02-18-2015, 08:03 AM | #67 | |
Rep 243
02-18-2015, 08:33 AM | #69 |
2133
Rep 5,011
02-18-2015, 10:16 AM | #70 |
Rep 10,252
Sean,
I am almost ready to order this kit for my 2013 BMW 335i xDrive. Can anyone recommend an experienced installer in Orange County, CA? |
02-18-2015, 12:37 PM | #71 |
@obriennathaniel_f30 on Instagram
515
Rep 1,063
Drives: 582whp/596wtq '13 335i
what are swift springs?
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| |
02-18-2015, 12:51 PM | #72 |
e92 - 335i
179
Rep 743
http://www.swiftsprings.net/
There an optional spring that is offered with higher and/or custom springs rates. |
02-18-2015, 01:16 PM | #73 |
2133
Rep 5,011
02-19-2015, 11:12 AM | #75 |
e92 - 335i
179
Rep 743
02-19-2015, 11:13 AM | #76 |
2133
Rep 5,011
02-23-2015, 09:21 AM | #77 |
515
Rep 1,063
So I have my front coilovers installed, do I need to adjust the spring compression according to ride height? I want a soft ride, so I'm thinking I can leave the springs with almost no tension, am I correct?
02-23-2015, 09:31 AM | #78 |
2133
Rep 5,011
You need to make sure there is a MINIMUM of 4MM preload on the spring to make sure the spring does not make noise once on the car.
02-23-2015, 09:31 AM | #79 |
Rep 3,089
Oh nice! Pics please!
02-23-2015, 09:40 AM | #80 |
515
Rep 1,063
How much does it come with from the factory? Cuz that's where they're at. I havnt driven it yet, just put it back in the garage till I have enoug time to do the rears. Hell I didn't even check to see if they were both the same. Guess I'll do that next
02-23-2015, 09:41 AM | #81 |
515
Rep 1,063
02-24-2015, 04:50 PM | #82 |
2133
Rep 5,011
It is based upon the height you have set it, once the height is set you can add preload.
02-24-2015, 06:48 PM | #83 | |
e92 - 335i
179
Rep 743
This is partially incorrect. It doesn't matter which adjustment is set first but adjusting preload after ride height will change the ride height. The typical daily driver isn't concerned with tracking the car. With the said the baseline preload of 4mm is sufficient, set it and forget it but set it first. Last edited by f30luxline; 02-25-2015 at 12:45 AM.. |
02-25-2015, 01:06 PM | #86 | |
2133
Rep 5,011
02-25-2015, 02:17 PM | #87 | |
515
Rep 1,063
02-25-2015, 03:38 PM | #88 |
Rep 728
Awesome, please tell them to not make them extremely low and a bit stiffer than the kw v1's. And please put me on the waiting list, i would gladly pick up a set.
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
