10-03-2012, 01:59 PM | #969 |
Rep 383
Well, I find that it disappears pretty quickly- Just want it to stay up a lil longer. Someone above mentioned they were able to make Sport+ appear but its greyed out. I'd like to have that one figured out
10-03-2012, 04:22 PM | #970 |
Rep 16
I've found a way to disable triple seatbelt gong, when you start your engine with unfastened seatbelt.
It's ACSM | 3000 Ausstattungsflags | Initialwarnung_GWF_IW | nicht_aktiv / Werte=00 | ( default = aktiv Werte=01 ) |
10-03-2012, 04:29 PM | #971 | |
Rep 1,892
The settings in the cheat sheet just turns off the constant nagging sounds, but it still blings 3 times if you start without the seatbelt on. It looks like this new setting turns that off too. Does this setting affect both the driver and passenger sides? |
10-03-2012, 11:37 PM | #972 |
Rep 169
I have found a way to modify the time the seatbelt gong goes off. Default time is 90s and Ive changed it to 20s.
ACSM / 3001 Seat_Belt_Reminder, 0C / GWF_SBR_WARNDAUER / Kommentar=Dauer der SBR-Warnung (typisch 90s) / unknown Werte=14 (default wert_01 Werte=5A) Change the 14 to whatever hex you want for time. Default will replace wert_01. |
10-04-2012, 02:12 AM | #973 |
Rep 16
I believe it does, but I'm not sure, because passenger's seatbelt warnings were turned off from factory in my car.
10-04-2012, 03:05 AM | #974 |
Rep 145
Drives: F30 320ed
Does anyone know the difference between Sport and Sport+?
Is Sport+ the same drivetrain and chassis settings but with DSC turned off? I've tried again with the FDS settings but can't get Sport + to select. |
10-04-2012, 07:20 AM | #975 |
Rep 40,944
Thanks, but no. That is only one single ECU (HU_CIC). I am looking for the main screen that shows every ECU.
10-04-2012, 10:47 AM | #976 |
Rep 84
Took delivery on Monday and trying to set all this up. It looks like both versions of psdzdata I've downloaded were not the 47.x versions, which I need. Does anyone have a link to 47.4 psdzdata?
10-04-2012, 10:57 AM | #977 |
Rep 1,892
10-04-2012, 11:16 AM | #978 |
Rep 40,944
PM Sent.
10-04-2012, 01:38 PM | #980 |
Rep 1,892
10-04-2012, 01:46 PM | #981 |
Rep 40,944
F020 psdzdata covers the F20 1-series and F30 3-series.
10-04-2012, 04:09 PM | #982 |
Rep 145
Drives: F30 320ed
Any good?
10-04-2012, 04:34 PM | #983 |
Rep 40,944
Yes, thanks. What are the CAFD Names for your HU_ENTRY, REM, FEM_Body, and FEM_GW?
10-05-2012, 06:48 PM | #984 |
Rep 13
Does anyone know if its possible to adjust the speedometer by coding? Mine, like I suppose everyone else's, reads high and I would love it to be accurate!
Andrew |
10-05-2012, 07:18 PM | #985 | |
Rep 40,944
Look for something like this in KOMBI: BC_V_KORREKTUR = Correction for Analog Speed BC_DIGITAL_V_KORREKTUR = Correction for Digital speed
10-05-2012, 10:02 PM | #986 | |
Rep 13
I hate having to do the correction in my head all the time, to figure out my true speed. Cheers Andrew |
10-06-2012, 12:31 AM | #987 |
Rep 1,892
10-06-2012, 01:32 AM | #989 |
Rep 46
This depends on your car's software release date.
If you have one early 533 you'l fine with 47.4 otherwise you need 47.5 Mine is from September and has 533 |
10-06-2012, 05:22 AM | #990 | |
Rep 44
At least, does anybody know which module is relevant for ACC? Then I would do some investigation on my own... |
