsc?
reason our country will consider warranty expired after driving for more than 100K. thanks
Originally Posted by kon View Post
*subscribed*
Not possible. You would need an EEPROM burner to blank the mileage in KOMBI, but the Mileage is backed up in CAS, and Kombi would pull the mileage back in from CAS module.
      04-18-2013, 04:05 AM   #3325
kon
Singapore
Would jacking the car up and turn the front wheel in reverse reverse the odometer
sorry can't resist!
      04-18-2013, 06:57 PM   #3326
UhhItsANT
Drives: 2013 BMW 335i
2013 BMW 335i  [0.00]
sorry can't resist!
reminds me of that movie... ferris bueller day off
      04-18-2013, 07:58 PM   #3327
vithy
Drives: 2016 F30 328xi
Is it possible to code Sports + without the hardware required?
      04-18-2013, 11:28 PM   #3328
Chris@codemybimmer
Chris@codemybimmer's Avatar
Drives: AW F30 328i Xdrive
yes
ICMQL > 3000 > LCMKOD B SPORTLENKUNG > VERBAUT
      04-19-2013, 08:57 AM   #3329
Puri1
Puri1's Avatar
Drives: F30 328i 2012
Hey Guys, I'm trying to install the software on a MacBook Air. Since HardDisk space is at a premium I was wondering if I can leave the data on an external USB drive and still run Esys and code. Does the psz data have to be on the internal HDD ?
Has anyone coded with a MB Air before? How was your experience. Did it work well?
2012 F30 328i, Alpine White on Black, Luxury, Premium + Exec. Package...
      04-19-2013, 09:07 AM   #3330
Puri1
Puri1's Avatar
Here guys, this is the cheat sheet I use for my F30. Hope it helps some of you.
      04-19-2013, 10:42 AM   #3331
vithy
If one of the CAF is programmed and i want to default them, can i just hit 'CODE'. and reset the settings? or is there a special method to do so.
      04-19-2013, 11:48 AM   #3332
steve@codemybimmer
steve@codemybimmer's Avatar
Hong Kong
663
Drives: 2020 G20 320i M Sport
That's correct. It will return it back to its factory state.
      04-19-2013, 03:26 PM   #3333
demge01
demge01's Avatar
Drives: F30 320ed
3.22.5.0 update issues..
Its been a while since I've posted and I've updated to 3.22.5.0 and purchased the patch and token.
I've been able to read the coding data in all but one of the modules but when I try to edit the FDL files and save before coding I get the attached error.
Any help appreciated.
      04-20-2013, 03:25 PM   #3334
DXL XLR8
So I coded the car to close all windows upon lock, but it seems the rear windows just stays down. I saw videos where all the windows roll up. Is there a code for this?
      04-21-2013, 07:28 AM   #3335
ad78
Yr1OfD1
ad78's Avatar
Drives: 2015 F34 M Sport
how long it will take after you made a transaction to andy? im freaking excited lol
is there any tutorial on 3.22? it seems a lot different on 3.18
      04-21-2013, 07:50 AM   #3336
shawnsheridan
3.22.5 is near identical to 3.18.4. There are some additional Target I-Level Options that are not used, and a couple buttons are renamed.
There is no tutorial. You use it just the same as 3.18.4.
      04-21-2013, 07:55 AM   #3337
ad78
Yr1OfD1
ad78's Avatar
Ok so same placement of buttons? If yes, I'm good to go.
Still waiting on my token / patch
      04-21-2013, 08:01 AM   #3338
shawnsheridan
Yes, same screen placement. Read VCM is now Read SVT, and I think one other button label changed, but I can't remember which one it is.
There is also a new OBD-CVN Module, but you won't need it either.
      04-21-2013, 12:23 PM   #3339
ad78
Yr1OfD1
ad78's Avatar
so i just got everything from andy and im getting this error
[Exception - UNKNOWN] CAF cafd_000000f9-007_003_024 does not support FA2FP version 001.000.071 for F030. Minimum required version is 001.000.074. Please use current PDX template!
i have 3.22.5 psdzdata is 48.1 and pasted the missing file on cafd 003_24
what is wrong here? do i need to replace the whole 48.1 to 49.1?
      04-21-2013, 12:26 PM   #3340
shawnsheridan
Yes, you need to update to 49.1, and since you are already using E-Sys 3.22.5, there is no reason not to.
      04-21-2013, 12:30 PM   #3341
ad78
Yr1OfD1
ad78's Avatar
ok, god damn im still on .rar 15-19 on 49.1
just remove the 48.1 and just paste the 49.1 correct?
      04-21-2013, 01:21 PM   #3342
shawnsheridan
If you are upgrading from a previous version of PSdZData, MOVE current CAFD folder (e.g. C:\ESysData\psdzdata\swe\cafd) to a backup location; DELETE current PSdZData folder (e.g C:\ESysData\psdzdata) and REPLACE with new one. If you encounter any [C012] Missing CAFD errors, look in your backed up CAFD folder from above for them, and then copy them to the new CAFD folder (e.g C:\ESysData\psdzdata\swe\cafd).
      04-21-2013, 03:50 PM   #3343
demge01
demge01's Avatar
Drives: F30 320ed
Bump
Still can't figure out what's wrong - any ideas?
This is the text in the body of the error file:
EstCmCryptographicException: SignHandler can not be initialized with data from EST <Signature decryption error: javax.crypto.BadPaddingException: Invalid PKCS#1 padding: encrypted message and modulus lengths do not match!>
__________________________________________________ ___
com.bmw.esys.commons.exception.EsysException: Failed to sign FDL. [C158]
at com.bmw.esys.commons.SecurityHandler.sign(Security Handler.java:92)
at com.bmw.esys.domain.coding.FdlLogic.save(FdlLogic. java:150)
at com.bmw.esys.gui.DefaultFileHandlingController.doS ave(DefaultFileHandlingController.java:174)
at com.bmw.esys.gui.DefaultFileHandlingController.sav e(DefaultFileHandlingController.java:189)
at com.bmw.esys.gui.FileHandlingSupport.save(FileHand lingSupport.java:292)
at com.bmw.esys.gui.FileHandlingSupport.access$700(Fi leHandlingSupport.java:41)
at com.bmw.esys.gui.FileHandlingSupport$SaveAction.do ActionPerformed(FileHandlingSupport.java:345)
at com.bmw.esys.gui.AbstractView$AbstractGuiAction.ac tionPerformed(AbstractView.java:233)
at javax.swing.AbstractButton.fireActionPerformed(Unk nown Source)
at javax.swing.AbstractButton$Handler.actionPerformed (Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed (Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseRe leased(Unknown Source)
at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent( Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(U nknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unkno wn Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$000(Unknown Source)
at java.awt.EventQueue$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.AccessControlContext$1.doIntersectio nPrivilege(Unknown Source)
at java.awt.EventQueue$2.run(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilter s(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(U nknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarch y(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
Caused by: com.bmw.est.cm.exception.EstCmCryptographicExcepti on: SignHandler can not be initialized with data from EST <Signature decryption error: javax.crypto.BadPaddingException: Invalid PKCS#1 padding: encrypted message and modulus lengths do not match!>
at com.bmw.est.cm.core.ESTCM.signXML(Unknown Source)
at com.bmw.esys.commons.SecurityHandler.sign(Security Handler.java:90)
... 44 more
      04-21-2013, 04:17 PM   #3344
ad78
Yr1OfD1
ad78's Avatar
finally i got all sorted and i used this cheat. everything was flaswless! the DRL tail is so sweet! the whole thing lighting up. pretty badass
thank you for this cheat sheet!
