BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Coolant Drain DIY - F30 335i
      06-29-2016, 12:40 AM   #1
humbertob
humbertob's Avatar
Drives: '13 F30 335i Sport
Exclamation Coolant Drain DIY - F30 335i
Well today I just replaced the brownish coolant on my F30, here are the steps, could help someone, I hope:
1. Place your car securely on ramps
2. Remove the engine under cover, you need to remove all the 8mm bolts holding it in place
3. Remove the 8mm bolt holding the overflow tank, then unlock the 2 tabs holding the overflow tank in place
4. disconnect the upper coolant line from the overflow tank
5. disconnect the coolant level sensor below the overflow tank
6. disconnect the lower coolant line from the overflow tank
7. After you remove the upper and lower coolant lines the coolant will start to drain so be prepared with a bin to catch the old coolant
8. Remove the overflow tank completely and at this time rinse the overflow tank using the garden hose to clean the overflow tank from old coolant and sediments
9. Go back under the engine and unbolt the water pump clamp, be prepared with a bin or recipient under the engine, masive coolant amount will drain at this time
10. release the coolant hose from the water pump (coolant will drain)
11. after all the coolant is gone, replace the clamp using the attached bolt
12. Replace the under engine cover and all the 8mm bolts that hold it in place
13. Re-attach the lower coolant line to the overflow tank
14. Re-connect the coolant level sensor to the overflow tank
15. Re-attach the upper coolant line to the overflow tank
16. Replace the bolt that holds the overflow tank in place (8mm bolt)
17. Remove the bleeding screw (black screw) from the overflow tank
18. Using 50/50 BMW Blue Coolant/Distilled Water fill the overflow tank slowly until the coolant starts to escape from the bleeding hole at the overflow tank
19. Re-attach the bleeding screw
20. Replace the overflow tank cap
21. start the ignition on the car, without starting the engine
22. select the hottest temp on the a/c unit
23. select the lowest fan speed on the a/c unit
24. push the accelerator down to the floor for 10 seconds
25. you'll start hearing that the water pump starts working, it's bleeding the coolant system for you
26. Wait for 12-13 minutes until the water pump completes the bleeding cycle
27. You have changed your Coolant on your F30 at this point !
Thanks for all your support !
(OO)-(////)(\\\\)-(OO)
'14 F10 535i M-Sport
'13 E70 X5 | Wife's
'11 E90 335i | BMW Performance Edition / Son's
'00 E46 323Ci | Convertible / Son's
Lego86421.00
      06-29-2016, 08:31 AM   #2
mr_kay
mr_kay's Avatar
116
Drives: F30 335i
Perfect. Thank you. I was looking how to do this for when I do my oil housing gaskets this weekend. Up until this morning I was trying to test to see if the bleeding procedure worked on my car and I couldn't hear anything to confirm if it was running...Good to know I was doing the correct procedure.
      06-29-2016, 08:35 AM   #3
mr_kay
mr_kay's Avatar
116
Drives: F30 335i
Any reason to drain the reservoir tank first and not the water pump connection? Seems like it might be less messy that way.
      06-29-2016, 11:51 AM   #4
humbertob
humbertob's Avatar
Exclamation
"The order of the factors does not alter the product !" The only reason that I first removed the overflow tank was to clean and rinse the tank from sediments and old coolant, but if yours is clean, you can even keep it attached, on my case there were sediments and I did prefer to clean the overflow tank before new coolant was poured.
'13 E70 X5 | Wife's
      06-29-2016, 11:52 AM   #5
mr_kay
mr_kay's Avatar
116
Drives: F30 335i
Gotcha. Thanks!
      07-31-2017, 11:05 PM   #6
rugbyfool89
Drives: F30 335i Sport
Just wanted to say thank you. Pretty cool how the car bleeds itself.
      08-01-2017, 10:09 PM   #7
jdr78569
jdr78569's Avatar
78
Drives: F31 328d sport wag
Do you have picture on how to unclip the lower hose? I stopped at that point since it was getting late and i didn't see how i could unclip it. I know BMW coolant is "lifetime" and mines clean i just wanted to do a drain and fill
      08-04-2017, 11:04 AM   #8
reyoasian
Drives: 340xi MPPSK
What's the spec of the coolant required?
      08-04-2017, 12:03 PM   #9
Sanelko
Sanelko's Avatar
28
Drives: 2012 Jet Black 328i
I think it's BMW N60069.0 (blue in color). Other than the BMW coolant, the only other ones I know of are Pentosin and Rowe.
      08-04-2017, 01:15 PM   #10
_bdiddyb_
Drives: 2013 335i
It was a bitch to unclip the hose from the water pump to drain the coolant. What ever happened to the drain plug at the bottom of the radiator??? C'mon BMW !!! Bleeding procedure was very smart.
On another car maker, the Lexus IS350 was completely opposite. Draining was a cinch, but bleeding procedure was asinine.
      08-15-2017, 08:56 PM   #11
vifferfun
Drives: 2012 BMW 335i Sedan 6MT
Thanks so much for posting these instructions! I just had to bleed my system (after replacing a blown coolant hose) so I just had to complete steps 17+. It was really easy!
      12-17-2017, 11:46 PM   #12
GTBrandon
GTBrandon's Avatar
Drives: F34 M-Sport
2014 335xi GT  [5.00]
Any idea on how much coolant the system took total? I'm wondering whether to use one or two (or more) Gallons of the BMW coolant after mixing with water
GT stands for Giant Trunk, right?
www.youtube.com/Channel/UCJdwA05Tsz3WHJFBHXWi9JA
Frank Smith ECU Flash, VRSF DP, CTP FMIC, FTP CP, and K&N Drop-In
diy coolant drain
