04-10-2024, 04:52 PM | #1 |
Rep 43
How to verify used calipers
I bought four new calipers (370/345mm) is there anything I should do or check to verify these before I paint and mount them to my car?
04-10-2024, 05:58 PM | #2 |
Car Hypochondriac
335
Rep 903
It's a bit of a pain to get the pistons out, but you could replace all the seals and dust boots just to make sure they're fresh. Super cheap to do. I'd recommend maybe putting in new bleeders too. Also cheap.
They're probably fine, but it's good for some peace of mind. |
_ObiJon207.50 PininMargherita10.50 |
04-10-2024, 06:05 PM | #3 |
Rep 306
Check that the dust boots on each piston are in good condition.
If any part of the piston(s) look even a little bit rusty, I'd take the time rebuilding them. Take your time with breaking the bleeder screws free. They sometimes seize and are a pain. If painting, I would mask off and not paint the ledges the pads ride along. The flat machined section. Painting that may cause tolerance issues when installing the pads. |
04-10-2024, 11:08 PM | #4 |
Rep 1,372
Beware using cheap dust boots. They can rip. The Brembo originals, while more expensive, seem more durable.
04-10-2024, 11:31 PM | #5 |
Rep 43
okay. The painting folks will be taking the caliper apart. I will supply them with:
* brembo original dust boots * new bleeder screws * new seals Is there anything else? Does anyone have a part number for these? Are there any preferred stores from which I should source? These are the calipers I have: 34116799469 and 34116799470 thanks for the help |
04-11-2024, 12:48 PM | #7 | |
1988
Rep 2,170
Rears: Fronts: Official colour is Estoril Blue Metallic IIRC
04-11-2024, 05:17 PM | #8 | |
Rep 43
https://autobrakesolutions.com/produ...44229737840958 https://autobrakesolutions.com/produ...44441656852798 |
04-11-2024, 05:19 PM | #9 | |
Rep 43
The Red and Orange are also OEM colors as they came with the "BMW M Performance Brake". I would like to stick to OEM colors if possible. |
04-12-2024, 08:57 AM | #10 |
Rep 287
Drives: 2018 440i xDrive Gran Coupe
Went with red for my upgrade. Replaced m logo with Brembo B, looks cleaner imo.
