06-20-2018, 02:16 PM | #2113 | |
Rep 79
Big thanks for the tips!!! Cactus_BMW |
06-20-2018, 02:19 PM | #2114 | |
Rep 606
Screenshot would be superb |
06-20-2018, 02:32 PM | #2115 | |
Rep 79
In the Android menu: 1. Settings 2. Settings 3. Apps 4. There are 'tabs' across the top of the window (Downloaded, Running, All, Disabled) - do the next step for items on 'Running' & 'All' tabs 5. Tap each Google related app (i.e. Google Play), or maybe it was a tap-&-hold, and there is then an option to stop the app as well as disable. Disable each of these that you know you don't want running. 6. Review all you've disabled on the 'Disabled' tab (and re-enable any, if needed). Sorry the image is a little blurry, but this is in the Apps section of Settings. The right side is showing a list of the apps I have disabled. Last edited by Cactus_BMW; 06-21-2018 at 09:13 AM.. |
06-20-2018, 03:49 PM | #2116 |
Rep 30
Hello all.
So I have upgraded speakers, tweeters, mids and amp. I understand gen1 4.4 Is not great for sound quality so can anyone please inform me if the new gen2 7.1 Is as good as standard Cic professional unit or will I be disappointed and should hold off buying it? Really appreciate any input as am keen to purchase if sound quality is decent. Many thanks |
06-21-2018, 06:44 AM | #2118 |
Rep 606
06-21-2018, 09:26 AM | #2119 |
Rep 5
iDrive controller/knob installation question
Hi guys,
I'm installing my 10.25" Avin system on a BMW X3 E83 model, I ordered also the optional iDriver controller/knob, but I can't understand where to connect its cable. I don't have a free connector on the back of the monitor, or in the main cable from the radio business cd. Where have I to connect it? Do you have a picture to understand better? Thanks a lot |
06-23-2018, 09:22 AM | #2120 |
Rep 23
I use CarPlay with BMW OEM bluetooth. Every time I plug my iphone and start the Auto Play app Carplay starts and takes over the bluetooth audio so I have to take my phone and change output audio back to bluetooth. Has anyone found a way to fix this?
06-28-2018, 11:25 AM | #2122 |
Rep 108
Not possible i think, you have split screen on OEM side, but it's useless...
Anyway, guys who disabled Google apps, how do you install apps than, for example navigation, which app you're using? Sygic wont work without Google play services? |
06-29-2018, 05:15 AM | #2124 |
Rep 147
How to update Firmware.xml, cartype.xml and APK list once the Firmware is updated ?
because i dont have ID6 Menu enabled even after my Firmware update. Can anyone help me pls how to get ID6 Menu in this AVIN device ? i am using latest Firmware from Avin. I have every now and then No Signal error also. Thanks in Avdance. |
06-29-2018, 10:21 AM | #2125 |
Rep 108
You can copy Factory.xml (you wrote Firmware.xml, but I don't know if such file exists) and Cartype.xml into folder called OEM and put that folder in the root of sd card. Than when you power the unit, go to system setup, and there you'll find option to update those files.
07-01-2018, 07:01 PM | #2127 |
Rep 121
Can anyone help me understand how to access the microsd slot?
I've read that it's the top slot, but it looks like mine is occupied with a card or a dummy, and I can't find an easy way to remove it. Pic below... |
07-02-2018, 08:45 AM | #2128 |
Rep 121
The solution was to use the bottom slot, it's not a sd eating black hole with this model.
07-04-2018, 05:03 AM | #2129 |
Rep 6
Hy y have a problem with my navigation f30 its don't working .
View post on imgur.com |
07-04-2018, 05:27 AM | #2130 | |
Rep 147
07-04-2018, 08:28 AM | #2133 |
Rep 147
07-04-2018, 06:28 PM | #2134 |
Rep 63
Is there a way to use stock navigation while streaming music to android(A2DP stream - music)? My unit automatically disables BT stream once switch to stock menu (car info) no matter what screen you are on (even Aux).
