02-03-2016, 10:43 AM | #1 |
Rep 86
How could i improve accelerate response
Dear All,
I have been tune my car into RC chip, changed Downpipes, intake and exhaust. I found my car was response slow when i press accelerate. I did install sprint booster, it showed slight faster response, but i felt that still slow for me. When i press the accelerate, it takes 2sec to response. Does anyone have a suggestion, what should i do to improve ? |
02-03-2016, 09:31 PM | #2 |
Rep 57
I know my car is slow to respond when I am not in either Sport or Sport + mode. Also, these new 8-speed automatic transmissions make dropping from cruising the highway in 8th gear to accelerating in 4th a little bit of a task. Still, 2 seconds is a little long. Also, if you press your accelerator pedal into the floor, past the clicky-resistance point, you should basically put the car into Sport mode acceleration as long as your hold the pedal all the way down.
02-04-2016, 07:32 AM | #3 | |
Rep 86
02-04-2016, 04:55 PM | #4 |
Rep 205
Try make a video.. 2 seconds are a really long time. considering 0-100km/h can be 5 seconds.
You might have a problem, would be easy to say from a video
320i Activeflex - JB4 - Afe Airfilter - VRSF IC - ER DP - ER CP - @Ethanol
02-04-2016, 10:13 PM | #5 |
Rep 241
I'm in for this. My car does it to. BMW replaced spark plugs but the throttle response still exist. When I try to get on the highway, I'll floor it in sport mode, it'll respond 1-1.5 seconds later. I read that the sprinter n jb4 sport mode should help but from what you're saying it's not resolving the issue. I read that you can code the car to shift better in the coding section. Have you tried that?
Charlie Vu
2013 328iX Melb RED- JB4 - AFE 5R Intake - B14 Bilstein - Morimoto H1 Projectors and LED Angel eyes- Morimoto HD Elite 50w 5500k H.I.D. |
02-05-2016, 09:21 AM | #6 | |
Rep 86
02-18-2016, 10:11 AM | #7 |
Rep 15
Just take off your RC and do flash tune. Rc only increasing your power when you are in boost. But flash tune increse power both in off boost and in boost. It also re adjust your timing and AFR in all RPM. So the powerband is very linear. It also adjust your throttle response. And the most important one is it also increase your water pump pressure to do better cooling for your engine which piggyback cant do except dinan.
