BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Anyone know where to get the grill with no slats like this?
      09-12-2017, 04:07 PM   #1
f32alex
Drives: 14' F32 435i
Think this is going to look pretty sweet and I want them. Anyone know?
      09-12-2017, 04:58 PM   #2
1QuikWS6
No 55mph
1QuikWS6's Avatar
1616
Drives: F32 435ix MSport
Uh, you can achieve that with any oem grill. The outside ring is a separate piece from the slatted section. Center section has clips around perimeter, release the clips, remove center slats entirely
Grill has to be removed from car to do this
I wouldn't recommend it, grills are there for a reason to protect your expensive rad from flying road debris...
      09-12-2017, 05:59 PM   #3
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Yes, but you can't use the one piece without the other. I considered that when I needed to remove the slats from mine, I ended up cutting them off.
+1. The reason I removed my slats was to do this, because I was concerned that the wide gaps between the slats didn't protect the radiator very well:
      09-13-2017, 02:08 PM   #4
atam1980
Drives: 2012 F30
not sure the two gaping holes is gonna give you the look you're going for... attached a photoshop to give you an idea.
      09-13-2017, 03:29 PM   #5
Billfitz
Billfitz's Avatar
+1. My guess is that the part in the picture is intended to replace a chrome frame, still using the original slat section.
      09-13-2017, 03:58 PM   #6
sickF30
Drives: F30 335i
do you realize how much you reduced the airflow to your radiator by doing that?
      09-13-2017, 04:27 PM   #7
7iM3less
7iM3less's Avatar
Drives: F80 M3 ZCP
Lmao, well you never know what some will do for weight reduction and improved airflow.
2016 BMW F80 ZCP
Instagram : 7IM3LESS
https://instagram.com/7im3less?igshid=YmMyMTA2M2Y=
      09-13-2017, 04:59 PM   #8
Billfitz
Billfitz's Avatar
Not enough to make a bit of difference in either my oil or coolant temperatures. OTOH a rock approaching a full inch in diameter can pass through the stock grille, and I'm quite sure the damage it would do to the radiator would cause a serious temperature problem.
      09-13-2017, 05:21 PM   #9
kern417
Cheapskate
4432
Drives: 2018 440i |2016 340i | 2010 X5
either way it looks horrible with the chicken wire. at least paint it black or something.
Youtube/Instagram/TikTok: @kern417
      09-13-2017, 05:55 PM   #10
SportySpice
SportySpice's Avatar
Drives: 2020 M340i
No one asked me, but I like it.
      09-13-2017, 05:57 PM   #11
Billfitz
Billfitz's Avatar
Yeah, horrible, like a Jag or Bentley. Much worse than black plastic.
      09-14-2017, 06:56 AM   #12
kern417
Cheapskate
4432
"like a jag or a bentley"
oh, and there's a reason why the sports models come with black grilles. it looks better.
      09-14-2017, 07:19 AM   #13
Billfitz
Billfitz's Avatar
I get it. You don't like it. So don't do it to your car, and don't tell me what I'm entitled to prefer.
ooshnoo868.50
      09-14-2017, 03:21 PM   #14
kern417
Cheapskate
4432
dawww i'm sowwy.
      10-14-2017, 04:08 AM   #15
whatnot
Drives: F31 320iAX Sport
nt.
      10-14-2017, 11:07 AM   #16
rlmesq
Drives: 2018 440i M Sport
This tiny ding on the AC heat exchanger released all the refrigerant, which burned up the compressor. My 2018 440i is only three months old. Repairs cost $2k. Fortunately, my insurance covered it.
      10-14-2017, 03:48 PM   #17
Billfitz
Billfitz's Avatar
That's the main reason why I replaced the slat grille on mine, the protection against road debris is minimal. TBH I didn't do the lower section on mine where my AC coils are, but after seeing your experience it's on my list.
